  3. S-FSK Synchronisation Timeouts
gxdn
By Gurux Documentation , 10 November, 2026
S-FSK synchronisation timeouts
Configures when an S-FSK device selects an initiator or abandons an inactive or invalid connection.
When to use it
For example, set a recovery timeout so a meter eventually searches again when its concentrator stops communicating.
Attributes
1. Logical name
Identifies this object instance by its six-part OBIS code. Use it to distinguish this object from other objects of the same class.
2. SearchInitiatorTimeout
Sets how many seconds the device searches before selecting the initiator with the strongest signal. Zero disables this timed search feature.
3. SynchronizationConfirmationTimeout
Sets how many seconds a newly detected physical frame may remain unconfirmed by a valid MAC frame before synchronisation is lost.
4. TimeOutNotAddressed
Sets how many minutes the device may remain without an individually addressed message before returning to its unconfigured state.
5. TimeOutFrameNotOK
Sets how many seconds the device may remain without a correctly formed MAC frame before losing frame synchronisation.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
