  3. SetArray Throws Exception While Trying To Parse a Structure Object
SetArray throws exception while trying to parse a structure object
By orim , 22 February, 2017
Hi!
Is this method, SetArray, working as it should or am I doing something wrong?
https://github.com/Gurux/Gurux.DLMS.Net/blob/0e05275a0a81e468a9dcb92d87…
I can't get it to work it is called during the following packet:
GxDlmsClient.Method(<a GXDLMSSpecialDaysTable object>, 1, <a GXDLMSSpecialDay object>, DataType.Structure)
The error I'm getting is:
System.InvalidCastException : Unable to cast object of type 'Gurux.DLMS.Objects.GXDLMSSpecialDay' to type 'System.Object[]'.
9 years 9 months ago
Do you want to insert or delete special day ? Or just get a list of them?
orim
Insert/replace
I want to insert/replace the existing ones as mentioned in the Blue Book:
"If a special day with the same index or with the same date as an already defined day is inserted, the old entry will be overwritten"
I have tried getting a list of them and deleting them using method nr. 2, worked fine!
We do not have method in GXDLMSSpecialDaysTable at the moment, but I'll add that to the work list. It should be ready today.
orim
OK, awesome. Thanks for the quick reply. :)
We have added new methods Insert and Delete for GXDLMSSpecialDaysTable for C#. Support for Java, ANSI C++ and ANSI C are coming later. Get new version from GitHub or nuget.org.
GXDLMSSpecialDay e = new GXDLMSSpecialDay();
e.DayId = 2;
e.Date = DateTime.Now;
e.Index = 1;
GXDLMSClient cl = new GXDLMSClient(true, 16, 1, Authentication.None, null, InterfaceType.WRAPPER);
GXDLMSSpecialDaysTable d = new GXDLMSSpecialDaysTable();
d.Insert(cl, e)
orim
Just tried it out, works like a charm! Thanks!
