Not able to read Elster AS3500 DLMS meter Via RS485 Port using C stack.
28 posts / 0 new
Last post
ayush
I am using the Elster AS3500 DLMS meter and I am trying to read this meter via serial Connection (RS485) using C stack but not able to read it. But, the same thing when I am trying to read Via GXDLMS director is reading properly.
I found that, Via C stack, it's not sending AARQ request after SNRM request. Below are the Frames:
Via GXDLMS Director :
7E A0 08 02 A1 21 93 E9 DD 7E
15:30:41
7E A0 19 21 02 A1 73 02 43 81 80 0C 05 01 80 06 01 80 07 01 01 08 01 01 05 13 7E
15:30:41 Parsing UA reply succeeded.
15:30:41 Send AARQ request.
7E A0 45 02 A1 21 10 2C D6 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 5C FD 7E
15:30:45
7E A0 38 21 02 A1 30 48 58 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 03 E8 00 07 58 26 7E
15:30:45 Parsing AARE reply succeeded.
Via C stack :
sending Command:
7e a0 08 02 a1 21 93 e9 dd 7e
received buffer: 27
7e a0 19 21 02 a1 73 02 43 81 80 0c 05 01 80 06 01 80 07 01 01 08 01 01 05 13 7e
Can you please tell me, why it's not sending AARQ request from the C stack?
ayush
Hi, I have observed that below function (cl_parseUAResponse) is not returning 0 (Zero) .
if ((ret = cl_snrmRequest(&connection->settings, &messages)) != 0 ||
(ret = com_readDataBlock(connection, &messages, &reply)) != 0 ||
(ret = cl_parseUAResponse(&connection->settings, &reply.data)) != 0)
debug_print("dlms_parseSnrmUaResponse : %d\r\n",ret); // 263
mes_clear(&messages);
reply_clear(&reply);
//return ret; - uncomment this after tesing.
Data Parse is not happening. I have commented the return ret, then its sending the AARQ request.
I have observed that for any frame data parse is not happening for this meter. Even though GXDLMS Tool and Stack frames are same.
Can you tell me the reason and how to resolve this ?
Kurumi's picture
This is tested with your commands and it worked like expected. You have broken something. Reject the changes and try again. You can try with client example if you add this parameter:
-s 208
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ayush
I tried several times, but its returning from that function only, even though SNRM response is correct and not sending AARQ request. and I am using Logical address as 208 only.
The same code is working fine with other DLMS meter( Kamstrup , Chint)
Kurumi's picture
Because this was working when your trace was simulated you need to check that you haven't made any changes for the source code. Try to get the latest version from the GitHub and replace your code with that. Or try to run client example with -s parameter.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ayush
Thanks for your reply .
Sorry, but I am not understanding this - try to run client example with -s parameter.
Can you pls tell me where I have o give this -s parameter in the code. An example will be much appreciated.
ayush
Now I am able to read this ELSTER meter via C library. After commenting the "return DLMS_ERROR_CODE_INVALID_CLIENT_ADDRESS; "
Can you pls tell me why this check is there - if (isClientAddress && size != 1)
//return DLMS_ERROR_CODE_INVALID_CLIENT_ADDRESS;
if (size == 1)
if ((ret = bb_getUInt8(buff, &ch)) != 0)
return ret;
*address = ((ch & 0xFE) >> 1);
else if (size == 2)
if ((ret = bb_getUInt16(buff, &s)) != 0)
return ret;
*address = ((s & 0xFE) >> 1) | ((s & 0xFE00) >> 2);
else if (size == 4)
if ((ret = bb_getUInt32(buff, &l)) != 0)
return ret;
*address = ((l & 0xFE) >> 1) | ((l & 0xFE00) >> 2)
| ((l & 0xFE0000) >> 3) | ((l & 0xFE000000) >> 4);
else
return DLMS_ERROR_CODE_INVALID_PARAMETER;
return DLMS_ERROR_CODE_OK;
ayush
Also can you pls provide cl_getServerAddress function definition. So that I can add it to my DLMS library.
Kurumi's picture
The size of the client address is always 1. If that fails, then your meter sends something else than what you have added here.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ayush
The meter sends the same frame which I have mentioned earlier.
Kurumi's picture
Are you sure that you haven't made modifications to the source code? What compiler you are using?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ayush
Yes I have not done any changes in DLMS library. And I am using GNU C Compiler : 8.2.1
Kurumi's picture
Are you running this in Linux?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ayush
No I am using RTOS based embedded device, ATSAME70Q20 Micro-controller . And I am using Atmel Studio to build the code.
