  3. How Can Write In GXDLMSdirector As HEX The Block Chiper Key Authentication Key????
How can write in GXDLMSdirector as HEX the block chiper key Authentication key????
By ducatilm , 28 October, 2024
Hi Mr. Kurumi, I have problem with XML tab of the DXLMSdirector . The password is converted correctly but the cipher key and Authentication pass is not. The software translate differently the key that I write ( I choose HEX as I did in password). I send you the exact case to understand what I mean.
<GXDLMSDevice xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns="Gurux1">
<WaitTime>53520</WaitTime>
<Authentication>High</Authentication>
<Password />
<HexPassword>AZkWXGUtEnrZ0ht0Dm/0mw==</HexPassword>
<Security>AuthenticationEncryption</Security>
<SecuritySuite>1</SecuritySuite>
<KeyAgreementScheme>1</KeyAgreementScheme>
<SystemTitle>4845430005000001</SystemTitle>
<ServerSystemTitle>4845430005000001</ServerSystemTitle>
<DedicatedKey>DC3CF45EF12C43211964B454A23F0FA1</DedicatedKey>
<BlockCipherKey>00000000000000000000000000000000</BlockCipherKey>
<AuthenticationKey>00000000000000000000000000000000</AuthenticationKey>
<BroadcastKey>00000000000000000000000000000000</BroadcastKey>
<InvocationCounter>10</InvocationCounter>
<FrameCounter>0.0.43.1.1.255</FrameCounter>
<Challenge />
<Signing>0</Signing>
The password is converted correct in XML: <HexPassword>AZkWXGUtEnrZ0ht0Dm/0mw==</HexPassword>
but the Cipher key is not HEX as I choose : <BlockCipherKey>00000000000000000000000000000000</BlockCipherKey>
how can I write as HEX in XML the cipher Key and Authentication pass???
1 year 10 months ago
Hi, GXDLMSDirector checks…
GXDLMSDirector checks the length of the block cipher key and if it's 16 bytes long it's ASCII and if it's 32 bytes long it's hex. So GXDLMSDirector handles this automatically.
ducatilm
Hi Mr. Mikko, thank you for…
Hi Mr. Mikko, thank you for your reply.
I have written everything correctly in accordance with the codes given to me by the manufacturer and with your instructions (the length of the block cipher key to be as HEX), i don't have the ECDSA keys and I haven't activated this option in the "secured connections" .
The meter stops responding just before final approval. There is a chance that the meter need this option (ECDSA keys) to give me final approval for the HLS Gmac Level?
I send you the communication log:
07:26:08 07:26:08.996 Info Opening
07:26:08 07:26:08.996 Info Ρυθμίσεις σειριακής θύρας: Όνομα θύρας: COM3 Ποσοστό Baud: 300 Κομμάτια δεδομένων: 7 Ισοτιμία: Even Διακοπή Bits: One Έλεγχος ροής: None Eop: None
07:26:09 07:26:09.012 Info Open
07:26:10 07:26:10.027 Sent 2F 3F 21 0D 0A
07:26:10 07:26:10.371 Received 2F
07:26:10 07:26:10.402 Received 2F
07:26:10 07:26:10.449 Received 48
07:26:10 07:26:10.480 Received 58
07:26:10 07:26:10.512 Received 45
07:26:10 07:26:10.543 Received 35
07:26:10 07:26:10.574 Received 5C
07:26:10 07:26:10.605 Received 35
07:26:10 07:26:10.636 Received 48
07:26:10 07:26:10.683 Received 58
07:26:10 07:26:10.715 Received 45
07:26:10 07:26:10.746 Received 33
07:26:10 07:26:10.777 Received 31
07:26:10 07:26:10.808 Received 30
07:26:10 07:26:10.840 Received 0D
07:26:10 07:26:10.840 Sent 06 32 35 32 0D 0A
07:26:12 07:26:12.855 Info Closing
07:26:12 07:26:12.964 Info Closed
07:26:12 07:26:12.964 Info Opening
07:26:12 07:26:12.964 Info Ρυθμίσεις σειριακής θύρας: Όνομα θύρας: COM3 Ποσοστό Baud: 9600 Κομμάτια δεδομένων: 8 Ισοτιμία: None Διακοπή Bits: One Έλεγχος ροής: None Eop: None
07:26:13 Send SNRM request.
