  3. Sagemcom DlmsDirector Settings
Sagemcom DlmsDirector settings
By ducatilm , 20 March, 2025
Hi , I try to connect with DlmsDirector on Sagemcom XT211 meter . I choose the manufacturer from the drop down menu (sagemcom energy & telecom) and when I try to make connection I receive that error "manufacturer type does not much. Manufacturer is SAG and should be SET".
Is possible to fix the issue with software??
1 year 7 months ago
Hi, It seems that Sagemcom…
It seems that Sagemcom Energy & Telecom has reserved two flag IDs with the same name.
Restart GXDLMSDirecor and select "New Manufacturer Settings Available" from the top menu.
Sagemcom Energy & Telecom (SAG) is added to manufacturers.
Select it and you should be able to read your meter.
