  3. Gurux.DLMS.Iec
Gurux DLMS Component for C#, .Net, Java, Delphi and ANSI C++ Getting started
Read basic information from Gurux.DLMS component before you start to create DLMS client.
Connection Initialization for IEC
The connection initialization depends on the connection type and the device. Some devices require IEC62056-21 protocol handshake when optical port (strobe) connecion is used before starting to communicate using DLMS protocol.
IEC62056-21 Handshake
If you are using IEC handshake with serial port you must first send identify command and move to mode E. If you are using TCP/IP connection you can skip this.
In serial port connection default IEC62056-21 settings are: Bitrate 300, 7E1.
"/?" + deviceSerialNumber + "!\r\n"
Send query to the device containing "/?!" and a new line (0x0D 0x0A) without the quotations. This requests the identity information from the device.
The device responds with serial number and the maximum connection speed. The reply data is formatted as follows:
/XXXZ Ident and a new line
XXX is the manufacturer name
Z is the maximum baud rate
Ident is the Identification info of the device.
Values of Z are:
0 - 300 Bd
1 - 600 Bd
2 - 1 200 Bd
3 - 2 400 Bd
4 - 4 800 Bd
5 - 9 600 Bd
6 - 19200Bd
7, 8, 9 - reserved for later extensions.
Send request to change to DLMS mode. Packet is formatted as follows:
0x06 "0" Z "2" 0x0D 0x0A without the quotations.
Z is the requested connection speed.
  • Java
  • C#
  • Delphi
  • ANSI C++
void InitSerial() throws Exception
    ReceiveParameters<byte[]> p = new ReceiveParameters<byte[]>(byte[].class);
    p.setAllData(false);
    p.setEop((byte) '\n');
    p.setWaitTime(WaitTime);
    String data;
    String replyStr;
    synchronized (Media.getSynchronous())
        data = "/?!\r\n";
        Media.send(data, null);
        if (!Media.receive(p))
            throw new Exception("Invalid meter type.");
        //If echo is used.
        replyStr = new String(p.getReply());
        if (data.equals(replyStr))
    if (replyStr.length() == 0 || replyStr.charAt(0) != '/')
        throw new Exception("Invalid responce.");
    String manufactureID = replyStr.substring(1, 3);
    if (manufacturer.getIdentification().compareToIgnoreCase(manufactureID) != 0)
        throw new Exception("Manufacturer " + manufacturer.getIdentification() + " expected but " + manufactureID + " found.");
    int bitrate = 0;
    char baudrate = replyStr.charAt(4);
    switch (baudrate)
        case '0':
            bitrate = 300;
            break;
        case '1':
            bitrate = 600;
            break;
        case '2':
            bitrate = 1200;
            break;
        case '3':
            bitrate = 2400;
            break;
        case '4':
            bitrate = 4800;
            break;
        case '5':
            bitrate = 9600;
            break;
        case '6':
            bitrate = 19200;
            break;
        default:
            throw new Exception("Unknown baud rate.");
    //Send ACK
    //Send Protocol control character
    byte controlCharacter = (byte)'2';// "2" HDLC protocol procedure (Mode E)
    //Send Baudrate character
    //Mode control character
    byte ModeControlCharacter = (byte)'2';//"2" //(HDLC protocol procedure) (Binary mode)
    //Set mode E.
    byte[] tmp = new byte[] { 0x06, controlCharacter, (byte)baudrate, ModeControlCharacter, 13, 10 };
    GXSerial serial = (GXSerial) Media;
        serial.setBaudRate(bitrate);
        Media.send(tmp, null);
    serial.setDataBits(8);
    serial.setParity(Parity.NONE);
    serial.setStopBits(StopBits.ONE);
void InitSerial()
    GXSerial serial = Media as GXSerial;
    byte Terminator = (byte)0x0A;
    if (serial != null && InitializeIEC)
        serial.BaudRate = 300;
        serial.DataBits = 7;
        serial.Parity = Parity.Even;
        serial.StopBits = StopBits.One;
    Media.Open();
    //Query device information.
    if (Media != null && InitializeIEC)
        string data = "/?!\r\n";
        if (Trace)
            Console.WriteLine("HDLC sending:" + data);
        ReceiveParameters p = new ReceiveParameters()
            Eop = Terminator,
            WaitTime = WaitTime
        lock (Media.Synchronous)
            Media.Send(data, null);
            if (!Media.Receive(p))
                //Try to move away from mode E.
                throw new Exception("Failed to receive reply from the device in given time.");
            //If echo is used.
