Trying with holley meter, help please!
19 posts / 0 new
Last post
hurani
Hi all,
I am researching for a project to read data from holley meter using bluetooth probe, I succefully connected to it using android (BluetoothSSP Library), then I tried to send String :
--> /?!\r\n
the meter replied with
<-- /HLY5\(Model Number)
then I tried to send SNRM request but there is no reply, I sent it as string and I tried as bytes but no reply, may you assist me?
--> 7E A0 07 03 23 93 BF 32 7E
and this:
--> 7E A0 07 03 21 93 0F 01 7E
I tried everything but no replied!
How to send it maybe in ASCII? PDU?
Thanks in advance
hurani
This from official program of Holley:
S: 55 AF 3F 21 8D 0A
R:
S: 7E A0 07 03 23 53 B3 F4 7E
R:
R: AF 48 CC 59 35 5C B2 44 44 53 44 B2 B8 35 8D 0A
S: 06 B2 35 B2 8D 0A
R: 06 B2 35 B2 8D 0A
S: 7E A0 07 03 23 93 BF 32 7E
R: 7E A0 1E 23 03 73 7B CF 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
S: 7E A0 48 03 23 10 62 20 E6 E6 00 60 3A 80 02 02 84 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 31 31 32 32 33 33 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 FF FF FF 28 00 B7 C6 7E
S: 7E A0 48 03 23 10 62 20 E6 E6 00 60 3A 80 02 02 84 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 FF FF FF 28 00 68 F4 7E
R: 7E A0 37 23 03 30 D4 C9 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 00 F0 00 07 C2 40 7E
S: 7E A0 19 03 23 32 DF EB E6 E6 00 C0 01 81 00 01 01 00 01 08 00 FE 02 00 11 64 7E
R: 7E A8 89 23 03 52 3E 1C E6 E7 00 C4 01 81 00 02 1C 06 00 23 95 72 06 00 23 95 72 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 06 06 00 00 00 06 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 04 3E D1 06 00 08 0D 3A 06 00 23 95 78 06 00 23 95 78 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 23 95 6C 06 00 23 95 6C 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 0D A8 06 00 23 45 C5 1C 7E
Kurumi's picture
Change client address to 0x11, authentication level to Low and password to 00112233.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
hurani
So What is the SNRM will be?
This is 11 in hex and 16 in decimal
Kurumi's picture
I believe that this is a typo, but 0x11 =17, not 16.
Now SNRM is the same as in your log from Holley.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
hurani
Yes, sorry ..
I tried it, but no luck
Kurumi's picture
And you are sending this as a byte array, not a hex string?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
hurani
As byte array like this:
byteArray(0x7E,0xA0,0x07,0x03,0x23,0x93,0xBF,0x32,0x7E)
bt.send(byteArray)
Is it correct?
Kurumi's picture
Yes, this is correct. Are you sending "/?!\r" before that? I'm not sure if meter requires that you need to send it first.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
hurani
Yes, I send it before it, and it replies as I said in first comment the model number of meter
hurani
And what is this command?
55 AF 3F 21 8D 0A
Its reply the same as /?! ..
Edit: I tried guruxDirector with it and it is connected well
Kurumi's picture
I believe that your sniffer settings are not correct.
55 AF 3F 21 8D 0A is "/?!\r"
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
hurani
May you guide me what should I do? After /?! ..
Kurumi's picture
You need to send data as bytearray. this is not byte array. It's array of integers.
bt.send(byteArray)
Try to change this to:
buff = byteArray(0x7E,0xA0,0x07,0x03,0x23,0x93,0xBF,0x32,0x7E)
bt.send(buff)
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
hurani
I sent the command as array of bytes, I am sure ..
If you want I can share code ..
Do I need to do anything before SNRM command?
Is there any way to use iec protocol on holley?
Kurumi's picture
Did you send "06 B2 35 B2 8D 0A" after you have send "/?!\r"?
You also need to change baud-rate.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
hurani
Yes, I tried that, same
Kurumi's picture
Can you share what optical probe (head) you are using?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
hurani
