  3. It's Not Respond After Moving To Mode E
It's not respond after moving to mode E
By abdurrezagh , 25 January, 2017
Do you know the problem
9 years 10 months ago
Unknown bound rate
Can you send trace from reply message? What meter you try to read (manufacturer and model)?
You can get trace from "View Log" under "Tools" -menu.
abdurrezagh
this the log
15:52:11 Initializing serial connection.
15:52:11 03:52:11.910 Info Opening
15:52:11 03:52:11.910 Info Serial Port Settings: Port Name: COM11 Baud Rate: 300 Data Bits: 7 Parity: Even Stop Bits: One Eop: None
15:52:11 03:52:11.944 Info Open
15:52:11 HDLC sending:/?!<CR><LF>
15:52:11 03:52:11.944 Sent 2F 3F 21 0D 0A
15:52:11 03:52:11.976 Received 2F
15:52:12 03:52:12.267 Received 2F
15:52:12 03:52:12.300 Received 2F
15:52:12 03:52:12.333 Received 41
15:52:12 03:52:12.367 Received 4D
15:52:12 03:52:12.400 Received 50
15:52:12 03:52:12.433 Received 30
15:52:12 03:52:12.467 Received 35
15:52:12 03:52:12.500 Received 31
15:52:12 03:52:12.533 Received 39
15:52:12 03:52:12.567 Received 36
15:52:12 03:52:12.600 Received 41
15:52:12 03:52:12.633 Received 2D
15:52:12 03:52:12.667 Received 36
15:52:12 03:52:12.700 Received 31
15:52:12 03:52:12.733 Received 42
15:52:12 03:52:12.767 Received 0D
15:52:12 HDLC received: //AMP05196A-61B<CR><LF>
15:52:12 03:52:12.768 Info Closing
15:52:13 03:52:13.105 Info Closed
System.Exception: Unknown baud rate.
at GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters)
abdurrezagh
meter model
meter is from Ampy automation -UK
type 5235D
Unknown baud rate
Landis+Gyr 5235D meter is not supporting DLMS. It is using IEC 62053–21.
You can't use GXDLMSDirector to read it.
abdurrezagh
can you let me know which
can you let me know which software can i use to read the meter
abdurrezagh
9 years 9 months ago
i got this after probe modify
20:11:49 Initializing serial connection.
20:11:49 08:11:49.832 Info Opening
20:11:49 08:11:49.832 Info Serial Port Settings: Port Name: COM11 Baud Rate: 300 Data Bits: 7 Parity: Even Stop Bits: One Eop: None
20:11:49 08:11:49.865 Info Open
20:11:49 HDLC sending:/?!<CR><LF>
20:11:49 08:11:49.866 Sent 2F 3F 21 0D 0A
20:11:50 08:11:50.192 Received 2F
20:11:50 08:11:50.225 Received 2F
20:11:50 08:11:50.258 Received 41
20:11:50 08:11:50.292 Received 4D
20:11:50 08:11:50.325 Received 50
20:11:50 08:11:50.358 Received 30
20:11:50 08:11:50.392 Received 35
20:11:50 08:11:50.425 Received 31
20:11:50 08:11:50.458 Received 39
20:11:50 08:11:50.492 Received 36
20:11:50 08:11:50.525 Received 41
20:11:50 08:11:50.558 Received 2D
20:11:50 08:11:50.592 Received 36
20:11:50 08:11:50.625 Received 31
20:11:50 08:11:50.658 Received 42
20:11:50 08:11:50.691 Received 0D
20:11:50 HDLC received: /AMP05196A-61B<CR><LF>
20:11:50 BaudRate is : 300
20:11:50 Moving to mode E.
06 32 30 32 0D 0A
20:11:50 08:11:50.729 Sent 06 32 30 32 0D 0A
20:11:52 08:11:52.730 Info Closing
20:11:53 08:11:53.068 Info Closed
20:11:53 08:11:53.068 Info Opening
20:11:53 08:11:53.068 Info Serial Port Settings: Port Name: COM11 Baud Rate: 300 Data Bits: 8 Parity: None Stop Bits: One Eop: None
20:11:53 08:11:53.103 Info Open
20:11:53 Send SNRM request.
7E A0 07 03 23 93 BF 32 7E
20:11:53 08:11:53.603 Sent 7E A0 07 03 23 93 BF 32 7E
20:12:00 Failed to receive reply from the device in given time.
20:12:00 08:12:00.603 Sent 01 42 30 03 0D 0A
20:12:07 08:12:07.604 Info Closing
20:12:07 08:12:07.942 Info Closed
Unknown baud rate
Your meter is using IEC 62053–21. You have to try find other app to read it.
