  3. [WARNING] Parsed_data.py:144:from_payload:The Payload Could Not Be Parsed,client.py:253:get_response_from_msg:The Following Message Could Not Be Translated:
[WARNING] parsed_data.py:144:from_payload:The payload could not be parsed,client.py:253:get_response_from_msg:The following message could not be translated:
By Rameshkumar9159 , 4 June, 2025
Project
Gurux.Common
Status
Active
2025-06-04 13:12:27,320 | [DEBUG] wirepas_network_interface.py:411:_on_response_received:Response for: send_data
2025-06-04 13:12:27,320 | [INFO] meter.py:930:establish_AA_NIC:Application association response from 4263594786 is being parsed.
2025-06-04 13:12:27,322 | [INFO] meter.py:934:establish_AA_NIC:Application association has been established with 4263594786
2025-06-04 13:12:27,323 | [INFO] meter.py:1454:get_meter_serial_number:Get the serial number of the meter in passthrough.
2025-06-04 13:12:27,324 | [INFO] meter.py:1009:get_meter_data:A get request of a data object is being sent to the meter in passthrough.
2025-06-04 13:12:27,325 | [INFO] dlms_network_interface.py:146:send_request:TX: Sending a message of size 40 to node 0xFE214B22(4263594786) through gateway wirepas-gateway1/sink1 and endpoints (2, 44)
2025-06-04 13:12:27,325 | [DEBUG] dlms_network_interface.py:150:send_request:TX: 0001003000010020c81e300000013e810044671d21cb7c9bcf33fde4de2916d5b38702b0cfcac2fb
2025-06-04 13:12:27,326 | [DEBUG] dlms_network_interface.py:159:send_request:<WRAPPER len="40" >
<TargetAddress Value="48" />
<SourceAddress Value="1" />
<PDU>
<!--Decrypt data: C0 01 C7 00 01 00 00 60 01 00 FF 02 00
<GetRequest>
<GetRequestNormal>
<InvokeIdAndPriority Value="199" />
<AttributeDescriptor>
<!--ObjectType.DATA-->
<ClassId Value="1" />
<!--0.0.96.1.0.255-->
<InstanceId Value="0000600100FF" />
<AttributeId Value="2" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
<glo_GetRequest Value="300000013E810044671D21CB7C9BCF33FDE4DE2916D5B38702B0CFCAC2FB" />
</PDU>
</WRAPPER>
2025-06-04 13:12:27,774 | [DEBUG] wirepas_network_interface.py:395:_on_downlink_data_received:Received message with id: 2371311992477016468
2025-06-04 13:12:28,426 | [DEBUG] wirepas_network_interface.py:411:_on_response_received:Response for: send_data
2025-06-04 13:12:33,772 | [INFO] meter.py:435:on_data_received_cb:RX: A payload of size 130 has been received from node 0xFE214B22(4263594786) from network 0x6B2A78(7023224) with gateway wirepas-gateway1/sink1 on endpoints (65, 65)
2025-06-04 13:12:33,772 | [DEBUG] meter.py:440:on_data_received_cb:RX: 0001000100400079db0853454530303036386e20000000379c1b6071952f0c6eb988f4bcd7797bed4ed200074f0239715b369cbace32351ee9b219b40fbb716fa2d49c3fc4d7d0e63ad6cfe7abcbe9a616ef312bf3982c5fb35fe41af07a9346a18b22d2cf0670d5ba02a2f1eaff8c3c7c5ead65fbde74d7a4776ed0cf9eab4e2b00
Data length is 121and there are 122 bytes.
2025-06-04 13:12:33,784 | [WARNING] parsed_data.py:144:from_payload:The payload could not be parsed.
2025-06-04 13:12:33,784 | [ERROR] client.py:253:get_response_from_msg:The following message could not be translated: 0001000100400079db0853454530303036386e20000000379c1b6071952f0c6eb988f4bcd7797bed4ed200074f0239715b369cbace32351ee9b219b40fbb716fa2d49c3fc4d7d0e63ad6cfe7abcbe9a616ef312bf3982c5fb35fe41af07a9346a18b22d2cf0670d5ba02a2f1eaff8c3c7c5ead65fbde74d7a4776ed0cf9eab4e2b00
2025-06-04 13:12:33,785 | [INFO] meter.py:456:on_data_received_cb:A message from 4263594786 could not be parsed.
2025-06-04 13:12:58,427 | [ERROR] dlms_network_interface.py:179:send_request:A timeout occured while waiting for response from node 4263594786
File "/home/ramesh/srikanth_sir/work_folder/dlms/dlms-app/testing_as_modify/dlms_integration_scripts/example_transparent_mode.py", line 95, in <module>
if response.success:
AttributeError: 'Response' object has no attribute 'success'
Priority
Normal
Category
Support request
Rameshkumar9159
1 year 3 months ago
I will try to get the meter…
I will try to get the meter serial number by the manual script but the rx message could not able to decrypt
Rameshkumar9159
1 year 3 months ago