TX: 7E A0 20 03 21 93 7D D9 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
07:26:13 07:26:13.980 Sent 7E A0 20 03 21 93 7D D9 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
07:26:14 07:26:14.167 Received 7E A0 20
07:26:14 07:26:14.183 Received 20 21 03 73 73 98 81 80 14 05 02 01
07:26:14 07:26:14.199 Received 02 01 FC 07 04 00 00 00 01 08 04 00 00 00
07:26:14 07:26:14.214 Received 01 DD A1
07:26:14
RX: 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 FC 06 02 01 FC 07 04 00 00 00 01 08 04 00 00 00 01 DD A1 7E
07:26:14 Send AARQ request.
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 BE DF FF FF E1 4E 7E
07:26:14 07:26:14.214 Sent 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 BE DF FF FF E1 4E 7E
07:26:14 07:26:14.417 Received 7E A0 37 21 03 30 6C 7C
07:26:14 07:26:14.433 Received 7C E6 E7 00 61 29 A1
07:26:14 07:26:14.449 Received 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00
07:26:14 07:26:14.464 Received BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10
07:26:14 07:26:14.480 Received 01 F9 00 07 4B 9D
07:26:14
RX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 01 F9 00 07 4B 9D 7E
07:26:14 07:26:14.495 Sent 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 01 FF 02 00 C6 93 7E
07:26:14 07:26:14.714 Received 7E A0 15 21 03 52
07:26:14 07:26:14.730 Received 52 5D 8A E6 E7 00 C4 01 C1 00
07:26:14 07:26:14.746 Received 7D 18
07:26:14
RX: 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 00 7D 18 7E
07:26:14 Disconnect request
07:26:14 07:26:14.746 Sent 7E A0 07 03 21 53 03 C7 7E
07:26:14 07:26:14.995 Received 7E A0 07 21
07:26:15 07:26:15.011 Received 21 03
07:26:15
RX: 7E A0 07 21 03 73 01 40 7E
07:26:15 07:26:15.011 Info Closing
07:26:15 07:26:15.152 Info Closed
07:26:15 07:26:15.152 Info Opening
07:26:15 07:26:15.152 Info Ρυθμίσεις σειριακής θύρας: Όνομα θύρας: COM3 Ποσοστό Baud: 300 Κομμάτια δεδομένων: 7 Ισοτιμία: Even Διακοπή Bits: One Έλεγχος ροής: None Eop: None
07:26:15 07:26:15.167 Info Open
07:26:16 07:26:16.183 Sent 2F 3F 21 0D 0A
07:26:16 07:26:16.527 Received 2F
07:26:16 07:26:16.573 Received 2F
07:26:16 07:26:16.605 Received 48
07:26:16 07:26:16.636 Received 58
07:26:16 07:26:16.667 Received 45
07:26:16 07:26:16.698 Received 35
07:26:16 07:26:16.745 Received 5C
07:26:16 07:26:16.777 Received 35
07:26:16 07:26:16.808 Received 48
07:26:16 07:26:16.839 Received 58
07:26:16 07:26:16.870 Received 45
07:26:16 07:26:16.902 Received 33
07:26:16 07:26:16.933 Received 31
07:26:16 07:26:16.964 Received 30
07:26:16 07:26:16.995 Received 0D
07:26:16 07:26:16.995 Sent 06 32 35 32 0D 0A
07:26:19 07:26:19.011 Info Closing
07:26:19 07:26:19.136 Info Closed
07:26:19 07:26:19.136 Info Opening
07:26:19 07:26:19.136 Info Ρυθμίσεις σειριακής θύρας: Όνομα θύρας: COM3 Ποσοστό Baud: 9600 Κομμάτια δεδομένων: 8 Ισοτιμία: None Διακοπή Bits: One Έλεγχος ροής: None Eop: None
07:26:20 Send SNRM request.
