  3. Landis Gyr E660
Landis gyr E660
By NovakJ , 9 September, 2025
I have a Landis+Gyr E660 with an Ethernet module E66C.
I can connect to it using the Interface Wrapper (client address 10, logical server 1, physical server 1, authentication set to none).
However, with this setup I only receive serial numbers and similar information.
I need to read the actual metering data.
Any advice on how to properly connect to it would be greatly appreciated.
hasimalpkaya
1 year ago
Hi Novak, I dont know what…
Hi Novak,
I dont know what is your configuration of meter but you need managament association for reading all data.
Client address should be 1. If management authentication is LLS, the default password is 12345678.
1 year ago
Hi Novak, @hasimalpkaya is…
Hi Novak,
@hasimalpkaya is right. The client address changes between authentication levels. The authentication levels and the used client address values should be defined in the meter documentation.
