  3. How To Get Notification (Last Gasp) In Suit0
How to get Notification (Last gasp) in suit0
By sandip1212 , 3 May, 2021
hi,
I am tried Last gasp notification in non suite,it works ok.
as following..
<ActionResponse>
<ActionResponseNormal>
<Result Value="Success" />
<ReturnParameters>
<Data>
<Structure Qty="04" >
<String Value="809190046" />
<String Value="865234030289671" />
<Int8 Value="0C" />
<OctetString Value="07E60504030C0F1FFF8000FF" />
</Structure>
</Data>
</ReturnParameters>
</ActionResponseNormal>
</ActionResponse>
Now i want to test notification service with Suite0, i get frame from meter but facing problem in deciphering frame is bellow
7E A0 55 61 00 02 BA 69 7C 7F 34 E6 E7 00 CF 44 30 00 00 00 06 A0 5E C5 68 90 64 7D D4 BE 51 04 86 FE B0 53 20 07 A1 3F 1B 2D E9 13 BB 50 B9 53 90 02 1B 31 DF AA 08 94 FE A2 62 64 70 2C FB BB 8C D6 BD 1D 03 84 1B E1 70 BF DC 62 DF 1D 6E 59 50 60 33 8E 7C 59 7E
encryption key: 01234567890abcdef
authentication key: 01234567890abcdef
server system title : 33 44 4C 28 09 19 00 46
Is we are doing something wrong?
Is notification can done in Suit0?
5 years 2 months ago
Are you using Gurux stack to send the push messages? What programming language you are using?
Block and authentication keys can't be correct, because there are 17 bytes and the key size must be 16 bytes.
sandip1212
hi,
hi,
I am not using Gurux stack. I am developing my Code myself in C language.
key are corrected as bellow,still facing problem.
encryption key: 0123456789abcdef (ascii)
authentication key: 0123456789abcdef(ascii)
server system title : 33 44 4C 28 09 19 00 46(hex)
I did try with your new keys and the decryption failed. There must be something wrong how you encrypt the data, but it's impossible to say what is the reason. Check your keys.
  • Vegazone-au
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
