  3. CoAP Setup
gxdn
By Gurux Documentation , 10 November, 2026
CoAP setup
This object configures the CoAP layer used to carry meter communication over UDP. It controls acknowledgements, retries, message concurrency and wrapper details.
When to use it
Use it when configuring a CoAP endpoint or adjusting retry timing for a network with long delays.
Attributes
1. Logical name
The OBIS code that identifies this object instance in the meter. Use it to distinguish this instance from other objects of the same class.
2. UDP reference
Identifies the TCP-UDP setup object providing the underlying UDP endpoint and port.
3. Acknowledgement timeout
Sets the minimum initial wait for acknowledgement of a confirmable message, in milliseconds.
4. Acknowledgement random factor
Sets the random variation applied to the initial acknowledgement timeout. The stored factor is expressed in hundredths.
5. Maximum retransmissions
Limits how many times a confirmable message can be sent again without acknowledgement.
6. NStart
Limits the number of requests that may remain outstanding at the same time.
7. Delayed acknowledgement timeout
Sets how long, in milliseconds, to wait for an application response before sending a separate acknowledgement.
8. Exponential backoff
Sets the factor that increases the delay between successive retransmissions. The stored factor is expressed in hundredths.
9. Probing rate
Limits the average number of bytes per second sent to an endpoint that does not respond.
10. CoAP URI path
Sets the resource path used by the meter communication wrapper.
11. Transport mode
Selects support for reliable operation, unreliable operation or both.
12. Wrapper version
Identifies the version of the CoAP wrapper used for meter messages.
13. Token length
Sets the number of bytes used for CoAP client tokens that match responses to requests.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
