L & T ERP 300p meter - unable to read
4 posts / 0 new
Last post
amyst
I am trying to connect to L&T ER300P meter through DLMSDirector. But my meter doesn't respond. I am certain it's due to some of my configuration. I tried Authorization mode None and Low with lnt1 password. But still no luck.
Could you please point me the mistake I am doing?
Abhiishek
Kurumi's picture
Are you using an optical probe or RS-232/RS/485?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
amyst
I am using RS485 port. I have RS485 to USB serial converter using that I have connected to meter.
Abhiishek
Amyst
Kurumi's picture
Check your cables. The reason is usually in cables or then the baud rate is wrong. Tryo to change the baud rate.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
