  3. Establishing Secure Premier300 Meter Connectivity With DLMSdirector
Establishing Secure Premier300 Meter connectivity with DLMSdirector
Profile picture for user rooftopurja
By rooftopurja , 10 September, 2024
Unable to establish connection between Premier 300 meter with DLMSdirector application. RJ11 to DB9 pinout is as below and DB9 to USB converter cable(bafo make) connected to laptop
RJ11 DB9-RS232
pin 1 - pin3
pin2 - pin2
pin3 - pin5
pin4 - pin7 and 8 (shorted)
in the DLMS application software - choosing secure meters ltd, interface - HDLC, client address 17, authentication low - password: ABCD0001, address type: default, logical server 0, physical server 1, media - serial. Still unable to establish connection. Can anybody help?
2 years 1 month ago
Hi, Check the wiring if you…
Check the wiring if you are not receiving any reply from the meter.
Check also the baudrate.
