  3. Communication Port Protection
gxdn
By Gurux Documentation , 10 November, 2026
Communication port protection
This object protects a communication port by blocking access after repeated failed attempts. It also records failures and shows whether the port is currently locked.
When to use it
Use it to limit repeated unsuccessful access attempts on a meter's remote communication port.
Attributes
1. Logical name
The OBIS code that identifies this object instance in the meter. Use it to distinguish this instance from other objects of the same class.
2. Protection mode
Selects permanent locking, locking after failed attempts or unrestricted access through the port.
3. Allowed failed attempts
Sets how many failed communication attempts are allowed before temporary locking starts.
4. Initial lockout time
Sets the initial temporary lock duration in seconds once the failure limit is reached.
5. Steepness factor
Controls how quickly lock durations grow as further failed attempts occur.
6. Maximum lockout time
Limits the duration of a temporary lock, in seconds.
7. Port
Identifies the object representing the protected port. The reference can be empty when a separate port identification is not needed.
8. Protection status
Shows whether the port is unlocked, temporarily locked or permanently locked.
9. Failed attempts
Counts failed communication attempts since the last reset, regardless of the protection mode.
10. Cumulative failed attempts
Keeps the total failure count independently of the resettable failed attempts counter.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
