  3. EMH LZQJ-XC: Load Profile Reading Issues
EMH LZQJ-XC: Load Profile reading issues
By MLA , 20 August, 2020
Hello.
I'm trying to read load profile values "ProfileGeneric" from my EMH LZQJ-XC meter.
All attempts will result in an error message.
Translated from German:
"The offset must be between plus and minus 14 hours.
Parameter name: offset"
Attachement: '1.0.99.x.x_offset error_GuruX8.jpg' and '1.0.99.x.x_offset error message_GuruX8.jpg'
Program version: 8.2.2007.0602
Same meter is readable with an older program version.
Attachement: '1.0.99.x.x__OK_GuruX7.jpg'
Program version: 7.0.40.1 (Sorry, last working version is unknown)
Same meter is shown in the screens. Read from different computers.
Reading of "Data", "Register", "Clock" is without problems.
Is this a known behaviour?
Are more information needed?
Thank you in advance
6 years 1 month ago
I can't access EMH LZQJ-XC at the moment so I can't verify this, but can you read your clock object?
If the time zone is a positive value (like (60 or 120) then select device settings and check "Use UTC time zone, not standard" from "Advanced tab".
More info from this is available at the clock object's TimeZone description.
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSClock
  • VigneshwaranC1993
  • Yousef Al-Saye…
  • Ask313
  • EmilioBecerra
  • Kundan Dhande
