  3. Landis + Gyr Meters
Landis + gyr meters
By eddiex , 2 June, 2020
Thanks in advance.
Sorry i am new to this.
Just wondering is landis gyr model EM5100, or landis gyr E350 u3400 supported?
Which protocol should i use to commnucate with them?
6 years ago
You can read E350 using GXDLMSDirector. Download it and select L+G as the manufacturer.
We don't have EM5100 and when I read the docs I believe that it's using IEC 62053-21.
eddiex
6 years ago
thanks , i just not sure
thanks , i just not sure whether E350 and E350 u3400 are using same protocol. and may i ask if anyone knows whether the serial port and optical are using same protocol?
thanks
6 years ago
You can try to get a readout from both of them. Send "/?!\r\n" to the serial port and wait what meter replies.
eddiex
6 years ago
Hi Thanks for the help
i send to the serial port but no response, in the documentation it saying use kf, i think it mean kingfisher protocol, but havent found anything over the internet
6 years ago
Have you try with gyr E350? Can you ask meter vendor more information from EM5100?
eddiex
6 years ago
E350 u3400 uses KF2.1
E350 u3400 uses KF2.1 protocol, and E5100 uses KF1 protocol.
So the vendor ask to purchase their empwin software which cost like 1700 dollars.
it has driver software like easydatareader_king and king2, that can help to send command and read data.
i had a peak of the driver folder, it has like 10 different drivers DLMS, KING, KING2, IEC, EDMI MODBUS etc...
I thought all meter has to be IEC compatible...
6 years ago
Is there DLMS label on the meter? If there is then you can communicate with DLMS. I don't know if there are different versions from E350.
6 years ago
I just find out that there are two different E350 meters from Landis+Gyr.
We have this:
https://www.landisgyr.fi/product/landisgyr-e350-electricity-meter-new-g…
Do you have this?
https://www.landisgyr.eu/webfoo/wp-content/uploads/2014/06/E350-Brochur…
eddiex
6 years ago
yes that is the one i have, i
yes that is the one i have, i hope i have the standard one not the u series
eddiex
6 years ago
Thanks for the help
Thanks for the help
And i am also want to know if anci c12.18 is a protocol?
6 years ago
Your meter is using ANSI C12.18 protocol. It means that you can't use DLMS to read it.
You need another app to read it.
