  3. Unable To Read Objects From Sagem Cx2000 Meter
Unable to read Objects from Sagem cx2000 Meter
By Badi3 , 17 October, 2016
I'm trying to read objects from Sagem Meter using GXDLMSDirector but I'm occuring the below issue:
System.Exception: GetObjects failed. Meter returns Service not allowed exception. Operation not possible
à GXDLMSDirector.MainForm.ReadDevice(GXDLMSDevice dev)
à GXDLMSDirector.MainForm.Read(Control sender, Object[] parameters)
Could you help me please?
10 years 1 month ago
cx2000
Can you read anything from the meter? What kind of data you are sending to the meter?
Badi3
I want to make a "Write" with GXDLMSDirctor, should I make always a Read before?
After Connection succeed, the Write button is always disabled.
Thanks.
Write
Write is disabled until you change value and press Enter.
After that write button is enabled.
Badi3
OK clear. But, should I make a read to all objects before making a write?
If yes, how can I make a specific read?
Thank you in advance.
Write
We are doing read automatically if data type is unknown.
Only changed items are write to the meter.
