  3. IPv4 Setup
gxdn
By Gurux Documentation , 10 November, 2026
IPv4 setup
This object holds the IPv4 network settings for a meter interface. It connects IP addressing and routing to the underlying communication link.
When to use it
Use it to assign a meter a fixed IPv4 address or enable automatic addressing on a local network.
Attributes
1. Logical name
The OBIS code that identifies this object instance in the meter. Use it to distinguish this instance from other objects of the same class.
2. Data link layer reference
Identifies the setup object for the link that carries IPv4 traffic.
For an Ethernet interface, the reference can identify the MAC address setup object.
3. IP address
Holds the IPv4 address assigned to this interface.
4. Multicast IP addresses
Lists multicast group addresses used by the interface to receive group traffic.
5. IP options
Holds optional IPv4 packet settings, with each option's type, length and data.
6. Subnet mask
Defines which part of an IPv4 address identifies the local network.
7. Gateway IP address
Sets the router address used to reach destinations outside the local network.
8. Use DHCP
Selects whether the interface obtains IPv4 configuration automatically through DHCP.
9. Primary DNS address
Sets the preferred DNS server used to resolve host names.
10. Secondary DNS address
Sets an additional DNS server for name resolution when the preferred server is unavailable.
Actions
1. Add mc IP address
Adds one multicast IP address to the multicast IP address array.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
