  2. Unable To Read Scalar of Billing-profile From a Device.
Unable to read Scalar of billing-profile from a device.
By pradson , 21 June, 2021
I am unable to read billing profile scalars (1.0.94.91.6.255) from a device using DLMSDirector tool.
Kindly suggest what should I do? I have attached the screenshot for the same.
Apart from this, I am sharing you the DLMSDirector logs for the same through email.
Kindly check and suggest.
Thanks & Regards,
Pradson
5 years 1 month ago
Hi Pradson,
Hi Pradson,
Please, don't add images. They are compressed and reading is impossible. I can't see the error message. What version you are using?
If you select the error message box and press Ctrl+C it will copy the error message to the clipboard.
pradson
5 years 1 month ago
In reply to Hi Pradson, by Kurumi
As suggested, Kindly find
As suggested, Kindly find error message.
The given key was not present in the dictionary.
OK
5 years 1 month ago
In the log that you sent all the profile generics are empty. There are no capture objects.
  • Vital479
  • HealthPro16
  • Brandondiz
  • JeffreyPal
  • DingfanXue
