  3. Gurux.DLMS.Client
Getting started
Read basic information from Gurux.DLMS component before you start to create DLMS client.
Simple meter reading example
Before use the following device parameters must be set. Parameters are manufacturer specific
  • Is Short or Logical name used.
  • Server address
  • Client address
  • Interface type
Usually you can use 1 as Server address and 16 as Client address when authentication is not used. If authentication is used Client address changes.
You can read here to find out how Client and Server addresses are counted.
Some manufacturers might use own custom Server and Client addresses.
Note!
If Server address is wrong meter does not send response. If Client address is wrong you will get authentication error.
Using authentication
When authentication (Access security) is used server(meter) can allow different rights to the client. Without authentication (None) only read is allowed. Gurux DLMS components supports six different authentication level:
  • None
  • Low
  • High
  • HighMD5
  • HighSHA1
  • GMAC
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
GXDLMSClient client = new GXDLMSClient();
// Is used Logican Name or Short Name referencing.
// Is used HDLC or COSEM transport layers for IPv4 networks (IEC 62056-47)
client.setInterfaceType(InterfaceType.HDLC);
client.setClientAddress(16);
client.setServerAddress(1);
import (
    dlms "github.com/Gurux/gxdlms-go"
    "github.com/Gurux/gxdlms-go/enums"
client := dlms.NewGXDLMSSecureClient(
    true,                     // Use Logical Name referencing.
    16,                       // Client address.
    1,                        // Server address.
    enums.AuthenticationNone,  // Authentication level.
    nil,                      // Password.
    enums.InterfaceTypeHDLC,   // HDLC or WRAPPER interface.
client.SetUseLogicalNameReferencing(true)
client.SetInterfaceType(enums.InterfaceTypeHDLC)
client.SetClientAddress(16)
client.SetServerAddress(1)
client.UseLogicalNameReferencing = true;
client.InterfaceType = InterfaceType.Hdlc;
client.ClientAddress = 16;
client.ServerAddress = 1;
Client := TGXDLMSClient.Create(
    True,
  //Client ID
    16,
  //Server ID
    1,
  //Authentication Level.
    TAuthentication.None,
  //PassWord
    Nil,
  TInterfaceType.General);
CGXDLMSClient cl(
true,
//Client ID
16,
//Server ID
1,
GXDLMS_AUTHENTICATION_LOW,
//PassWord
"ABCDEFGH",
GXDLMS_INTERFACETYPE_HDLC);
connection con;
//Support trace.
con_init(&con, 1);
//Initialize settings using Logical Name referencing and WRAPPER.
cl_init(&con.settings,
1,
//Client ID
16,
//Server ID
1,
DLMS_AUTHENTICATION_NONE,
//Password
NULL,
DLMS_INTERFACE_TYPE_HDLC);
client = GXDLMSClient()
#Is used Logican Name or Short Name referencing.
client.useLogicalNameReferencing = True
#Is used HDLC or COSEM transport layers for IPv4 networks (IEC 62056-47)
client.interfaceType = InterfaceType.HDLC
client.clientAddress = 16
client.serverAddress = 1
Connection Initialization
The connection initialization depends on the connection type and the device. Some devices require IEC62056-21 protocol handshake when optical probe (communication head that is using LED to) is used before starting to communicate using DLMS protocol.
Serial/Modem handshake
This is done only with serial and modem connections. Direct tcp/ip doesn't need this. If IEC62056-21 handshake is used it is done before this.
This handshake uses SNMR request to gather packet and window size information from the device.
If the device does not reply to this message usually Server address is wrong or meter do not support DLMS.
Once the full reply data is received call ParseUAResponse method to set configure GXCOSEM Component with correct settings.
AARE request
This is the first command that is mandatory for all connections and device types. This command tells the device if authentication is used and whether Long Name or Short Name reference is used. The packet can be generated with AARQRequest method and it uses UseLogicalName and Authentication properties so make sure these are set to correct values.
If password is defined all data do not necessary do not fit to one message.
Once the full reply is received parse it with ParseAAREResponse method. This method sets the relevant settings to the GXCOSEM component and return a collection of manufacturer specific tags if there was any.
Now the connection is established.
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
byte[] data;
data = client.SNRMRequest();
if (data != null)
    readDLMSPacket(data, reply);
    //Has server accepted client.
    client.parseUAResponse(reply.getData());
//Generate AARQ request.
//Split requests to multiple packets if needed.
//If password is used all data might not fit to one packet.
for (byte[] it : client.AARQRequest())
    reply.clear();
    reply = readDLMSPacket(it, reply);
//Parse reply.
client.parseAAREResponse(reply.getData());
reply := dlms.NewGXReplyData()
frame, err := client.SNRMRequest()
if err != nil {
    return err
if frame != nil {
    if err = reader.ReadDataBlock(frame, reply); err != nil {
        return err
    // Has server accepted client.
    if err = client.ParseUAResponse(reply.Data); err != nil {
        return err
// Generate AARQ request.
// Split requests to multiple packets if needed.
frames, err := client.AARQRequest()
if err != nil {
    return err
for _, frame := range frames {
    reply.Clear()
        return err
// Parse reply.
return client.ParseAAREResponse(reply.Data)
byte[] data;
if (data != null)
    ReadDLMSPacket(data, reply);
foreach (byte[] it in client.AARQRequest())
    reply.Clear();
    reply = ReadDLMSPacket(it, reply);
//Parse reply.
client.ParseAAREResponse(reply.Data);
data := Client.SNRMRequest;
if (data <> Nil) then
begin
  reply := ReadDLMSPacket(data);
  Client.ParseUAResponse(reply);
end;
for data in Client.AARQRequest(nil) do
begin
end;
Client.ParseAAREResponse(reply);
//Initialize connection to the meter.
int InitializeConnection()
	std::vector< std::vector<unsigned char> > data;
	vector<unsigned char> reply;
	int ret = 0;
	//Get meter's send and receive buffers size.
	if ((ret = m_Parser->SNRMRequest(data)) != 0 ||
		(ret = ReadDataBlock(data, reply)) != 0 ||
		(ret = m_Parser->ParseUAResponse(reply)) != 0)
		TRACE("SNRMRequest failed %d.\r\n", ret);
		return ret;
	reply.clear();
	if (m_Parser->GetIntefaceType() == GXDLMS_INTERFACETYPE_NET)
		InitializeBuffers(0xFFFF, 0xFFFF);
	else
		//Initialize send and receive buffers to same as meter's buffers.
