  3. L&G E650 Invalid Responce After Initial Connection
L&G E650 Invalid Responce after initial connection
By Virus , 14 June, 2017
Good day
I'm connecting to a L&G E650 via Serial-USB-Optical. Able to read back all info once, after that I can't reconnect. Getting Error "Invalid Response", no settings changed. Sometimes after rebooting Meter, I can connect again, but then also only once.
Here is Log data:
https://pastebin.com/DbYEvweU
Attached Setup as Logo.
Any advice will be appreciated.
Blessings
Herman
9 years 5 months ago
Your serial port is sending some extra bytes. What optical head and serial port convertor your are using (manufacturer and model).
In DLMS this is not a problem, but before we are moving to DLMS this is causing problem.
We try to think something for this.
Virus
In reply to L&G E650 Invalid Responce after initial connection by Kurumi
Good day
Using KoCoS - USB Optical Eye.
Driver: FTDI - USB Serial Port v2.8.28.0
Edit:
Using YAT Terminal I can replicate the Invalid Response:
https://pastebin.com/UKZcwYF2
I don't have any experience with Terminal, but hope this helps.
https://pastebin.com/vasHfqiJ - Without sending the second command like in the first link, receiving
much more data from meter.
Blessings
If you don't send command meter goes to readout mode and it sends lots of data.
We are making changes to this. There is new version available on next week.
aerregei
Gprs connection
Hi, I'd like to estabilish a connection to a L&G E650 that is connected by a gprs modem.
Can you help me in this issue?
Thanks a lot.
BR
Aerregei
GPRS connection
Are you using static or dynamic IPs?
aerregei
GPRS connection
I have in the modem connected to the meter(ApSystem DM530) a M2M sim card,
and in my office a static IP.
BR
Aerregei
GPRS connection
Do you have static IP on your meter and do you know it? Can you ping your meter?
aerregei
GPRS connection
No, I think that I have to estabilish the connection by a dial up modem calling the number of SIM (machine to machine).
Actally, if I call this number by my cellphone, I can ear the old sound of a 56k modem.
Angelo
GPRS connection
Then you are using Terminal connection not GPRS. You can use GXDLMSDirector to read your meter.
Select terminal. Give correct phone number and you can make connection to your meter.
aerregei
Terminal connection
Great!
Many thanks Mikko,
but just another question..
Do I need a dial up modem on COM1 and so a telephone analogic line?
I have only a VOIP ...
What about if I purchase an internet key such as huawey E172?
BR
Angelo
Terminal connection
Hi Angelo,
You need modem for your PC if you want to use GSM connection. Get M2M SIM card and GSM dongle like Huawey E172. That should work. You can see GSM modem as a serial port.
Note! You can read only one meter at the time when using GSM connection.
aerregei
Terminal connection
OK, perfect!
I'll try using a GSM dongle,
I'll keep you update on the result.
BR
Angelo
Virus
Good day
I installed new version of Guru Director.
I'm still getting "Invalid responce" error message.
Here is Log:
12:22:57 PM Initializing serial connection.
12:22:57 PM HDLC sending:/?!<CR><LF>
12:22:59 PM HDLC received: ??/LGZ5\2ZMD4054407.B32<CR><LF>
System.Exception: Invalid responce.
at GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters)
12:42:23 PM Initializing serial connection.
12:42:23 PM HDLC sending:/?!<CR><LF>
12:42:24 PM HDLC received: ??/LGZ5\2ZMD4054407.B32<CR><LF>
Blessings
Virus
9 years 4 months ago
Good day
Here is Log:
Blessings
Are you using baudrate 9600 8None1?
Your dongle is returning some extra bytes. We are improving this. This is not a problem with DLMS,
but when we are moving from IEC to DLMS this is causing an error.
We are releasing new version tomorrow.
Virus
Good day
Settings is same as described in Post #1.( 300 7Even1)
Trying to use 9600 8None1, results in "No response from meter".
Blessings
Sorry, There was other question in this topic and I thought that you was using terminal connection.
Your settings are right. We are releasing new version tomorrow where we have improved this.
aerregei
Terminal connection
It works like a charm!!
You are my Hero Mikko!!
I have just a question: can I act on the scaler?
e.g. in register 1.8.0 I have stored 695865,5 but it has to be : 69586,55
BR
Angelo
Terminal connection
If you have read scaler from the meter (attribute index 3) we are using that and multiply read value with it. Check this value from the meter.