TX: 7E A0 20 03 03 93 FE C9 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
07:26:20 07:26:20.151 Sent 7E A0 20 03 03 93 FE C9 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
07:26:20 07:26:20.354 Received 7E A0 20 03 03 73 F0 2E 81 80
07:26:20 07:26:20.370 Received 80 14 05 02 01 FC
07:26:20 07:26:20.386 Received 01 08 04 00 00 00 01 DD A1
07:26:20
RX: 7E A0 20 03 03 73 F0 2E 81 80 14 05 02 01 FC 06 02 01 FC 07 04 00 00 00 01 08 04 00 00 00 01 DD A1 7E
07:26:20 Send AARQ request.
TX: 7E A0 7C 03 03 10 4F 3D E6 E6 00 60 6E A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 45 43 00 05 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 5E 2E 59 16 08 2F 3E 0B 0F 3F 40 4B 4B 18 08 3D BE 34 04 32 21 30 30 00 00 00 01 70 C0 3E BC E1 0B 18 8E C9 82 D3 97 D3 1E 51 28 C4 F1 18 73 3A 31 F1 38 DA 0E 09 ED ED 15 25 A7 38 D0 F7 61 BF CD B7 CA B7 CE 54 BF 6D 7E
07:26:20 07:26:20.386 Sent 7E A0 7C 03 03 10 4F 3D E6 E6 00 60 6E A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 45 43 00 05 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 5E 2E 59 16 08 2F 3E 0B 0F 3F 40 4B 4B 18 08 3D BE 34 04 32 21 30 30 00 00 00 01 70 C0 3E BC E1 0B 18 8E C9 82 D3 97 D3 1E 51 28 C4 F1 18 73 3A 31 F1 38 DA 0E 09 ED ED 15 25 A7 38 D0 F7 61 BF CD B7 CA B7 CE 54 BF 6D 7E
07:26:20 07:26:20.745 Received 7E A0 5A 03 03
07:26:20 07:26:20.761 Received 03 30 84 D8 E6 E7 00 61 4C A1
07:26:20 07:26:20.776 Received 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1
07:26:20 07:26:20.792 Received 03 02 01 01 A4 0A 04 08 48 58 45 03 31 65 E2
07:26:20 07:26:20.807 Received 7C 88 02 07 80 89 07 60 85 74 05 08 02 02
07:26:20 07:26:20.823 Received AA 12 80 10 3E 83 8B 34 BE 20 C2 FA 68 1B
07:26:20 07:26:20.839 Received F5 DB 87 A6 26 C1 BE 06 04 04 0E 01 06 01
07:26:20 07:26:20.854 Received 4F 36
07:26:20
RX: 7E A0 5A 03 03 30 84 D8 E6 E7 00 61 4C A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 A4 0A 04 08 48 58 45 03 31 65 E2 7C 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 3E 83 8B 34 BE 20 C2 FA 68 1B F5 DB 87 A6 26 C1 BE 06 04 04 0E 01 06 01 4F 36 7E
07:26:20 07:26:20.854 Sent 7E A0 07 03 03 53 80 D7 7E
07:26:21 07:26:21.057 Received 7E A0 07 03 03 73 82 F6 7E
07:26:21
RX: 7E A0 07 03 03 73 82 F6 7E
07:26:21 07:26:21.057 Sent 01 42 30 03 0D 0A
Hi, Check that your…
Check that your authentication level and keys are correct.
It's not possible to say what might be the reason because the meter doesn't reply anything. You need to verify the settings from the meter manufacturer.
