HLS is not working with the latest version of Gurux director 8.2.2008.2701.
With the same project file, we can connect with an older version 8.1.2006.2302.
We are facing this issue with HDLC over a serial port.
Can you first select "Supported Services" tab and check that Get" and "Action" services are selected.
If they are selected can you add trace from the messages so I can check it?
With latest version of Gurux director 8.2.2008.2701; Association with HighGMAC is not connecting for HDLC over local port, with older version it is working fine.
Hi Chintan,
Hi Chintan,
HI,
HI,
HDLC Logs:
15:35:48 Send SNRM request.
TX: 7E A0 08 02 23 23 93 0D 57 7E
15:35:48
RX: 7E A0 1F 23 02 23 73 90 FE 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
15:35:48 Send AARQ request.
TX: 7E A0 6C 02 23 23 10 3D 6D E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 45 4C 53 67 10 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 57 44 5A 3D 2A 52 23 5A 5B 15 1A 20 4E 02 55 69 BE 23 04 21 21 1F 30 00 00 01 F4 93 A4 B7 11 54 3C 26 CF 52 D8 CC F0 B7 28 47 16 08 B2 24 5E 89 10 9E 1C 85 E1 D8 44 7E
15:35:48
RX: 7E A0 47 23 02 23 30 4D A1 E6 E7 00 61 38 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 A4 0A 04 08 45 4C 53 67 10 00 00 00 88 02 07 80 89 07 60 85 74 05 08 02 05 BE 06 04 04 0E 01 06 04 DE B2 7E
15:35:48
Hi Ritesh ,
Hi Ritesh ,
Did you read the frame counter? Can you add a trace from it also to the new topic?
Thanks, New topic open @http:
Thanks, New topic open @http://gurux.fi/node/16649