		GXDLMSLimits limits = m_Parser->GetLimits();
		CGXDLMSVariant rx = limits.GetMaxInfoRX();
		rx.ChangeType(DLMS_DATA_TYPE_INT32);
		CGXDLMSVariant tx = limits.GetMaxInfoTX();
		tx.ChangeType(DLMS_DATA_TYPE_INT32);
		InitializeBuffers(rx.lVal, tx.lVal);
	if ((ret = m_Parser->AARQRequest(data)) != 0 ||
		(ret = m_Parser->ParseAAREResponse(reply)) != 0)
		if (ret == ERROR_CODES_APPLICATION_CONTEXT_NAME_NOT_SUPPORTED)
			TRACE1("Use Logical Name referencing is wrong. Change it!\r\n");
			return ret;
		TRACE("AARQRequest failed %d.\r\n", ret);
		return ret;
	return ERROR_CODES_OK;
int com_init(
    connection *connection)
    int ret = DLMS_ERROR_CODE_OK;
    message messages;
    gxReplyData reply;
    printf("InitializeConnection\r\n");
    mes_init(&messages);
    reply_init(&reply);
    if ((ret = cl_snrmRequest(&connection->settings, &messages)) != 0 ||
        (ret = com_readDataBlock(connection, &messages, &reply)) != 0 ||
        (ret = cl_parseUAResponse(&connection->settings, &reply.data)) != 0)
        mes_clear(&messages);
        reply_clear(&reply);
        printf("SNRMRequest failed %s\r\n", hlp_getErrorMessage(ret));
        return ret;
    if ((ret = cl_aarqRequest(&connection->settings, &messages)) != 0 ||
        (ret = cl_parseAAREResponse(&connection->settings, &reply.data)) != 0)
        if (ret == DLMS_ERROR_CODE_APPLICATION_CONTEXT_NAME_NOT_SUPPORTED)
            printf("Use Logical Name referencing is wrong. Change it!\r\n");
            return ret;
        printf("AARQRequest failed %s\r\n", hlp_getErrorMessage(ret));
        return ret;
    if (connection->settings.maxPduSize == 0xFFFF)
        con_initializeBuffers(connection, connection->settings.maxPduSize);
    else
        //Allocate 50 bytes more because some meters count this wrong and send few bytes too many.
        con_initializeBuffers(connection, 50 + connection->settings.maxPduSize);
    // Get challenge Is HLS authentication is used.
    if (connection->settings.isAuthenticationRequired)
        if ((ret = cl_getApplicationAssociationRequest(&connection->settings, &messages)) != 0 ||
            (ret = cl_parseApplicationAssociationResponse(&connection->settings, &reply.data)) != 0)
            return ret;
    return DLMS_ERROR_CODE_OK;
reply = GXReplyData()
data = client.snrmRequest()
if data:
    #Has server accepted client.
    client.parseUAResponse(reply.Data)
#Generate AARQ request.
#Split requests to multiple packets if needed.
#If password is used all data might not fit to one packet.
for it in client.aarqRequest():
    reply.clear()
    reply = self.readDLMSPacket(it, reply)
#Parse reply.
client.parseAAREResponse(reply.Data)
If parameters are right connection is made. Next you can read Association view and show all objects that meter can offer.
Association View
Association View describes what kind of objects meter offers. The association view is requested using data from GetObjects method. The reply data is very large so this can take very long time (even hours with slow connection like terminal and if the connection is bad). Because this takes so long it is recommended to save this information for future use as it doesn't change unless meter software is updated. The data structure varies between manufacturers and device models.
The reply data is parsed using ParseObjects method in GXCOSEM Component. The method returns a collection of DLMS Objects.
Some of the data object may be typed as Profile Generic. These are special objects that have columns and rows instead of single value. You can think Profile Generic as a Table.
You should read captures objects (Column names) of Profile Generics here.
Note!
Some meters can return different objects depending from Authentication level. Example Actaris returns only Device ID with Low authentication level. Also Indian Standard IS 15959 defines what what kind of objects are available different authentication levels.
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
/// Read Association View from the meter.
readDataBlock(client.getObjects(), reply);
GXDLMSObjectCollection objects = client.parseObjects(reply.getData(), true);
frames, err := client.GetObjectsRequest()
if err != nil {
    return err
if _, err = reader.ReadDataBlocks(frames, reply); err != nil {
    return err
objects, err := client.ParseObjects(reply.Data, true)
if err != nil {
    return err
ReadDataBlock(client.GetObjects(), reply);
GXDLMSObjectCollection objects = client.ParseObjects(reply.Data, true);
reply := ReadDataBlock(Client.GetObjectsRequest());
Client.ParseObjects(reply, True);
Result := Client.Objects;
if ((ret = Client->GetObjectsRequest(data)) != 0 ||
    (ret = Client->ParseObjects(reply, objects)) != 0)
        TRACE("GetObjects failed %d.\r\n", ret);
        return ret;
int com_getObjects(connection *connection)
    int ret;
    message data;
    gxReplyData reply;
    mes_init(&data);
    reply_init(&reply);
    if ((ret = cl_getObjectsRequest(&connection->settings, &data)) != 0 ||
        (ret = com_readDataBlock(connection, &data, &reply)) != 0 ||
        (ret = cl_parseObjects(&connection->settings, &reply.data)) != 0)
        printf("GetObjects failed %s\r\n", hlp_getErrorMessage(ret));
    mes_clear(&data);
    return ret;
#Read Association View from the meter.
reply = new GXReplyData()
self.readDataBlock(client.getObjects(), reply)
objects = client.parseObjects(reply.Data, True)
Reading values
Reading is generally split in two. Reading of "regular" data objects and profile generic objects.
General Data Objects
Data objects are read using Read method. The parameters are defined as follows:
Item: COSEM Object to read.
Attribute Ordinal: The ordinal number of the requested attribute.
The data is updated using UpdateValue method that returns the value in the format that the device provided.
Profile Generic objects
There are two ways to read Profile Generic data. By Entry or Range. In entry parameters tell where read is started (Zero index) and how many items are read. In range parameters tell starting and ending time.
