  3. Connection Is Permanently Rejected. No Common AcseVersion
Connection is permanently rejected. No common AcseVersion
By supernan , 19 January, 2026
I'm trying to connect to wasion meter. the security is using HighGMAC. and the response is "Connection is permanently rejected. No common AcseVersion"
I try many combination on client, logical, physical address and i think the current value is correct because the meter responding and responsive. What could possibly go wrong? Is it regarding the title, block cipher, etc?
This is the log messages:
05:24:26 Send SNRM request.
TX: 7E A0 07 03 0D 93 9C 8B 7E
05:24:26
RX: 7E A0 20 0D 03 73 EB 3E 81 80 14 05 02 02 3B 06 02 02 3B 07 04 00 00 00 01 08 04 00 00 00 01 CA 8A 7E
05:24:26 Send AARQ request.
TX: 7E A0 58 03 0D 10 E0 5A E6 E6 00 60 4A A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 1F 35 57 6D 0D 21 1C 0A 36 4F 3B 24 3C 60 13 6D BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 46 7E 7E
05:24:26
RX: 7E A0 37 0D 03 30 F4 DA E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A2 03 02 01 02 BE 10 04 0E 08 00 06 5F 1F 04 00 40 1E 1D 00 00 00 07 93 62 7E
05:24:26
RX: 7E A0 07 0D 03 73 99 E6 7E
Thank you for your help.
8 months ago
Hi, One of your settings is…
One of your settings is different from what the meter expects. The returned error code doesn't describe the reason why the connection fails.
At first, check that your Wasion meter supports GMAC authentication and your client address is correct. It also might be that the GMAC authentication expects secured connection.
Try removing DeltaValueEncoding from the proposed configuration. It's causing problems with some meters.
supernan
7 months 3 weeks ago
Hi Mikko, You're right. I…
You're right. I need to activate the authentication and security options. Thanks for the guidance. Always spot on.
