  3. G3-PLC MAC Layer Counters
gxdn
By Gurux Documentation , 10 November, 2026
G3-PLC MAC layer counters
Records traffic and communication problems at the G3 power line link layer. Comparing readings over time helps reveal congestion or poor links.
When to use it
For example, compare missing acknowledgements and checksum errors before and after repairing a noisy connection.
Attributes
1. Logical name
Identifies this object instance by its six-part OBIS code. Use it to distinguish this object from other objects of the same class.
2. TxDataPacketCount
Counts data packets successfully sent.
3. RxDataPacketCount
Counts data packets successfully received.
4. TxCmdPacketCount
Counts link management command packets successfully sent.
5. RxCmdPacketCount
Counts link management command packets successfully received.
6. CSMAFailCount
Counts attempts abandoned after reaching the channel access backoff limit.
7. CSMANoAckCount
Counts unicast data transmissions for which the expected acknowledgement did not arrive.
8. BadCrcCount
Counts received frames that failed the CRC integrity check.
9. TxDataBroadcastCount
Counts broadcast data frames sent.
10. RxDataBroadcastCount
Counts broadcast data frames successfully received.
Versions
Attribute availability in the supplied component help depends on the object version (version 0: attributes 1-10; version 1: attributes 1-10). Use the version-specific descriptions above where provided.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
