Join the Gurux Community or follow @Gurux for project updates.
Gurux.Common class implements interfaces that are needed for Gurux Media components and Gurux Device Framework. Purpose of Gurux Device Framework is help you to read your devices, meters and sensors easier.
You can get source codes and examples from http://www.github.com/gurux
or if you use Nuget install gurux.common using Package Manager Console.
https://www.nuget.org/packages/gurux.common
If you have problems you can ask your questions in Gurux Forum.
