  3. L+G E650 System.OutOfMemoryException
By kamil , 9 May, 2017
we were reading data from L+G E650 while we stopped readout without closing connection and after that we are not able to establish new connection (using serial port). After trying to establish connection we get System.OutOfMemoryException . Is there anything we can do in this matter? Basically SNRM request is sent, next UA reply and next after request a very strange frame is transmitted having a lot of "01 0D". The log is as follows:
12:50:35 Initializing serial connection.
12:50:40 Send SNRM request.
7E A0 12 03 21 93 F9 AC 81 80 06 05 01 3E 06 01 80 AB A3 7E
12:50:51 Received data
7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
12:50:51 Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01
12:50:51 Parsing UA reply succeeded.
12:50:51
7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 5C 03 20 FF FF A2 6A 7E
12:51:03 Received data
7E A8 4B 21 03 30 3D EB E6 E7 00 0C 81 95 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 01 0D 05 BF 7E
System.OutOfMemoryException: Za mało pamięci, aby kontynuować wykonywanie tego programu.
w GXDLMSDirector.GXDLMSDevice.InitializeConnection()
w GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters)
Best regards,
9 years 6 months ago
We have received other reports that L+G E650 will behave like this if Disconnect method is not called.
What I have heard that if you try again meter will behave correctly.
Remember to call Disconnect method!
kamil
Thank you very much for quick response. At the moment we are not able to connect but maybe there is a problem with module parametrization so I'll try to get in touch with company which provided the meter. Best regards!
Kamil
Can you try to make connection to the meter and send disconnect right away?
You do not need to initialize connection with sending SNRM message.
kamil
at the moment I restarted the power on the meter and that solved our problem. I think we will run into this again and than I'll prepare software to send disconnect first and let you know if it works. Best regards,
Kamil