I believe that one of them is different from what the meter expects.
ducatilm
Hi Mr. Mikko, I send you the…
Hi Mr. Mikko, I send you the LOG with all options enabled (block cipher key, authentication key...etc) and HLS pass from the factory software. please tell me where in that log the block cipher key and authentication pass is stored. How can I read the keys???
>> [16:28:08:646] [Information]
Connecting...
>> [16:28:08:708] [COM3] [Device(COM3)] [EMode] [Wakeup] [Debug]
TX:U
>> [16:28:08:724] [COM3] [Device(COM3)] [EMode] [RequestMsg] [Debug]
TX:/?!<CR><LF>
>> [16:28:09:693] [COM3] [Device(COM3)] [EMode] [IdentificationMsg] [Debug]
RX:/HXE5\5HXE310<CR><LF>
>> [16:28:09:708] [COM3] [Device(COM3)] [EMode] [SelectionMsg] [Debug]
TX:<ACK>252<CR><LF>
>> [16:28:10:771] [COM3] [Device(COM3)] [EMode] [DataMsg] [Debug]
RX:<ACK>252<CR><LF>
>> [16:28:10:787] [COM3] [Device(COM3)] [HDLC] [SNRM] [Debug]
TX:7E A0 20 03 05 93 2E 9D 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
>> [16:28:11:037] [COM3] [Device(COM3)] [HDLC] [UA] [Debug]
RX:7E A0 20 05 03 73 29 F8 81 80 14 05 02 01 FC 06 02 01 FC 07 04 00 00 00 01 08 04 00 00 00 01 DD A1 7E
>> [16:28:11:052] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
TX:7E A0 78 03 05 10 73 1B E6 E6 00 60 6A 80 02 07 80 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 45 43 00 05 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 03 AC 12 80 10 32 B3 84 F5 30 A8 55 21 F3 4E BC 54 00 9C A3 ED BE 2C 04 2A DB 08 48 45 43 00 05 00 00 01 1F 31 00 00 00 01 70 C1 2E 82 E5 BD 8F 90 FE FD C2 3F F2 BE C9 C8 06 E1 E9 8F 8D 20 BE A6 8B 29 F7 3D 7E
>> [16:28:11:568] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
RX:7E A0 80 05 03 30 8B 2A E6 E7 00 61 72 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 48 58 45 03 31 65 E2 7C 88 02 07 80 89 07 60 85 74 05 08 02 03 AA 12 80 10 91 97 17 C5 31 A0 31 36 02 91 D1 28 B0 E1 C3 5A BE 2C 04 2A DB 08 48 58 45 03 31 65 E2 7C 1F 31 00 00 00 01 58 2A A3 FA B6 F0 93 83 C6 9A 41 74 2E C7 93 70 7E 8B E2 0D 47 1A 7C 09 64 90 74 20 7E
>> [16:28:11:646] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
TX:7E A0 77 03 05 32 9A AB E6 E6 00 DD 08 01 02 03 04 05 06 07 08 08 48 45 43 00 05 00 00 01 08 48 58 45 03 31 65 E2 7C 00 00 01 01 00 18 BB ED 21 79 FA D0 A3 C1 D3 A0 43 C6 A9 3F DD ED ED EE 4E 42 9A 7A D8 DF 30 31 00 00 00 02 D1 F6 60 A5 55 31 BE 49 E9 E9 CF AB 62 8F 47 E1 8B F6 FD D8 92 33 07 DE 6A A6 4D 8B 44 DF 4F 96 7E 16 42 CF 6B 06 9A 06 96 66 5D 4F E8 7E
>> [16:28:12:208] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
RX:7E A0 70 05 03 52 B4 1D E6 E7 00 DD 08 01 02 03 04 05 06 07 08 08 48 58 45 03 31 65 E2 7C 08 48 45 43 00 05 00 00 01 00 00 01 01 00 18 66 24 A6 C3 7F 30 8C A9 9D 84 18 A7 9D D5 EE 4C 3F FB 95 61 87 BB FE 6C 29 31 00 00 00 00 B2 BD 59 57 40 63 61 AC AC 25 59 71 09 B3 85 31 A7 29 39 96 4E 90 FC 19 60 4A 55 85 F4 6A 9B 3A 31 23 1E 3C 84 3C 7E
>> [16:28:12:240] [Information]
Connect success!
