  3. Logs Not Showing In Gurux
Logs not showing in Gurux
By ManishChoubisa , 18 June, 2024
I was implementing the TCP server in NBIOT module. To test the TCP server i was trying to send a wrapper frame from gurux to module and after receiving this whatever received i am sending back to grurux via tcp connection.
But what i saw that the wrapper frame sent by the module is reaching at port( As per wireshark logs ) but the frame is not showing in the gurux logs window.
I want you support on this issue that
1. Is valid frames can shows in the gurux logs? because i am sable to see the data frame at wireshark.
2 years 4 months ago
Hi, GXDLMSDirector doesn't…
GXDLMSDirector doesn't show ignored frames in the log.
The received frame is ignored because your client and server addresses don't match.
