  3. M-Bus Port Setup
gxdn
By Gurux Documentation , 10 November, 2026
M-Bus port setup
Configures an M-Bus port through which a device provides its DLMS server. It includes addressing, packet size and listening periods.
When to use it
For example, configure a battery powered wireless meter to listen during scheduled communication windows.
Attributes
1. Logical name
Identifies this object instance by its six-part OBIS code. Use it to distinguish this object from other objects of the same class.
2. Profile selection
Selects the wired or wireless M-Bus communication profile used by the port.
3. Port communication status
Reports whether the port is available for communication and its current communication state.
4. Data header type
Selects the format of the M-Bus header carried before the application data.
5. Primary address
Sets the short M-Bus address used to address the device.
6. Identification number
Contains the device identification number used in its M-Bus identity.
7. Manufacturer Id
Contains the manufacturer code in the M-Bus identity.
8. MBus version
Contains the device revision used in the M-Bus identity.
9. Device type
Identifies the device category or measured medium in the M-Bus identity.
10. Max PDU size
Sets the largest protocol data unit that the port can handle.
11. Listening window
Lists the time periods during which the port listens for incoming communication.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
