  3. Strange Behaviour In SNRM Messages
Strange behaviour in SNRM messages
By coppice , 29 April, 2016
If I change the physical and logical server IDs I find the with some settings DLMSDirector sends the blocks of window and maximum message lengths, and with some settings it doesn't. An example is with physical server set to 1 and Logical server set to 0 I get:
7E A0 07 03 21 93 0F 01 7E
but if I change physical server set to 0x100 and Logical server set to 1 I get:
7E A0 17 00 02 04 01 21 93 F1 2E 81 80 08 05 02 00 80 06 02 00 80 F8 85 7E
Surely the information should be sent whatever the addresses are set to?
10 years 6 months ago
We will check this, but message is correct.
Client can ask server to use spesific window size or count.
This is an issue and that this info should not be sent if default values are used.
I added issue from this:
http://www.gurux.fi/node/5370