>> [16:28:12:349] [Information]
Reading...
Device ID 1-Serial number {1, 0-0:96.1.0.255, 2}
>> [16:28:12:349] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
TX:7E A0 65 03 05 54 7D 57 E6 E6 00 DD 08 01 02 03 04 05 06 07 08 08 48 45 43 00 05 00 00 01 08 48 58 45 03 31 65 E2 7C 00 00 01 01 00 18 E5 2D EB E8 57 79 04 30 18 4C 01 10 87 60 84 5C 14 3D DB 93 66 39 21 7A 1E 31 00 00 00 03 3B 12 DD 4C 03 C5 4E 2B 7B 1D 85 71 5D 0E 6E 58 3C AE 03 75 F2 E8 4A 07 1F 9C C5 7E
>> [16:28:12:833] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
RX:7E A0 66 05 03 74 BB D1 E6 E7 00 DD 08 01 02 03 04 05 06 07 08 08 48 58 45 03 31 65 E2 7C 08 48 45 43 00 05 00 00 01 00 00 01 01 00 18 A4 80 84 3C 12 72 9D 4E 47 75 96 8F E4 5D 90 28 30 67 B1 65 D1 5F 41 58 1F 31 00 00 00 00 6D 53 38 08 D6 BC FB F0 39 CD D0 F4 58 A8 A1 3B 23 D5 22 0A 99 1E 34 9B 11 96 70 82 7E
>> [16:28:12:865] [Information]
Read success. Device ID 1-Serial number {1, 0-0:96.1.0.255, 2}
>> [16:28:13:005] [Information]
Reading...
Clock {8, 0-0:1.0.0.255, 2}
>> [16:28:13:005] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
TX:7E A0 65 03 05 76 6D 55 E6 E6 00 DD 08 01 02 03 04 05 06 07 08 08 48 45 43 00 05 00 00 01 08 48 58 45 03 31 65 E2 7C 00 00 01 01 00 18 B8 A1 22 86 CD 16 9D 5E 10 10 D6 24 3B DF 05 CF B7 E2 F8 00 81 7F D5 01 1E 31 00 00 00 04 B3 06 57 E4 4E 07 12 CF A2 D0 2F 12 32 9D CD 9B 6A 3D 3B 90 3F 45 97 87 CF 4C F7 7E
>> [16:28:13:521] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
RX:7E A0 6A 05 03 96 93 82 E6 E7 00 DD 08 01 02 03 04 05 06 07 08 08 48 58 45 03 31 65 E2 7C 08 48 45 43 00 05 00 00 01 00 00 01 01 00 18 FD 6F CA 38 5E 04 B7 1B 26 BB 42 E9 C4 E3 DC 3A 0C 84 C3 72 47 29 A1 EE 23 31 00 00 00 00 8A 4D 96 3C 57 95 EF 4B 59 3C FF 15 21 46 05 33 B4 AC E0 18 65 53 B9 33 A4 B4 F9 2A BC B9 8D B4 7E
>> [16:28:13:536] [Information]
Read success. Clock {8, 0-0:1.0.0.255, 2}
>> [16:28:13:583] [Information]
Reading...