            if (p.Reply == data)
                p.Reply = null;
        if (Trace)
            Console.WriteLine("HDLC received: " + p.Reply);
        if (p.Reply[0] != '/')
            p.WaitTime = 100;
            Media.Receive(p);
        string manufactureID = p.Reply.Substring(1, 3);
        //UpdateManufactureSettings(manufactureID);
        char baudrate = p.Reply[4];
        int BaudRate = 0;
        switch (baudrate)
            case '0':
                BaudRate = 300;
                break;
            case '1':
                BaudRate = 600;
                break;
            case '2':
                BaudRate = 1200;
                break;
            case '3':
                BaudRate = 2400;
                break;
            case '4':
                BaudRate = 4800;
                break;
            case '5':
                BaudRate = 9600;
                break;
            case '6':
                BaudRate = 19200;
                break;
            default:
        Console.WriteLine("BaudRate is :", BaudRate.ToString());
        //Send ACK
        //Set mode E.
        byte[] arr = new byte[] { 0x06, controlCharacter, (byte)baudrate, ModeControlCharacter, 13, 10 };
        if (Trace)
            Console.WriteLine("Moving to mode E", BitConverter.ToString(arr));
            Media.Send(arr, null);
            p.Reply = null;
            p.WaitTime = 500;
                this.ReadDLMSPacket(m_Parser.DisconnectRequest());
        if (serial != null)
            serial.BaudRate = BaudRate;
            serial.DataBits = 8;
            serial.Parity = Parity.None;
//Delphi do not support serial port at the moment.
void InitSerial()
#if _MSC_VER > 1000
	strcpy_s(buff, 10, "/?!\r\n");
#else
	strcpy(buff, "/?!\r\n");
#endif
    cnt = strlen(buff);
    DWORD sendSize = 0;
    BOOL bRes = ::WriteFile(m_hComPort, buff, cnt, &sendSize, &m_osWrite);
    if (!bRes)
	    DWORD err = GetLastError();
	    //If error occurs...
	    if (err != ERROR_IO_PENDING)
		    return ERROR_CODES_SEND_FAILED;
	    //Wait until data is actually sent
	    ::WaitForSingleObject(m_osWrite.hEvent, INFINITE);
    //Read reply data.
    DWORD bytesRead = 0;
    do
	    cnt = 0;
	    do
		    //Read reply one byte at time.
		    if (!ReadFile(m_hComPort, m_Receivebuff + cnt, 1, &bytesRead, &m_osReader))
			    DWORD nErr = GetLastError();
			    if (nErr != ERROR_IO_PENDING)
			    //Wait until data is actually read
			    ::WaitForSingleObject(m_osReader.hEvent, INFINITE);
		    ++cnt;
	    }while(m_Receivebuff[cnt - 1] != 0x0A);
	    m_Receivebuff[cnt] = 0;
    while(memcmp(buff, m_Receivebuff, cnt) == 0);//Remove echo.
    if (m_Receivebuff[0] != '/')
    char baudrate = m_Receivebuff[4];
    if (baudrate == ' ')
        baudrate = '5';
    int bitrate = 0;
    switch (baudrate)
        case '0':
            bitrate = 300;
            break;
        case '1':
            bitrate = 600;
            break;
        case '2':
            bitrate = 1200;
            break;
        case '3':
            bitrate = 2400;
            break;
        case '4':
            bitrate = 4800;
            break;
        case '5':
            bitrate = 9600;
            break;
        case '6':
            bitrate = 19200;
            break;
        default:
            return ERROR_CODES_INVALID_PARAMETER;
    //Send ACK
    buff[0] = 0x06;
    buff[1] = '2';// "2" HDLC protocol procedure (Mode E)
    buff[2] = baudrate;
    buff[3] = '2';
    buff[4] = (char) 0x0D;
    buff[5] = 0x0A;
    bRes = ::WriteFile(m_hComPort, buff, 6, &sendSize, &m_osWrite);
    if (!bRes)
    //Read reply data.
    bytesRead = 0;
    cnt = 0;
    //This sleep is in standard. Do not remove.
    Sleep(500);
    //Change bit rate.
    conf.dcb.BaudRate = bitrate;
    SetCommState(m_hComPort, &conf.dcb);
    do
	    ++cnt;
    //Change bit rate.
    conf.dcb.ByteSize = 8;
    conf.dcb.StopBits = ONESTOPBIT;
    conf.dcb.Parity = NOPARITY;
    //Some meters need this sleep. Do not remove.
    Sleep(300);
    return ERROR_CODES_OK;
Thats it. Now you can continue with DLMS protocol. If you have any questions or ideas how to improve Gurux.DLMS component let us know or ask question in a Forum