Note! All meters do not support read by entry or range. You can check is this supported from conformance.
The request is generated using ReadRowsByEntry or ReadRowsByRange methods.
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
Object readObject(GXDLMSObject item, int attributeIndex) throws Exception
    byte[] data = Client.read(item, attributeIndex)[0];
    readDataBlock(data, reply);
    return Client.updateValue(item, attributeIndex, reply.getValue());
func (r *GXDLMSReader) Read(obj objects.IGXDLMSBase, attributeIndex int) (any, error) {
    if obj == nil {
        return nil, errors.New("object is nil")
    frames, err := r.client.Read(obj, attributeIndex)
    if err != nil {
        return nil, err
    if _, err = r.ReadDataBlocks(frames, reply); err != nil {
        return nil, err
    dt, err := obj.GetDataType(attributeIndex)
    if err == nil && dt == enums.DataTypeNone {
        obj.Base().SetDataType(attributeIndex, reply.DataType)
    return r.client.UpdateValue(obj, attributeIndex, reply.Value, nil)
// Read attribute value.
public object Read(GXDLMSObject it, int attributeIndex)
    ReadDataBlock(Client.Read(it.Name, it.ObjectType, attributeIndex), reply);
    return Client.UpdateValue(it, attributeIndex, reply.Value);
function Read(it : TGXDLMSObject; attributeIndex : Integer) : TValue;
var
  reply : TBytes;
begin
  reply := ReadDataBlock(Client.Read(it.Name, it.ObjectType, attributeIndex)[0]);
  Result := Client.UpdateValue(reply, it, attributeIndex);
end;
int Read(CGXDLMSObject* pObject, int attributeIndex)
    int ret;
    std::vector<CGXByteBuffer> data;
    CGXReplyData reply;
    //Read data from the meter.
    if ((ret = m_Parser->Read(pObject, attributeIndex, data)) != 0 ||
        (ret = m_Parser->UpdateValue(*pObject, attributeIndex, reply.GetValue())) != 0)
        return ret;
//Read object.
int com_readObject(
    connection *connection,
    gxObject* object,
    unsigned char attributeOrdinal)
    int ret;
    message data;
    gxReplyData reply;
    mes_init(&data);
    reply_init(&reply);
    if ((ret = cl_read(&connection->settings, object, attributeOrdinal, &data)) != 0 ||
        (ret = cl_updateValue(&connection->settings, object, attributeOrdinal, &reply.dataValue)) != 0)
    mes_clear(&data);
    return ret;
def read(self, item, attributeIndex):
        data = self.client.read(item, attributeIndex)[0]
        self.readDataBlock(data, reply)
        if item.getDataType(attributeIndex) == DataType.NONE:
            item.setDataType(attributeIndex, reply.valueType)
        return self.client.updateValue(item, attributeIndex, reply.value)
Writing values
Writing values to the meter is very simple. You just Update Object's propery and then write it. In this example we want to update clock time of the meter.
Note!
Data type must be correct or meter returns usually error. If you are reading byte value you can't write UIn16.
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
void writeObject(GXDLMSObject item, int attributeIndex) throws Exception
    byte[] data = Client.write(item, attributeIndex);
func (r *GXDLMSReader) Write(obj objects.IGXDLMSBase, attributeIndex int) error {
    if obj == nil {
        return errors.New("object is nil")
    frames, err := r.client.Write(obj, attributeIndex)
    if err != nil {
        return err
    return err
// Write attribute value.
public void Write(GXDLMSObject it, int attributeIndex)
    ReadDataBlock(Client.Write(it, attributeIndex), reply);
procedure TGXProgram.Write(it : TGXDLMSObject; attributeIndex : Integer);
begin
    ReadDataBlock(Client.Write(it, attributeIndex)[0]);
end;
//Write selected object.
int Write(CGXObject* pObject, int attributeIndex, CGXDLMSVariant& value)
	int ret;
	vector< vector<unsigned char> > data;
	CGXDLMSVariant name = pObject->GetName();
	if ((ret = Client->Write(name, pObject->GetObjectType(), attributeIndex, value, data)) != 0 ||
		(ret = ReadDataBlock(data, reply)) != 0)
		TRACE("Write failed %d.\r\n", ret);
		return ret;
int com_write(
    gxObject* object,
    int ret;
    message data;
    gxReplyData reply;
    mes_init(&data);
    reply_init(&reply);
    if ((ret = cl_write(&connection->settings, object, attributeOrdinal, &data)) != 0 ||
        (ret = com_readDataBlock(connection, &data, &reply)) != 0)
        printf("Write failed %s\r\n", hlp_getErrorMessage(ret));
    mes_clear(&data);
    return ret;
# Write attribute value.
self.readDataBlock(client.write(it, attributeIndex), reply)
Disconnecting
Last you must close the connection by sending disconnecting request. If you do not close connection correctly your next connection attempt will fail.
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
void close() throws Exception
    if (Media != null)
        readDLMSPacket(Client.disconnectRequest(), reply);
        Media.close();
func (r *GXDLMSReader) Disconnect() error {
    if r.client == nil || r.media == nil {
        return nil
    if err := r.Release(); err != nil {
        r.writeTrace(fmt.Sprintf("Release failed: %v", err))
        // Ignore release failures for meters that do not support release.
    frame, err := r.client.DisconnectRequest()
    if err != nil {
        return err
    if frame == nil {
        return nil
    return r.ReadDLMSPacket(frame, reply)
func (r *GXDLMSReader) Close() error {
    if r.media == nil {
        return nil
    _ = r.Disconnect()
    err := r.media.Close()
    r.media = nil
    r.client = nil
    return err
void Close()
    if (Media != null && Client != null)
        try
            ReadDLMSPacket(Client.DisconnectRequest(), reply);
            Media.Close();
        catch
            //Ignore if close fails.
        Media = null;
        Client = null;
procedure Close();
begin
  if (Client <> Nil) then
  begin
    ReadDLMSPacket(Client.DisconnectRequest());
  end;
  FreeAndNil(socket);
  FreeAndNil(Client);
end;
int Close()
	int ret;
	if ((ret = m_Parser->DisconnectRequest(data)) != 0 ||
		//Show error.
