  3. STS Payment Token Settings
gxdn
By Gurux Documentation , 10 November, 2026
STS payment token settings
This object exposes the identity and key management settings of a meter that accepts STS payment tokens. It helps a payment system select tokens compatible with that meter.
When to use it
Use it when commissioning a token payment meter or checking its supply group and key revision before issuing tokens.
Attributes
1. Logical name
The OBIS code that identifies this object instance in the meter. Use it to distinguish this instance from other objects of the same class.
2. Meter PAN
Identifies the meter's primary account number using the issuer identifier, decoder reference and check digit. It is set during manufacture.
3. Commodity
Identifies what the meter supplies, such as electricity, water, gas or time. Together with the account currency it determines token units.
4. Token carrier types
Lists the supported ways in which tokens can be carried or presented to the meter.
5. Encryption algorithm
Identifies the algorithm used to protect payment token information.
6. Supply group code
Identifies the meter's supply group for token key management. Key change tokens can update it.
7. Tariff index
Identifies the tariff selection used in token key management. It is updated through key change tokens.
8. Key revision number
Identifies the revision of the token decoding key. It is updated through key change tokens.
9. Key type
Identifies the type of token decoding key currently used by the meter.
10. Key expiry number
Identifies the expiry setting associated with the token decoding key. It is updated through key change tokens.
11. Supported key change tokens
Shows how many tokens the meter supports in a key change sequence.
12. STS certificate
Holds the meter's STS conformance certificate number. It can change when firmware is upgraded.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
