  3. Wrong Result On Second Call Bb_compare()
Wrong result on second call bb_compare()
By Dmitry , 7 November, 2024
Hi, Mikko!
I try compare two buffers twice.
unsigned char vnd[] = "VND";
gxData vndr; // here byteArr "VND"
unsigned char c = bb_compare(vndr.value.byteArr, vnd, 3); //OK, c==1
c = bb_compare(vndr.value.byteArr, vnd, 3); //Fail, c == 0
This is because if the buffers are equal, position of vndr.byteArr changes to length of comparing.
How to compare buffers multiple times?
Thanks!
1 year 11 months ago
Hi, If compare succeeds, the…
If compare succeeds, the bb_compare increases the byte array position with the length of compared str;
Try this:
if (c)
vndr.value.byteArr-position -= 3;
Dmitry
Thanks for you reply. It's…
It's work.
But i think comparing should not change internal state of buffers.
Also i try this:
if(vndr.value.vt == DLMS_DATA_TYPE_OCTET_STRING)
bool res = (memcmp(vndr.value.byteArr->data, vnd, sizeof(vnd)-1) == 0);
Hi, It's designed this way…
It's designed this way and used in many projects, so it can't be changed.