#if _MSC_VER > 1000
	if (m_hComPort != INVALID_HANDLE_VALUE)
		CloseHandle(m_hComPort);
		m_hComPort = INVALID_HANDLE_VALUE;
		CloseHandle(m_osReader.hEvent);
		CloseHandle(m_osWrite.hEvent);
#endif
	if (m_socket != -1)
		closesocket(m_socket);
		m_socket = -1;
	return ret;
int com_close(
    gxReplyData reply;
    message msg;
    //If client is closed.
    if (!connection->settings.server)
        reply_init(&reply);
        mes_init(&msg);
        if ((ret = cl_disconnectRequest(&connection->settings, &msg)) != 0 ||
            (ret = com_readDataBlock(connection, &msg, &reply)) != 0)
            //Show error but continue close.
            printf("Close failed.");
        mes_clear(&msg);
    if (connection->socket != -1)
        connection->closing = 1;
#if defined(_WIN32) || defined(_WIN64)//Windows includes
        closesocket(connection->socket);
#else
        close(connection->socket);
#endif
        connection->socket = -1;
    else if (connection->comPort != INVALID_HANDLE_VALUE)
        CloseHandle(connection->comPort);
        connection->comPort = INVALID_HANDLE_VALUE;
        CloseHandle(connection->osReader.hEvent);
        CloseHandle(connection->osWrite.hEvent);
#else
        close(connection->comPort);
#endif
    cl_clear(&connection->settings);
    return ret;
def close(self):
    if self.media:
        print("DisconnectRequest")
        try:
            self.readDataBlock(self.client.releaseRequest(), reply)
        except Exception as e:
            pass
            #  All meters don't support release.
        reply.clear()
        self.readDLMSPacket(self.client.disconnectRequest(), reply)
        self.media.close()
Keep Alive
If you do not read anything from the meter you must send a keep alive message. Best way is make a connection, read all data from the meter and close connection.
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
readDLMSPacket(Client.keepAlive(), reply);
frames, err := client.KeepAlive()
if err != nil {
    return err
return err
ReadDLMSPacket(Client.KeepAlive(), reply);
ReadDLMSPacket(Client.GetKeepAlive());
int KeepAlive()
    int ret;
	if ((ret = Client->GetKeepAlive(data)) != 0 ||
		(ret = Client->GetValue(reply, value)) != 0)
		TRACE("Read failed %d.\r\n", ret);
    return ret;
int com_keepAlive(
    int ret;
    message data;
    gxReplyData reply;
    mes_init(&data);
    reply_init(&reply);
    if ((ret = cl_keepAlive(&connection->settings, &data)) != 0 ||
    mes_clear(&data);
    return ret;
self.readDLMSPacket(client.keepAlive(), reply)
Image updating
The meter manufacturer usually defines the identification string and that must be used or the meter returns an error for image transfer initiate.
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • Python
//Check that image transfer is enabled.
readDataBlock(Client, Media, Client.read(target, 5), reply);
Client.updateValue(target, 5, reply.getValue());
if (!target.getImageTransferEnabled())
    throw new Exception("Image transfer is not enabled");
//Step 1: Read image block size.
readDataBlock(Client, Media, Client.read(target, 2), reply);
Client.updateValue(target, 2, reply.getValue());
// Step 2: Initiate the Image transfer process.
readDataBlock(Client, Media, target.imageTransferInitiate(Client, Identification, data.length), reply);
// Step 3: Transfers ImageBlocks.
int[] imageBlockCount = new int[1];
readDataBlock(Client, Media, target.imageBlockTransfer(Client, data, imageBlockCount), reply);
//Step 4: Check the completeness of the Image.
readDataBlock(Client, Media, Client.read(target, 3), reply);
Client.updateValue(target, 3, reply.getValue());
// Step 5: The Image is verified;
readDataBlock(Client, Media, target.imageVerify(Client), reply);
// Step 6: Before activation, the Image is checked;
//Get list to imaages to activate.
readDataBlock(Client, Media, Client.read(target, 7), reply);
Client.updateValue(target, 7, reply);
boolean bFound = false;
for (GXDLMSImageActivateInfo it : target.getImageActivateInfo())
    if (it.getIdentification().equals(Identification))
        bFound = true;
        break;
//Read image transfer status.
readDataBlock(Client, Media, Client.read(target, 6), reply);
Client.updateValue(target, 6, reply);
if (target.getImageTransferStatus() != ImageTransferStatus.IMAGE_VERIFICATION_SUCCESSFUL)
    throw new RuntimeException("Image transfer status is " + target.getImageTransferStatus().toString());
if (!bFound)
    throw new RuntimeException("Image not found.");
//Step 7: Activate image.
readDataBlock(Client, Media, target.imageActivate(Client), reply);
func (r *GXDLMSReader) ImageUpdate(target *objects.GXDLMSImageTransfer, identification []byte, image []byte) error {
    if _, err := r.Read(target, 5); err != nil {
        return err
    if !target.ImageTransferEnabled {
        return errors.New("image transfer is not enabled")
    if _, err := r.Read(target, 2); err != nil {
        return err
    frames, err := target.ImageTransferInitiate(r.client, identification, uint32(len(image)))
    if err != nil {
        return err
        return err
    frames, imageBlockCount, err := target.ImageBlockTransfer(r.client, image)
    if err != nil {
        return err
        return err
    r.writeTrace(fmt.Sprintf("Image blocks transferred: %d", imageBlockCount))
    if _, err = r.Read(target, 3); err != nil {
        return err
    frames, err = target.ImageVerify(r.client)
    if err != nil {
        return err
        return err
    if _, err = r.Read(target, 6); err != nil {
        return err
    if target.ImageTransferStatus != enums.ImageTransferStatusVerificationSuccessful {
        return fmt.Errorf("image transfer status is %s", target.ImageTransferStatus.String())
    frames, err = target.ImageActivate(r.client)
    if err != nil {
        return err
    return err
ReadDataBlock(Client, Media, Client.Read(target, 5), reply);
Client.UpdateValue(target, 5, reply.Value);
if (!target.ImageTransferEnabled)
ReadDataBlock(Client, Media, Client.Read(target, 2), reply);
Client.UpdateValue(target, 2, reply.Value);
ReadDataBlock(Client, Media, target.ImageTransferInitiate(Client, Identification, data.Length), reply);
int imageBlockCount;
ReadDataBlock(Client, Media, target.ImageBlockTransfer(Client, data, out imageBlockCount), reply);
ReadDataBlock(Client, Media, Client.Read(target, 3), reply);
Client.UpdateValue(target, 3, reply.Value);
ReadDataBlock(Client, Media, target.ImageVerify(Client), reply);
//Get list to images to activate.
