  3. PRIME MAC Setup
gxdn
By Gurux Documentation , 10 November, 2026
PRIME MAC setup
Configures how a PRIME node discovers switches, advertises beacons and retries link control messages.
When to use it
For example, adjust discovery and retry timing when commissioning service nodes on a busy power line.
Attributes
1. Logical name
Identifies this object instance by its six-part OBIS code. Use it to distinguish this object from other objects of the same class.
2. MacMinSwitchSearchTime
Sets how many seconds a disconnected service node scans for beacons before requesting switch promotion.
3. MacMaxPromotionPdu
Limits the number of promotion request packets that a service node may send within the configured period.
4. MacPromotionPduTxPeriod
Sets the period, in seconds, over which the promotion request packet limit applies.
5. MacBeaconsPerFrame
Limits the number of beacon slots that a base node may allocate in each frame.
6. MacScpMaxTxAttempts
Limits channel access attempts when earlier attempts found the channel busy.
7. MacCtlReTxTimer
Sets how many seconds to wait for acknowledgement of a link control packet before retrying.
8. MacMaxCtlReTx
Limits retransmissions of a link control packet that has not been acknowledged.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
