  3. Kamstrup OMNIpower Connecting To CCC Module
Kamstrup OMNIpower Connecting to CCC Module
By Martin Hallberg , 15 June, 2016
Hi.
I am trying to connect to the CCC Module interface but only get a error message.
I am using Gurux GXDLMS Editor version 8.0.0.20
16:02:22 Initializing serial connection.
16:02:22 04:02:22.129 Info Opening
16:02:22 04:02:22.129 Info Serial Port Settings: Port Name: COM26 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Eop: None
16:02:22 04:02:22.413 Info Open
16:02:22 Send SNRM request.
7E A0 08 20 03 27 93 73 85 7E
16:02:22 04:02:22.413 Sent 7E A0 08 20 03 27 93 73 85 7E
16:02:29 Failed to receive reply from the device in given time.
16:02:29 04:02:29.414 Info Closing
16:02:29 04:02:29.432 Info Closed
vid GXDLMSDirector.GXDLMSDevice.InitializeConnection() i C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:rad 384
vid GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) i C:\Projects\GXDLMSDirector\Development\MainForm.cs:rad 929
Accrding to Kamstrup the settings for the CCC Module interface should be:
CCC Module interface Association with Low Level security (Password protected):
- Client SAP: 20 (2)
- Server SAP: 16
- Context name: Logical name addressing
- Mechanism name: Low Level security. Password default is ‘12345’
- Conformance: GET, Block transfer with GET, SET, ACTION, SELECTIVE ACCESS
2 For OMNIPOWER software revision F1 (Only) the Client SAP is 19.
Is there anyone out there that could help.
Thanks in advance.
Martin.
Martin Hallberg
10 years 5 months ago
The connection is now working
The connection is now working using the default settings in the tool, my fault. Bad grounding on the serial interface, was the cause.
Profile picture for user Tbnilen
Tbnilen
7 years 10 months ago
In reply to The connection is now working by Martin Hallberg
CCC connection to serial adapter
Hey Martin
Hope you can help me, I try to connect to CCC with a USB>Serial cabel but with no succes, could you help me the with wiring/setup to the serial adapter, I use pin 6, 5 and 2, (gnd, data out, data in).
BR Tommy
asbjoern
7 years 9 months ago
Hi Tommy
Hi Tommy
Did you find a way to connect to the CCC interface?
My best guess is that it is just a 3.3v uart, but I have not been able to confirm this.
250266
In reply to CCC connection to serial adapter by Tbnilen
Serial cable connection
Hi Tommy
Look at my other tread "Kamstrup OMNIPOWER - THREE-PHASE METER".
I have a picture of my cable and connections.
Tbnilen
CCC connection
No, but i’ll try to buy the adapter to FTDI connection.
Tbnilen
In reply to Serial cable connection by 250266
CCC connection
Thanks Lars for your reply, i’ll try it out
BR Tommy
I believe you should check this.
http://www.gurux.fi/comment/13419#comment-13419
Martin Hallberg
7 years 8 months ago
Is help still wanted?
Hi.
Everyone I just saw this message in my spam folder.
BEst regards
Martin Hallberg
Lansen Systems AB
Wireless BUilding TEchnology
www.lansen.se
I have asked this from Kamstrup, but not received reply yet. Sometimes it's taking some time. I believe that amount of the peoples who can answer this in Kamstrup is very limited. :-)
