  2. Energy Meter Voltage Event Not Generating
Energy Meter Voltage event not generating
By mightyChamp , 19 April, 2021
I am new to DLMS. I have tested lots of obis codes and functionality of DLMS with Arduino Mega, and its work fine.
My Meter supports IS 15959. According to IS15959 documentations it has over voltage and under voltage event generation capability with OBIS : "0.0.96.11.0.255", which will return event ID.
I have generated low voltage condition (Volt: 100V), and tried about 30 min or more, but when I read "0.0.96.11.0.255". it returns 0 event ID in return.
Event:Power Related, OBIS: "0.0.96.11.2.255" is working fine, it shows meter power on and off id, and in its log profile OBIS "0.0.99.98.2.255", also shows event id with timestamp.
So how I verify Voltage events or any method I have to change to get voltage related events.
Thank You
5 years 3 months ago
Our clients are Voltage Related-events and it should work. I believe that there is an error in your meter. Can you ask the meter manufacturer to verify this?
mightyChamp
Is there any configurations that should be made before voltage related events to be perform, like threshold setting and time to observe under voltage conditions etc. I didn't find any information regarding configuration, So Is threshold and timeout values are set by default.
You can try to check register monitor object thresholds values and what are actions to do when the threshold value is crossed. I know that some meters are using internal actions and don't show actions in the list. Try if you can add or modify thresholds or actions.
  • QDeYZLrphMziQF…
  • sharrongm69
  • agize
  • BioTips
  • Vital479
