  2. Set Value In The DLMS Object
Set Value in the DLMS object
By Bhaumik , 7 June, 2024
I have successfully read the value from the meter using your library. I retrieved the clock object and its Time attribute value, then converted the response into an Epoch value.
Now, I need to convert the Epoch value to the actual time using the client.updateValue function.
Can you guide me on how to correctly set this value into the DLMS object?
2 years 1 month ago
Hi, Do you want to write a…
Do you want to write a new time for the meter, or do you want to show the time in UI? What programming language are you using?
Bhaumik
2 years 1 month ago
Hi Mikko, I do not want to…
I do not want to write into the meter.
I want to show time in UI.
I am using C# programming language.
2 years 1 month ago
Hi, You can skip the Epoch…
You can skip the Epoch and use ToString() to show the date and time.
