  3. Create .gxc File For a New Meter
Create .gxc file for a new meter
By hugoabreu1002 , 24 October, 2019
Hello, How can I create a .gxc file for a new meter?
Or even, when you create a new connection following the steps in (http://www.gurux.fi//GXDLMSDirectorExample), the Object Tree will be automatically shown ?
I mean, when I open a .gxc file for a given meter, the Object Tree of COSEM object loads, but, if I don't have the .gxc and create the connection manually, the Object Tree of this new meter will be automatically loaded as well ?
Hugo.
6 years 11 months ago
Check this. I hope it helps you to implement own manufacturer settings.
https://www.gurux.fi/GXDLMSDirector.Manufacturers
It's possible to add all objects to the manufacturer template, but it'll cause problems if meter settings are changed. For example, if there are new objects or some are removed.
  • VigneshwaranC1993
  • Yousef Al-Saye…
  • Ask313
  • EmilioBecerra
  • Kundan Dhande
