  3. PRIME MAC Functional Parameters
gxdn
By Gurux Documentation , 10 November, 2026
PRIME MAC functional parameters
Shows a PRIME node's assigned identities, network role and current beacon arrangement.
When to use it
For example, check whether a meter is connected as a terminal or forwarding traffic as a switch.
Attributes
1. Logical name
Identifies this object instance by its six-part OBIS code. Use it to distinguish this object from other objects of the same class.
2. LnId
Contains the local node identifier assigned when this node registered.
3. LsId
Contains the local switch identifier assigned when the node became a switch. It is not used while the node is a terminal.
4. SId
Identifies the switch through which this node joins the subnetwork. It does not apply to a base node.
5. SNa
Contains the subnetwork address to which the node is registered.
6. State
Reports whether the node is disconnected, a terminal, a switch or a base node.
7. ScpLength
Shows the length, in symbols, of the shared contention period in the current frame.
8. NodeHierarchyLevel
Shows how deep this node is in the subnetwork hierarchy.
9. BeaconSlotCount
Shows how many beacon slots are provided in the current frame.
10. BeaconRxSlot
Identifies the slot in which this node receives its parent switch's beacon.
11. BeaconTxSlot
Identifies the slot in which this node sends its own beacon, when its role requires one.
12. BeaconRxFrequency
Shows the number of frames between received beacons. Zero means a beacon is received in every frame.
13. BeaconTxFrequency
Shows the number of frames between transmitted beacons. Zero means a beacon is sent in every frame.
14. Capabilities
Shows supported functions, such as switching, multicast, retransmission and direct connections, as capability flags.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
