  2. How To Get Code To Convert Response Raw Data To String Using Dlms C# Library
How to get code to convert response raw data to string using dlms c# library
By jayaram , 8 July, 2024
i am trying to connect to smart meter through Medial type serial and i got the response properly
here is my code
public class Test
static GXDLMSClient client = new GXDLMSClient();
public static IGXMedia Media = null;
public static TraceLevel Trace = TraceLevel.Info;
public static void Main()
GXSerial serial = new GXSerial();
serial.PortName = "COM3";
serial.BaudRate = 9600;
serial.Parity = Parity.None;
serial.StopBits = StopBits.One;
// Is used Logican Name or Short Name referencing.
client.UseLogicalNameReferencing = true;
// Is used HDLC or COSEM transport layers for IPv4 networks (IEC 62056-47)
client.InterfaceType = InterfaceType.HDLC;
client.ClientAddress = 32;
client.ServerAddress = 1;
client.Authentication = Authentication.Low;
client.Password = ASCIIEncoding.ASCII.GetBytes("1111111111111111");
Media = serial as IGXMedia;
Media.Open();
byte[] data;
data = client.SNRMRequest();
if (data != null)
ReadDLMSPacket(data, reply);
//Has server accepted client.
client.ParseUAResponse(reply.Data);
//Generate AARQ request.
//Split requests to multiple packets if needed.
//If password is used all data might not fit to one packet.
foreach (byte[] it in client.AARQRequest())
reply.Clear();
reply = ReadDLMSPacket(it, reply);
//Parse reply.
client.ParseAAREResponse(reply.Data);
Console.WriteLine("Conformance: " + client.NegotiatedConformance);
Console.WriteLine(client.ConnectionState);
byte[][] obj = client.Read("0.0.96.1.0.255", ObjectType.Data,2);
reply = new GXReplyData();
ReadDataBlock(obj, reply);
in the above code last line ReadDataBlock(obj, reply); reply.value contains response that is in readable format only
but i need a logic how raw data of response is converting to readable string
i debug the gurux.dlms class library
[Obsolete("Use Read")]
public byte[][] Read(object name, ObjectType objectType, int attributeOrdinal)
return Read(name, objectType, attributeOrdinal, null, 0);
private byte[][] Read(object name, ObjectType objectType, int attributeOrdinal, GXByteBuffer data, int mode)
if (attributeOrdinal < 0)
throw new ArgumentException("Invalid parameter");
Settings.ResetBlockIndex();
GXByteBuffer gXByteBuffer = new GXByteBuffer();
if (UseLogicalNameReferencing)
gXByteBuffer.SetUInt16((ushort)objectType);
gXByteBuffer.Set(GXCommon.LogicalNameToBytes((string)name));
gXByteBuffer.SetUInt8((byte)attributeOrdinal);
if (data == null || data.Size == 0)
gXByteBuffer.SetUInt8(0);
else
gXByteBuffer.SetUInt8(1);
return GXDLMS.GetLnMessages(new GXDLMSLNParameters(Settings, 0u, Command.GetRequest, 1, gXByteBuffer, data, byte.MaxValue, Command.None)
AccessMode = mode
above read method is returning the expected result
but i need to check GXDLMS.GetLnMessages method logic but i am unable see the source code
jayaram
2 years ago
image changed
gurux.dlms GXDLMSClient class screen shot
2 years ago
Hi, Use this code instead of…
Use this code instead of. It will update the received bytes to the correct format.
GXDLMSData obj = new GXDLMSData("0.0.96.1.0.255");
ReadDLMSPacket(Read(obj, 2), reply);
client.UpdateValue(obj, 2, reply.Value);