ReadDataBlock(Client, Media, Client.Read(target, 7), reply);
Client.UpdateValue(target, 7, reply.Value);
bool bFound = false;
foreach (GXDLMSImageActivateInfo it in target.ImageActivateInfo)
    if (it.Identification == Identification)
        bFound = true;
        break;
ReadDataBlock(Client, Media, Client.Read(target, 6), reply);
Client.UpdateValue(target, 6, reply);
if (target.ImageTransferStatus != ImageTransferStatus.VerificationSuccessful)
    throw new Exception("Image transfer status is " + target.ImageTransferStatus.ToString());
if (!bFound)
    throw new Exception("Image not found.");
ReadDataBlock(Client, Media, target.ImageActivate(Client), reply);
//Delphi do not support Image update yet.
CGXReplyData reply;
std::string value;
std::vector<CGXByteBuffer> blocks;
CGXDLMSImageTransfer target("0.0.44.0.0.255");
if ((ret = Read(&target, 5, value)) != DLMS_ERROR_CODE_OK)
    return ret;
if (!target.GetImageTransferEnabled())
    //Image transfer is not enabled.
    return DLMS_ERROR_CODE_INVALID_PARAMETER;
if ((ret = Read(&target, 2, value)) != DLMS_ERROR_CODE_OK)
    return ret;
char* identification = "Image identifier. This depends from the manufacturer and version.";
if ((ret = target.ImageTransferInitiate(m_Parser, identification, strlen(identification), blocks)) != 0 ||
    (ret = ReadDataBlock(blocks, reply)) != 0)
    return ret;
reply.Clear();
blocks.clear();
unsigned long imageBlockCount = 0;
//Image to update. Read this from the file.
CGXByteBuffer image;
if ((ret = target.ImageBlockTransfer(m_Parser, image, imageBlockCount, blocks)) != 0 ||
    return ret;
reply.Clear();
blocks.clear();
if ((ret = Read(&target, 3, value)) != DLMS_ERROR_CODE_OK)
    return ret;
if ((ret = target.ImageVerify(m_Parser, blocks)) != 0 ||
    return ret;
reply.Clear();
blocks.clear();
if ((ret = Read(&target, 7, value)) != DLMS_ERROR_CODE_OK)
    return ret;
for (std::vector<CGXDLMSImageActivateInfo*>::iterator it = target.GetImageActivateInfo().begin(); it != target.GetImageActivateInfo().end(); ++it)
    if ((*it)->GetIdentification().Compare((unsigned char*)identification, strlen(identification)) == 0)
        bFound = true;
        break;
if ((ret = Read(&target, 6, value)) != DLMS_ERROR_CODE_OK)
    return ret;
if (target.GetImageTransferStatus() != DLMS_IMAGE_TRANSFER_STATUS_VERIFICATION_SUCCESSFUL)
    //Invalid Image transfer status.
if (!bFound)
    //Image not found;
if ((ret = target.ImageActivate(m_Parser, blocks)) != 0 ||
    return ret;
# Check that image transfer is enabled.
self.readDataBlock(self.client, self.media, self.client.read(target, 5), reply)
self.client.updateValue(target, 5, reply.value)
if not target.imageTransferEnabled:
    raise Exception("Image transfer is not enabled")
# Step 1: Read image block size.
reply.clear()
self.readDataBlock(self.client, self.media, self.client.read(target, 2), reply)
self.client.updateValue(target, 2, reply.value)
# Step 2: Initiate the Image transfer process.
self.readDataBlock(self.client, self.media, target.imageTransferInitiate(self.client, identification, len(data)), reply)
# Step 3: Transfers ImageBlocks.
imageBlockCount = [0]
self.readDataBlock(self.client, self.media, target.imageBlockTransfer(self.client, data, imageBlockCount), reply)
# Step 4: Check the completeness of the Image.
self.readDataBlock(self.client, self.media, self.client.read(target, 3), reply)
self.client.updateValue(target, 3, reply.value)
# Step 5: The Image is verified;
self.readDataBlock(self.client, self.media, target.imageVerify(self.client), reply)
# Step 6: Before activation, the Image is checked;
# Read image transfer status.
self.readDataBlock(self.client, self.media, self.client.read(target, 6), reply)
self.client.updateValue(target, 6, reply)
if target.imageTransferStatus != ImageTransferStatus.IMAGE_VERIFICATION_SUCCESSFUL:
    raise Exception("Image transfer status is " + str(target.imageTransferStatus)
# Step 7: Activate image.
self.readDataBlock(self.client, self.media, target.imageActivate(self.client), reply)
Sending and receiving data
Data is not always fit to one packet. In this case data can be split to blocks and one block to frames. Gurux DLMS component handles this automatically.
When a full frame is received check if there is more data available using IsMoreData method. If there is more data, generate a new read message using ReceiverReady method and check are there all data received again.
After receiving the full frame check that there wasn't any errors from err.
Reading Frame is implemented as follows:
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
public void readDLMSPacket(byte[] data, GXReplyData reply)
        throws Exception {
    if (data == null || data.length == 0) {
        return;
    Object eop = (byte) 0x7E;
    // In network connection terminator is not used.
    if (dlms.getInterfaceType() == InterfaceType.WRAPPER
            && Media instanceof GXNet) {
        eop = null;
    Integer pos = 0;
    boolean succeeded = false;
    ReceiveParameters<byte[]> p =
            new ReceiveParameters<byte[]>(byte[].class);
    p.setAllData(true);
    p.setEop(eop);
    p.setCount(5);
    p.setWaitTime(WaitTime);
    synchronized (Media.getSynchronous()) {
        while (!succeeded) {
            writeTrace("<- " + now() + "\t" + GXCommon.toHex(data));
            Media.send(data, null);
            if (p.getEop() == null) {
                p.setCount(1);
            succeeded = Media.receive(p);
            if (!succeeded) {
                // Try to read again...
                if (pos++ != 3) {
                    System.out.println("Data send failed. Try to resend "
                            + pos.toString() + "/3");
                    continue;
                throw new RuntimeException("Failed to receive reply from the device in given time.");
        // Loop until whole DLMS packet is received.
