  3. Charge
gxdn
By Gurux Documentation , 10 November, 2026
Charge
A charge defines how money is collected for consumption, elapsed time or a payment event. It holds the pricing settings and tracks the amounts collected.
When to use it
Use it to configure a standing charge or to collect part of each top-up toward an outstanding balance.
Attributes
1. Logical name
Identifies this object instance using its six-part OBIS code. Use it to distinguish this object from other instances of the same class.
2. Total amount paid
Shows the total amount collected by this charge.
3. Charge type
Selects whether collection is based on consumption, time or payment events.
4. Priority
Sets the collection priority relative to other charges.
5. Unit charge active
Contains the active commodity reference, scaling and price table.
6. Unit charge passive
Contains a replacement unit charge prepared for later activation.
7. Unit charge activation time
Sets when the passive unit charge becomes active.
8. Period
Defines the collection period in seconds for periodic charging.
9. Charge configuration
Sets options such as percentage-based collection and continuous collection.
10. Last collection time
Records when the most recent collection occurred.
11. Last collection amount
Shows the amount taken in the most recent collection.
12. Total amount remaining
Shows how much is still to be collected when collection has a fixed total.
13. Proportion
Sets the share of a top-up collected by a percentage-based payment-event charge. Values from 0 to 10,000 represent 0 to 100 percent.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
