  3. S-FSK MAC Counters
gxdn
By Gurux Documentation , 10 November, 2026
S-FSK MAC counters
Records synchronisation history, repeated traffic and frame integrity results on an S-FSK network.
When to use it
For example, inspect synchronisation losses and CRC failures when a meter repeatedly disappears from the network.
Attributes
1. Logical name
Identifies this object instance by its six-part OBIS code. Use it to distinguish this object from other objects of the same class.
2. SynchronizationRegister
Records how often the device has synchronised with each initiator.
3. Desynchronization listing
Counts losses of synchronisation according to their cause, helping distinguish timeouts from other failures.
4. BroadcastFramesCounter
Counts received broadcast frames separately for each source MAC address.
5. RepetitionsCounter
Counts repetition phases in which the device forwards a received frame as a repeater. Several copies sent during one repetition phase count only once.
6. TransmissionsCounter
Counts transmission phases initiated by the device, including repetitions of its own frame. Forwarding a received frame is counted separately as a repetition phase.
7. CrcOkFramesCounter
Counts received frames that passed their CRC integrity check.
8. CrcNOkFramesCounter
Counts received frames that failed their CRC integrity check.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