        while (!dlms.getData(p.getReply(), reply)) {
                p.setCount(1);
            if (!Media.receive(p)) {
                throw new Exception("Failed to receive reply from the device in given time.");
    writeTrace("-> " + now() + "\t" + GXCommon.toHex(p.getReply()));
    if (reply.getError() != 0) {
        throw new GXDLMSException(reply.getError());
func (r *GXDLMSReader) ReadDLMSPacket(data []byte, reply *dlms.GXReplyData) error {
    if reply == nil {
        return errors.New("reply is nil")
    if data == nil && !reply.IsStreaming() {
        return nil
    notify := dlms.NewGXReplyData()
    reply.Error = 0
    eop := any(byte(0x7E))
    if r.client.InterfaceType() != enums.InterfaceTypeHDLC &&
        r.client.InterfaceType() != enums.InterfaceTypeHdlcWithModeE {
        eop = nil
    unlock := r.media.GetSynchronous()
    defer unlock()
    rd := types.NewGXByteBuffer()
    p := gxcommon.NewReceiveParameters[[]byte]()
    p.EOP = eop
    p.Count = r.client.GetFrameSize(rd)
    p.AllData = true
    p.WaitTime = r.WaitTime
    if !reply.IsStreaming() {
        r.writeTrace("TX:	" + time.Now().Format("15:04:05.000") + "	" + types.ToHex(data, true))
        if err := r.media.Send(data, ""); err != nil {
            return err
        succeeded, err := r.media.Receive(p)
        if err != nil {
            return err
        if !succeeded {
            return errors.New("failed to receive reply from the device in given time")
    if err := rd.Set(p.Reply.([]byte)); err != nil {
        return err
    for {
        complete, err := r.client.GetData(rd, reply, notify)
        if err != nil {
            return err
        if complete {
            break
        if ok, err := r.media.Receive(p); err != nil || !ok {
            if err != nil {
                return err
        if err = rd.Set(p.Reply.([]byte)); err != nil {
            return err
    r.writeTrace("RX:	" + time.Now().Format("15:04:05.000") + "	" + rd.String())
    if reply.Error != 0 {
        return enums.ErrorCode(reply.Error)
    return nil
public void ReadDLMSPacket(byte[] data, GXReplyData reply)
    if (data == null)
        return;
    object eop = (byte)0x7E;
    //In network connection terminator is not used.
    if (Client.InterfaceType == InterfaceType.Wrapper && Media is GXNet)
        eop = null;
    int pos = 0;
    bool succeeded = false;
    ReceiveParameters<byte[]> p = new ReceiveParameters<byte[]>()
        AllData = true,
        Eop = eop,
        Count = 5,
        WaitTime = WaitTime,
    lock (Media.Synchronous)
        while (!succeeded && pos != 3)
            WriteTrace("<- " + DateTime.Now.ToLongTimeString() + "\t" + GXCommon.ToHex(data, true));
            Media.Send(data, null);
            succeeded = Media.Receive(p);
            if (!succeeded)
                //If Eop is not set read one byte at time.
                if (p.Eop == null)
                    p.Count = 1;
                //Try to read again...
                if (++pos != 3)
                    System.Diagnostics.Debug.WriteLine("Data send failed. Try to resend " + pos.ToString() + "/3");
                    continue;
        //Loop until whole COSEM packet is received.
        while (!Client.GetData(p.Reply, reply))
            if (p.Eop == null)
                p.Count = 1;
            if (!Media.Receive(p))
                if (pos != 3)
                    continue;
    if (reply.Error != 0)
        throw new GXDLMSException(reply.Error);
function ReadDLMSPacket(data: TBytes): TBytes;
var
  error: Integer;
  cnt, pos: Integer;
  eop: Variant;
  Description : string;
  stream: TWinSocketStream;
begin
  Result := nil;
  if (data = nil) then
      Exit;
  try
    stream := TWinSocketStream.Create(socket.Socket, WaitTime);
    if Trace then
      writeln(TGXCommon.ToHexString(data));
    //Send data.
    stream.Write(data, 0, Length(data));
    eop := (Byte(126));
    if Client.InterfaceType = TInterfaceType.Net then
      eop := VarEmpty;
    pos := 0;
    repeat
      //Wait new data.
      if stream.WaitForData(WaitTime) = false then
        raise Exception.Create('Failed to received reply from the meter.');
      cnt := socket.Socket.ReceiveLength;
      if cnt <> 0 then
      begin
        SetLength(Result, pos + cnt);
        socket.Socket.ReceiveBuf(Result[pos], cnt);
        pos := pos + cnt;
        //If all data is received.
        if Client.IsDLMSPacketComplete(Result) then
        begin
          break;
        end;
      end;
    Until Length(Result) > 2000;
    if Trace then
      writeln('-> ' + TimeToStr(Time) + ' ' + TGXCommon.ToHexString(Result));
    error := Client.CheckReplyErrors(data, Result, Description);
    if (error <> 0) then
    begin
      raise TGXDLMSException.Create(error);
    end;
  finally
    FreeAndNil(stream);
  end;
end;
// Read DLMS Data frame from the device.
int ReadDLMSPacket(CGXByteBuffer& data, CGXReplyData& reply)
    int ret;
    CGXByteBuffer bb;
    std::string tmp;
    if (data.GetSize() == 0)
    Now(tmp);
    tmp = "<- " + tmp;
    tmp += "\t" + data.ToHexString();
    if (m_Trace)
        printf("%s\r\n", tmp.c_str());
    int len = data.GetSize();
#if defined(_WIN32) || defined(_WIN64)//If Windows
        DWORD sendSize = 0;
        BOOL bRes = ::WriteFile(m_hComPort, data.GetData(), len, &sendSize, &m_osWrite);
        if (!bRes)
            DWORD err = GetLastError();
            //If error occurs...
