  3. LTE Monitoring
gxdn
By Gurux Documentation , 10 November, 2026
LTE monitoring
This object reports LTE network timers and radio service quality.
This object reports LTE network parameters and radio service quality, including LTE Cat M1 and narrowband IoT operation.
When to use it
Use it to investigate weak cellular coverage or understand a battery-powered meter's network sleep and wake timing.
Attributes
1. Logical name
The OBIS code that identifies this object instance in the meter. Use it to distinguish this instance from other objects of the same class.
2. Quality of service (version 0)
Reports network timers T3402 and T3412, received signal quality RSRQ, received signal strength RSRP and the minimum required reception level qRxlevMin.
2. Network parameters (version 1)
Reports network timers and parameters for power saving, extended paging and coverage, including T3402, T3412 extended, T3324, extended DRX, paging time window and qRxlevMin.
3. Quality of service (version 1)
Reports radio quality RSRQ, received signal level RSRP, signal-to-noise information and the coverage enhancement mode.
Versions
Attribute availability in the supplied component help depends on the object version (version 0: attributes 1-2; version 1: attributes 1-3). Use the version-specific descriptions above where provided.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