Clock {8, 0-0:1.0.0.255, 3}
>> [16:28:13:599] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
TX:7E A0 65 03 05 98 1D 5B E6 E6 00 DD 08 01 02 03 04 05 06 07 08 08 48 45 43 00 05 00 00 01 08 48 58 45 03 31 65 E2 7C 00 00 01 01 00 18 64 0F 62 FF E5 F7 D1 23 92 0D AE D7 B7 9F 1C B5 12 6D 57 AE 97 C3 CA 2E 1E 31 00 00 00 05 C2 83 6C 1F 58 95 45 A1 7B D1 7F F2 31 E5 F8 6C B7 55 A3 6E 4F 2A 3B A1 08 AC A2 7E
>> [16:28:14:130] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
RX:7E A0 5F 05 03 B8 4A 68 E6 E7 00 DD 08 01 02 03 04 05 06 07 08 08 48 58 45 03 31 65 E2 7C 08 48 45 43 00 05 00 00 01 00 00 01 01 00 18 04 01 F9 73 06 DE D7 83 C2 59 0E B4 6A 55 15 6F 9F 94 A4 60 CB F1 B4 C0 18 31 00 00 00 00 50 B3 A7 D9 DF B7 C2 76 25 C7 31 F1 1C 0F A5 04 BE B6 01 22 47 7E
>> [16:28:14:146] [Information]
Read success. Clock {8, 0-0:1.0.0.255, 3}
>> [16:28:14:161] [Information]
Reading...
Clock {8, 0-0:1.0.0.255, 8}
>> [16:28:14:161] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
TX:7E A0 65 03 05 BA 0D 59 E6 E6 00 DD 08 01 02 03 04 05 06 07 08 08 48 45 43 00 05 00 00 01 08 48 58 45 03 31 65 E2 7C 00 00 01 01 00 18 D8 2F 3C 51 57 93 2A FA CC 62 B7 4F AB 24 44 46 53 86 C3 8D 43 98 26 08 1E 31 00 00 00 06 88 DA 01 94 C1 DE FD 6D 55 3C BA 95 C6 85 FA 65 1B B0 96 7E 93 0B 91 88 C1 E2 AD 7E
>> [16:28:14:646] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
RX:7E A0 5E 05 03 DA E5 34 E6 E7 00 DD 08 01 02 03 04 05 06 07 08 08 48 58 45 03 31 65 E2 7C 08 48 45 43 00 05 00 00 01 00 00 01 01 00 18 01 49 65 00 C2 6F 88 33 2B 2D 58 DB DE 2E BD EE 1C 1F 84 ED E2 E8 B2 16 17 31 00 00 00 00 DE 17 90 4B 65 CD 90 DC 2A CA F1 05 24 34 BB 1A D0 FF 1F 2E 7E
>> [16:28:14:661] [Information]
Read success. Clock {8, 0-0:1.0.0.255, 8}
>> [16:28:14:677] [Information]
Disconnecting...
>> [16:28:14:677] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
TX:7E A0 3F 03 05 DC 85 56 E6 E6 00 62 31 80 01 00 BE 2C 04 2A DB 08 48 45 43 00 05 00 00 01 1F 31 00 00 00 07 7D CE 75 C3 C0 30 DA 54 1E 80 14 DD FD 45 24 6D F9 34 00 53 43 C8 C5 CB BE A0 62 97 7E
>> [16:28:15:083] [COM3] [Device(COM3)] [HDLC] [I] [Debug]
RX:7E A0 3F 05 03 FC 8E F5 E6 E7 00 63 31 80 01 00 BE 2C 04 2A DB 08 48 58 45 03 31 65 E2 7C 1F 31 00 00 00 07 0E 74 69 BA BC BE 75 F9 89 12 5B 49 96 F8 12 36 41 10 63 07 96 9C B3 CA 7F 45 16 92 7E
>> [16:28:15:099] [COM3] [Device(COM3)] [HDLC] [DISC] [Debug]
TX:7E A0 07 03 05 53 50 83 7E
>> [16:28:15:318] [COM3] [Device(COM3)] [HDLC] [UA] [Debug]
RX:7E A0 07 05 03 73 5B 20 7E
>> [16:28:15:443] [Information]
Disconnect success!
Hi, I don't know what…
I don't know what application you are using to read the meter so I don't know where keys are saved. You can't read the keys from the meter. The keys usually come with the meter as a separate document. You need to ask this from the meter vendor.
