  3. Not Getting CGXProfileGenericObject Class Definition Inside DLMSServer C++ Code
Not getting CGXProfileGenericObject class definition inside DLMSServer C++ code
By Swapnil , 22 April, 2016
I am using C++ Server code for communicating to GxDLMSDirector using Logicalname server (i.e 4061).
I am able to complete basic commincation from server to client .
Now I need to add load profile object ("1.0.99.1.0.255") for sending multiple OBIS code .
But code for profile load object (CGXProfileGenericObject ) is commented inside GDLMSBase.cpp .
Please guide me to add the same.
Thank you.
Swapnil
Swapnil
10 years 6 months ago
We checked the profile generic class in C++.
and implemneted the following line of code in init() of GXDLMSBase.cpp file.
CGXDLMSProfileGeneric* pPG = new CGXDLMSProfileGeneric("1.0.99.1.0.255");
pPG->SetCapturePeriod(60);
pPG->SetProfileEntries(100);
pPG->SetSortMethod(GX_SORT_METHOD_FIFO);
pPG->SetSortObject(pClock);
pPG->AddCaptureObject(pClock,2,0);
GetItems().push_back(pPG);
But we could not read the profile generic class in GXDLMSDirector.
Kindly let us know if any step is missing to get the Profile Generic data.
Thank you.
Awaiting your reply.
Administrator
We are just finishing our server side tests with new API. New version is available on this week.
Swapnil
Awaiting for latest code
Awaiting for latest code release .
New version
New version is released. We found one issue yesterday and it took longer than expected to fix it.
Get sources here:
https://github.com/Gurux/Gurux.DLMS.cpp
Swapnil
Thank you for update .
Even in the updated code profilegeneric object implementation in still commented.
We need to know how to use profile generic object functionality .
Swapnil
Hi ,
Hi ,
I was trying to compile the source code for DLMS server but getting the error .Library and client code is build successfully.
Server example
Get new version from GitHub. I was too fast when I updated new version to GitHub and server code for Linux was not commited to our repository.
In reply to Thank you for update . by Swapnil
Profile Generic
I updated new example just now where we add profile generic for server example.
Get latest version from GitHub.
Swapnil
Compilation error
Hi, We got an error while compiling the updated server C++ code as below:
GXDLMSBase.cpp:491:37: error: no matching function for call to ‘std::vector<CGXDLMSVariant>::push_back(CGXDateTime)’
row.push_back(CGXDateTime::Now());
Kindly let us know how to resolve this.
Thank you.
Compilation error
I updated example. Get new version.
Swapnil
Get Object failed error on client side
hi , this change fixed the compilation error .
After running Server we are trying to read data from client, but it is giving error that getObject failed (ON GXDLMSDirrector).
ON client code:
GURUX_DLMS_CLIENT.out: /home/swapnilc/PROJECT_DCU/GuruWorkspace/GURUX_DLMS_CLIENT/development/src/GXHelpers.cpp:1235: static int GXHelpers::GetData(CGXByteBuffer&, CGXDataInfo&, CGXDLMSVariant&): Assertion `0' failed.
Aborted (core dumped)
Swapnil
cpp Server issue
Do you got simiilar isssue with updated code ?? Kindly let me know as I am not able to send any object data with this modified code.
Thank you.
Administrator
cpp Server issue
Dear Swapnil,
we are resolving this.
Administrator
cpp Server issue
Dear Swapnil,
We have fixed this. Get latest version.
Swapnil
library building failed inside development folder
I am getting errors while building library it self ...one of the error message is mentioned below:
In member function ‘int CGXDLMSClient::Read(CGXDLMSObject*, int, std::vector<CGXByteBuffer>&)’:
src/GXDLMSClient.cpp:866:92: error: no matching function for call to ‘CGXDLMSClient::Read(CGXDLMSVariant, DLMS_OBJECT_TYPE, int&, NULL, std::vector<CGXByteBuffer>&)’
return Read(pObject->GetName(), pObject->GetObjectType(), attributeOrdinal, NULL, reply);
Thank you .
Swapnil
10 years 5 months ago
Segmentation falt
Hi ,
Tried to run updated code ,but getting segmentation fault .
In reply to Segmentation falt by Swapnil
Segmentation falt
Can you tell what compiler and Linux distro you are using?
Swapnil
Compiler and Linux Distro
The compiler we are using is Windriver GNU C++ and the Linux Distro is Ubuntu 14.04 LTS.
Thnaks,
Swapnil.
and you are using TCP/IP or serial port connection?
Swapnil
TCP/IP
We are using TCP/IP communication .
Linux issue
We was finally able to duplicate this error today. We fixed it and new client example is available on GitHub.
Swapnil
Director error for profileGeneric object
Thanks you for the update.
We ran the server side code and tried getting the data on Director.
for Profile GenericClass it is throwing a message box saying "Acess Error: Device reports a hardware fault".
Kindly let us know what does this mean.
We would like to know if we have to update the version of director installed on our machine aswell, if needed.
Thank you.
Swapnil.
10 years 4 months ago
What meter you are using (Manufacturer and model)?
Swapnil
Profile Generic capture object settings
Hi ,
I have given manufacturer as Gurux inside GXDLMSdirector and I am only checking with dirrector itself and not with any hardware meter(we will be using our own hardware meters in future) .
Also I have downloaded updated code and working on it .but not able to set values inside capture object buffer .
Can you help me out with setting the object value inside capture buffer ??And how to add multiple objects to capture buffer??
Thank you .
Rahul Kumbhar
We downloaded latest copy of Gurux.DLMS.cpp and trying to communicate with Gurux DLMS Director. we get all object except profilegeneric.
when we trying to read profilegeneric object from Gurux DLMS Director we are getting error as "Acess Error: Device reports a hardware fault". and socket get disconnected.
Please can you tell us how to resolve this issue.
Rahul K.
I test this and it worked. What kind of data you have added to profile generic?
Swapnil
In reply to Profile Generic capture object settings by Kurumi
I am using same code of your's as below and I haven't added any data from my side yet .
//Add profile generic (historical data) object.
CGXDLMSProfileGeneric* profileGeneric = new CGXDLMSProfileGeneric("1.0.99.1.0.255");
profileGeneric->SetCapturePeriod(60);
profileGeneric->SetProfileEntries(100);
profileGeneric->SetSortMethod(DLMS_SORT_METHOD_FIFO);
profileGeneric->SetSortObject(pClock);
CGXDLMSCaptureObject * capture = new CGXDLMSCaptureObject(2, 0);
profileGeneric->GetCaptureObjects().push_back(std::pair<CGXDLMSObject*, CGXDLMSCaptureObject*>(pClock, capture));
profileGeneric->GetCaptureObjects().push_back(std::pair<CGXDLMSObject*, CGXDLMSCaptureObject*>(pRegister, capture));
GetItems().push_back(profileGeneric);
std::vector<CGXDLMSVariant> row;
CGXDateTime tmp = CGXDateTime::Now();
row.push_back(tmp);
row.push_back(10);
profileGeneric->GetBuffer().push_back(row);
Where should I look for my error mentione before!!!?
Thanks ,
Swapnil
Hi Swapnil,
You was right. We fixed this. Get new version from GitHub.
We was using different settings what you are.
Swapnil
Thanks for update .It
Thanks for update .It resolved the hardware fault issue .
Can i know how to capture() functionality should be implemented for updating profile generic data ?I have gone through the java as well as c# implementation for same but not compeletly clear about function yet .
Thanks ,
Swapnil