            if (err != ERROR_IO_PENDING)
                return DLMS_ERROR_CODE_SEND_FAILED;
            //Wait until data is actually sent
            ::WaitForSingleObject(m_osWrite.hEvent, INFINITE);
#else //If Linux
        ret = write(m_hComPort, data.GetData(), len);
        if (ret != len)
            printf("send failed %d\n", errno);
#endif
    else if ((ret = send(m_socket, (const char*)data.GetData(), len, 0)) == -1)
        //If error has occured
        printf("send failed %d\n", WSAGetLastError());
#else
#endif
    tmp = "";
    do
            if (Read(0x7E, bb) != 0)
        else
            len = RECEIVE_BUFFER_SIZE;
            if ((ret = recv(m_socket, (char*)m_Receivebuff, len, 0)) == -1)
                printf("recv failed %d\n", WSAGetLastError());
#else
                printf("recv failed %d\n", errno);
#endif
                return DLMS_ERROR_CODE_RECEIVE_FAILED;
            bb.Set(m_Receivebuff, ret);
        if (tmp.size() == 0)
            Now(tmp);
            tmp = "-> " + tmp + "\t";
        else
            tmp += " ";
        tmp += GXHelpers::BytesToHex(m_Receivebuff, ret);
    } while ((ret = m_Parser->GetData(bb, reply)) == DLMS_ERROR_CODE_FALSE);
    tmp += "\r\n";
    if (m_Trace)
        printf("%s", tmp.c_str());
    GXHelpers::Write("trace.txt", tmp);
    if (ret == DLMS_ERROR_CODE_REJECTED)
        Sleep(1000);
#else
        usleep(1000000);
#endif
        ret = ReadDLMSPacket(data, reply);
    return ret;
int readDLMSPacket(
    gxByteBuffer* data,
    gxReplyData* reply)
    char *hex;
    unsigned long sendSize = 0;
#endif
    int ret = DLMS_ERROR_CODE_OK, cnt;
    if (data->size == 0)
    reply->complete = 0;
    connection->data.size = 0;
    connection->data.position = 0;
    if (connection->trace)
        hex = bb_toHexString(data);
        printf("<- %s\r\n", hex);
        free(hex);
        ret = WriteFile(connection->comPort, data->data, data->size, &sendSize, &connection->osWrite);
        if (ret == 0)
            ret = WaitForSingleObject(connection->osWrite.hEvent, connection->waitTime);
            if (ret != 0)
#else
        ret = write(connection->comPort, data->data, data->size);
        if (ret != data->size)
#endif
    else
        if (send(connection->socket, (const char*)data->data, data->size, 0) == -1)
            //If error has occurred
            printf("DLMS_ERROR_CODE_SEND_FAILED");
    //Loop until packet is complete.
    do
            if (com_read(connection, 0x7E) != 0)
        else
            cnt = connection->data.capacity - connection->data.size;
            if (cnt < 1)
                return DLMS_ERROR_CODE_OUTOFMEMORY;
            if ((ret = recv(connection->socket, (char*)connection->data.data + connection->data.size, cnt, 0)) == -1)
            connection->data.size += ret;
                hex = bb_toHexString(&connection->data);
                printf("-> %s\r\n", hex);
                free(hex);
        ret = cl_getData(&connection->settings, &connection->data, reply);
        if (ret != 0 && ret != DLMS_ERROR_CODE_FALSE)
            break;
    } while (reply->complete == 0);
    return ret;
def readDLMSPacket2(self, data, reply):
if data == None or len(data) == 0:
    return
notify = GXReplyData()
reply.error = 0
succeeded = False
rd = GXByteBuffer()
if not reply.isStreaming():
    self.writeTrace("TX: " + self.now() + "\t" + GXByteBuffer.hex(data), TraceLevel.VERBOSE)
    self.media.sendall(data)
msgPos = 0
count = 100
pos = 0
try:
    while not self.client.getData(rd, reply, notify):
        if notify.data.size != 0:
            if not notify.isMoreData():
                t = GXDLMSTranslator(TranslatorOutputType.SIMPLE_XML)
                xml = t.dataToXml(notify.data)
                print(xml)
                notify.clear()
                msgPos = rd.position
            continue
        rd.position = msgPos
        rd.set(self.media.recv(100))
    if pos == 3:
        raise ValueError("Failed to receive reply from the device in given time.")
    if pos != 0:
        print("Data send failed.  Try to resend " + str(pos) + "/3")
    ++pos
    self.writeTrace("RX: " + self.now() + "\t" + rd.__str__(), TraceLevel.ERROR)
    raise e
self.writeTrace("RX: " + self.now() + "\t" + rd.__str__(), TraceLevel.VERBOSE)
if reply.error != 0:
    raise GXDLMSException(reply.error)
Reading Block is implemeted as follows:
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
    * Reads next data block.
    * @param data
    * @return
    * @throws Exception
void readDataBlock(byte[] data, GXReplyData reply) throws Exception {
    if (data.length != 0) {
        while (reply.isMoreData()) {
            data = dlms.receiverReady(reply.getMoreData());
func (r *GXDLMSReader) ReadDataBlock(data []byte, reply *dlms.GXReplyData) error {
    if err := r.ReadDLMSPacket(data, reply); err != nil {
        return err
    defer unlock()
    for reply.IsMoreData() &&
        (r.client.ConnectionState() != enums.ConnectionStateNone || r.client.PreEstablishedConnection()) {
        if reply.IsStreaming() {
            data = nil
        } else {
            next, err := r.client.ReceiverReady(reply)
            if err != nil {
                return err
            data = next
            return err
    return nil
/// Read data block from the device.
/// data to send
/// Progress text.
/// Received data.
public void ReadDataBlock(byte[] data, GXReplyData reply)
    while (reply.IsMoreData)
        data = Client.ReceiverReady(reply.MoreData);
        if (!Trace)
            //If data block is read.
            if ((reply.MoreData & RequestTypes.Frame) == 0)
                Console.Write("+");
            else
                Console.Write("-");
function ReadDataBlock(data: TBytes): TBytes;
var
  tmp, moredata: Integer;
  allData, reply: TBytes;
begin
  moredata := Integer(Client.GetDataFromPacket(reply, allData));
  while (Integer(moredata) <> 0) do
  begin
    while ((moredata and Integer(TRequestTypes.Frame)) <> 0) do
    begin
      data := Client.ReceiverReady(tRequestTypes.Frame);
      tmp := Integer(Client.GetDataFromPacket(reply, allData));
      if (Trace = False) then
        writeln('-');
      if ((tmp and Integer(TRequestTypes.Frame)) = 0) then
      begin
        moredata := moredata and (not Integer(TRequestTypes.Frame));
        break;
      end;
    end;
    if (moredata and Integer(TRequestTypes.DataBlock)) <> 0 then
    begin
      data := Client.ReceiverReady(TRequestTypes.DataBlock);
        writeln('+');
    end;
  end;
  Result := allData;
end;
int ReadDataBlock(CGXByteBuffer& data, CGXReplyData& reply)
    //If ther is no data to send.