Kurumi's picture
Are (and can) you using malloc? Are you sure that data in the buffer is this:
The reason why I'm asking this is that this is used in lots of different places and if the data is the same as in your log below this should succeed. Verify what data you have saved to the buffer.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ayush
hi,
Yes Malloc has been used in the library, below is the code
void mes_init(message* mes)
mes->capacity = MESSAGE_CAPACITY;
mes->data = (gxByteBuffer**) gxmalloc(mes->capacity * sizeof(gxByteBuffer*));
mes->size = 0;
below is the response we are getting in our embedded device:
sending Command:
received buffer: 27
Client address:0
Client address Size:1
Client address:1
Client address Size:2
I tried to hardcode size to 1 to check whether this meter is parsing data or not. But unfortunately its not parsing when size is 1.
ayush
When I am querying the OBIS code(1.1.72.7.0.255) sometimes I am receiving the below frame can you pls tell me what's this mean.
snrm cmd:
7e a0 15 02 a1 21 93 dd 15 81 80 08 05 02 03 f2 06 02 03 f2 03 f0 7e
Resp:
Aarq Cmd :
7e a0 45 02 a1 21 10 2c d6 e6 e6 00 60 36 a1 09 06 07 60 85 74 05 08 01 01 8a 02 07 80 8b 07 60 85 74 05 08 02 01 ac 0a 80 08 30 30 30 30 30 30 30 30 be 10 04 0e 01 00 00 00 06 5f 1f 04 00 00 1e 1d ff ff 5c fd 7e
resp:
7e a0 38 21 02 a1 30 48 58 e6 e7 00 61 29 a1 09 06 07 60 85 74 05 08 01 01 a2 03 02 01 00 a3 05 a1 03 02 01 00 be 10 04 0e 08 00 06 5f 1f 04 00 00 18 1d 03 e8 00 07 58 26 7e
cmd : 1.1.72.7.0.255
7e a0 1a 02 a1 21 32 a2 cb e6 e6 00 c0 01 81 00 03 01 01 48 07 00 ff 02 00 bc 77 7e
Resp :
7e a0 08 21 02 a1 91 1a 38 7e
Kurumi's picture
Your meter is sending ReceiverReady, but there is no reason why this is happening. I believe that this is a meter issue. You should talk with the meter manufacturer about this.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ayush
This is what i got response from elster team.
After analyzing all the communication logs
Reader Ready means that the authentication is correct and is ready for valid Request.
It appears that the request is incorrect because the response means Next Frame. With this behavior, this means the Request is regarding the frames.
ayush
Thanks for your quick response.
One more query I have.
When I am receiving AARQ response that time its returning value as 260 which is DLMS_OUT_OF_MEMORY even though I am giving Max PDU size 0xFFFF.
snrm cmd:
Resp:
Aarq Cmd :
resp:
Kurumi's picture
Have you cleared the receiver buffer? It's the buffer where you are appending received bytes.
Max PDU size is not causing this DLMS_OUT_OF_MEMORY error. It's something else.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ayush
Thanks for your reply this got resolved.
One more query i have some times i am not getting response from the meter so received buffer is coming 0.
Can you tell me why this is happening if you have any idea?
I am using linux board this time and also i am not using fifo here.
In microcontroller based device i am receiving response every time.
Kurumi's picture
The message is lost for some reason. This is happening all the time when the connection is not good.
If you are making the meter the might also be a problem with the meter, but it's impossible to say what is causing this.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ayush
I found that whenever Next Frame(receiver Ready) is coming as respone that time Command Frame is different that why the meter is requesting to send the next frame. Can you check the command frame and let me know why this is happening. Check the Frame type value.
1.1.72.7.0.255
cmd : 7e a0 1a 02 a1 21 fe c2 c7 e6 e6 00 c0 01 81 00 03 01 01 48 07 00 ff 02 00 bc 77 7e
resp : 7e a0 14 21 02 a1 1e 95 87 e6 e7 00 c4 01 81 00 12 08 bb b9 b5 7e
cmd : 7e a0 1a 02 a1 21 32 a2 cb e6 e6 00 c0 01 81 00 03 01 01 48 07 00 ff 02 00 bc 77 7e
resp : 7e a0 08 21 02 a1 11 12 bc 7e
1.1.14.7.0.255
cmd : 7e a0 1a 02 a1 21 fe c2 c7 e6 e6 00 c0 01 81 00 03 01 01 0e 07 00 ff 02 00 97 6d 7e
resp : 7e a0 14 21 02 a1 1e 95 87 e6 e7 00 c4 01 81 00 12 13 8b 03 f5 7e
cmd :7e a0 1a 02 a1 21 ba e2 c3 e6 e6 00 c0 01 81 00 03 01 01 0e 07 00 ff 02 00 97 6d 7e
resp : 7e a0 08 21 02 a1 f1 1c 5b 7e
ayush
Can you pls reply to this as soon as possible. Please.
Kurumi's picture
If those are two consecutive frames your HDLC frame sequence number is wrong. Make sure that you haven't made any changes to the source code.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ayush
Thanks for your reply. I don't think I have done any changes and those are not two consecutive frames. but I will check. can you tell me in which function I have to check? Is it "dlms_getHdlcFrame()"
Also, can you tell me the Frame type value will be always the same for the command(for the same OBIS of a meter) or it will vary in every query for the same OBIS code?
Kurumi's picture
Another option is that you call ex, read method twice. Each call will increase HDLC sequence number.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
