  3. EMH LZQJ-XC - Failed To Receive Reply From The Device In Given Time.
EMH LZQJ-XC - Failed to receive reply from the device in given time.
Profile picture for user Fatih
By Fatih , 30 May, 2017
EMH LZQJ-XC Serial Number: 3936795
Hi. I Can't connect to EMH. What am I doing wrong? Thanks.
Here Is my Configuration
Network Connector MOXA Baud 9600 8N1
Option 1:
https://www.dropbox.com/s/qafo1x6gcbnc9a8/Screenshot%202017-05-30%2018…
<GXDLMSDevice>
<WaitTime>7</WaitTime>
<PhysicalAddress xsi:type="xsd:decimal">3936795</PhysicalAddress>
<LogicalAddress>0</LogicalAddress>
<StartProtocol>DLMS</StartProtocol>
<Name>EMH</Name>
<Verbose>false</Verbose>
<Conformance>6030112</Conformance>
<Manufacturer>EMH</Manufacturer>
<HDLCAddressing>1</HDLCAddressing>
<MediaType>Gurux.Net.GXNet</MediaType>
<MediaSettings>&lt;IP&gt;192.168.2.250&lt;/IP&gt;
&lt;Port&gt;10001&lt;/Port&gt;
</MediaSettings>
<Objects2 />
</GXDLMSDevice>
Option 2
https://www.dropbox.com/s/jdml32o5x5u5ah6/Screenshot%202017-05-30%2018…
<GXDLMSDevice>
<Authentication>Low</Authentication>
<Password>erYuzf62R/ADUcaJLbuoHA==</Password>
<Name>EMH</Name>
</MediaSettings>
<Objects2 />
</GXDLMSDevice>
Result
18:23:02 Send SNRM request.
7E A0 0A 00 02 6E 17 21 93 71 A3 7E
18:23:09 Failed to receive reply from the device in given time.
What's wrong?
9 years 5 months ago
EMH LZQJ-XC
Your meter settings are right. You should check Moxa settings.
Also check that cable is working.