    int ret;
    CGXByteBuffer bb;
    //Send data.
    if ((ret = ReadDLMSPacket(data, reply)) != DLMS_ERROR_CODE_OK)
        return ret;
    while (reply.IsMoreData())
        bb.Clear();
        if ((ret = m_Parser->ReceiverReady(reply.GetMoreData(), bb)) != 0)
            return ret;
        if ((ret = ReadDLMSPacket(bb, reply)) != DLMS_ERROR_CODE_OK)
            return ret;
int com_readDataBlock(
    message* messages,
    gxReplyData* reply)
    gxByteBuffer rr;
    int pos, ret = DLMS_ERROR_CODE_OK;
    //If there is no data to send.
    if (messages->size == 0)
    bb_init(&rr);
    //Send data.
    for (pos = 0; pos != messages->size; ++pos)
        //Send data.
        if ((ret = readDLMSPacket(connection, messages->data[pos], reply)) != DLMS_ERROR_CODE_OK)
            return ret;
        //Check is there errors or more data from server
        while (reply_isMoreData(reply))
            if ((ret = cl_receiverReady(&connection->settings, reply->moreData, &rr)) != DLMS_ERROR_CODE_OK)
                bb_clear(&rr);
                return ret;
            if ((ret = readDLMSPacket(connection, &rr, reply)) != DLMS_ERROR_CODE_OK)
                bb_clear(&rr);
                return ret;
            bb_clear(&rr);
    return ret;
def readDataBlock(self, data, reply):
        if data != None and len(data):
            while reply.isMoreData():
                if reply.isStreaming():
                    data = None
                else:
                    data = self.client.receiverReady(reply.moreData)
Authentication using challenge
When authentication is High or above secret is used. After connection is made client must send challenge to the server and server must accept this challenge. This is done checking is Is Authentication Required after AARE message is parsed. If authentication is required client sends challenge to the server and if everything succeeded server returns own challenge that client checks.
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
//Parse reply.
Client.parseAAREResponse(reply);
 // Get a challenge when HLS authentication is used.
if (Client.getIsAuthenticationRequired())
    reply = readDLMSPacket(Client.getApplicationAssociationRequest());
    Client.parseApplicationAssociationResponse(reply);
// Parse reply.
if err := client.ParseAAREResponse(reply.Data); err != nil {
    return err
// Get challenge when HLS authentication is used.
if client.Authentication() > enums.AuthenticationLow {
    frames, err := client.GetApplicationAssociationRequest()
    if err != nil {
        return err
        reply.Clear()
            return err
    return client.ParseApplicationAssociationResponse(reply.Data)
//Parse reply.
if (Client.IsAuthenticationRequired)
    reply = ReadDLMSPacket(Client.GetApplicationAssociationRequest());
    Client.ParseApplicationAssociationResponse(reply);
//Delphi do not support this at the moment.
if (m_Parser->IsAuthenticationRequired())
    if ((ret = m_Parser->GetApplicationAssociationRequest(data)) != 0 ||
        (ret = m_Parser->ParseApplicationAssociationResponse(reply.GetData())) != 0)
        return ret;
        return ret;
//Parse reply.
client.parseAAREResponse(reply)
#Get challenge Is HSL authentication is used.
if client.isAuthenticationRequired:
    reply = self.readDLMSPacket(client.getApplicationAssociationRequest())
    client.parseApplicationAssociationResponse(reply)
Transport security
DLMS supports three different transport security . When transport security is used each packet is secured using GMAC security. Security level are:
  • Authentication
  • Encryption
  • AuthenticationEncryption
Using secured messages (glo services) is easy. Before security can be used following properties must set:
  • Security
  • SystemTitle
  • AuthenticationKey
  • BlockCipherKey
  • FrameCounter
  • Java
  • Go
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
GXDLMSSecureClient sc = new GXDLMSSecureClient();
sc.getCiphering().setSecurity(Security.ENCRYPTION);
//Default security when using Gurux test server.
sc.getCiphering().setSystemTitle("GRX12345".GetBytes("ASCII");
client := dlms.NewGXDLMSSecureClient()
client.Ciphering().SetSecurity(enums.SecurityEncryption)
// Default system title when using Gurux test server.
client.Ciphering().SetSystemTitle([]byte("GRX12345"))
client.Ciphering().SetAuthenticationKey(types.HexToBytes("D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF"))
client.Ciphering().SetBlockCipherKey(types.HexToBytes("000102030405060708090A0B0C0D0E0F"))
sc.Ciphering.Security = Security.Encryption;
sc.Ciphering.SystemTitle = ASCIIEncoding.ASCII.GetBytes("GRX12345");
CGXDLMSSecureClient cl(true);
cl.GetCiphering()->SetSecurity(DLMS_SECURITY_ENCRYPTION);
CGXByteBuffer st;
st.AddString("GRX12345");
cl.GetCiphering()->SetSystemTitle(st);
connection con;
con_init(&con, 1);
//Initialize settings using Logican Name referencing and HDLC.
cl_init(&con.settings, 1, 1, 1, DLMS_AUTHENTICATION_NONE, NULL, DLMS_INTERFACE_TYPE_WRAPPER);
con.settings.cipher.security = DLMS_SECURITY_ENCRYPTION;
//Clear old values.
bb_clear(&con.settings.cipher.systemTitle);
bb_clear(&con.settings.cipher.authenticationKey);
bb_clear(&con.settings.cipher.blockCipherKey);
//Add new ciphering settings.
bb_addString(&con.settings.cipher.systemTitle, "GRX12345");
bb_addHexString(&con.settings.cipher.authenticationKey, "D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF");
bb_addHexString(&con.settings.cipher.blockCipherKey, "00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F");
sc = GXDLMSSecureClient()
sc.ciphering.security = Security.ENCRYPTION
#Default security when using Gurux test server.
sc.ciphering.systemTitle = "GRX12345".encode()
Thats it. If you have any questions or ideas on how to improve Gurux.DLMS component let us know or ask question in a Forum
