  3. Segmentation_and_get Response_with_blocks
segmentation_and_get response_with_blocks
By Giulia2 , 30 May, 2024
Hi ,
thanks in advance for your help and attention.
I am trying to read from a meter a load profile with authentication and encryption. The content of load profile is huge so that we receive from meter a get response with blocks and each block is segmented at lower level HDLC.
We came across a problem with first block. We can receive from the meter all frames belonging to first block. As you know the different frames of first block are collected in the object GXReplaydata and so in an instance of GXByteBuffer.
Our first block is bytearray of size 4087. When the method “set” of GXByteBuffer is called we get the error “byte must be in range(0, 256)”.
What we can see by debugging is that method “set” call method “setPosition” and when we try to access to position 4087 of GXbyteBuffer istance it fail with the error written above.
I do not understand why it happens only in this case.
We have no problem in this following cases:
1.segmentation with encrypted and authenticated communication
2. segmentation and get response with block without encryption and authentication
Can you help me?
To run gurux libraries we are using python 3.12
thanks
2 years 5 months ago
Hi, Try this first with…
Try this first with GXDLMSDirector. Can you read the old profile with that? Our customers are reading much bigger blocks than 4087 bytes so this might also be the meter issue. I need the communication log, block cipher, and authentication keys to verify this.
Giulia2
Hi Mikko, thanks so much for…
thanks so much for gettig me back so soon.
We tried with Director but we had no problem.
Attached there is a file with all information you need.
I divided file in four parts. The latter point( point 4) is where we get buffer.
Library
gurux_dlms' version: 1.0.152
'gurux_net' version: 1.0.20
'gurux_serial' version: 1.0.20
Keys
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
1.AARQ by public client
TX: 16:01:40 06 32 35 32 0D 0A
TX: 16:01:41 7E A0 08 44 D1 21 93 1C 00 7E
RX: 16:01:41 7E A0 1F 21 44 D1 73 F1 58 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 16:01:41 7E A0 2C 44 D1 21 10 0E FB E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
RX: 16:01:41 7E A0 38 21 44 D1 30 23 78 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 10 00 00 07 CB 10 7E
2.get invocation counter by public client
TX: 16:01:41 7E A0 1A 44 D1 21 32 57 16 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E
RX: 16:01:42 7E A0 16 21 44 D1 52 1E 39 E6 E7 00 C4 01 C1 00 06 00 00 09 5F 17 65 7E
Invocation counter value: Data (DATA_NAME, value): 2399
3.AARQ + authentication by management client
TX: 16:02:44 06 32 35 32 0D 0A
TX: 16:02:45 7E A0 08 44 D1 03 93 9F 10 7E
RX: 16:02:45 7E A0 1F 03 44 D1 73 D4 EE 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 16:02:45 7E A0 6C 44 D1 03 10 AF 2A E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 61 BC A0 C1 5B 4F 08 43 2A 2F 83 C5 B9 50 B0 DF BE 23 04 21 21 1F 30 00 00 09 60 60 C6 20 CD 33 1C D6 14 7F 11 C2 14 7E 2B 8E 33 56 67 9F 9E E4 0E 5A 8A 75 88 D5 58 7E
RX: 16:02:46 7E A0 78 03 44 D1 30 24 0F E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 41 42 43 44 45 46 47 48 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 28 1F 30 00 00 09 E6 48 59 7A 76 8E 23 63 E4 E8 20 FB 25 85 4E BC 2E D2 A6 7B AF 81 C1 B2 36 BD 10 22 33 7E
TX: 16:02:46 7E A0 40 44 D1 03 32 1E 3F E6 E6 00 CB 31 30 00 00 09 61 CC 93 B2 38 0E B7 76 F7 A2 11 C9 29 CD 3D 7B 5B A5 61 DA 8B 67 89 A5 03 6E 63 22 ED F5 7A 05 3B EC F7 34 8E 66 0D 27 B8 89 0F 50 2D E5 0B 7E
RX: 16:02:46 7E A0 3A 03 44 D1 52 9A 98 E6 E7 00 CF 2B 30 00 00 09 E9 91 CD 7C B7 EA 8A 3C 65 A0 A1 07 77 4F 47 EA B8 28 CC 68 F9 22 57 BB 2C 2D 23 89 ED 57 C1 A9 5A 8F FB 7A FF 21 FF E8 BA 7E
3. Reading Load profile with period 1 by management client( profile_entries and capture object list)
TX: 16:02:46 7E A0 2D 44 D1 03 54 E9 E4 E6 E6 00 C8 1E 30 00 00 09 62 74 C3 CB 0C 59 F7 7B 07 82 60 29 F9 12 B5 DF 95 50 C7 9C 9D C3 BE A0 1C 53 B0 F0 7E
RX: 16:02:46 7E A8 87 03 44 D1 74 06 DF E6 E7 00 CC 81 CB 30 00 00 09 EA C8 C5 83 BC C2 4B 41 45 40 BE 08 99 A8 81 01 68 C9 25 26 90 D2 74 67 46 A5 C0 6A 04 EB DD A5 EA 7E 1F 43 5D FE 2D EF 43 D8 89 3F A0 E0 8B B8 A5 3B 90 A5 73 95 3C 09 C0 F0 3D B7 BC C1 EC 18 BB 72 F6 1C 9E 72 D2 72 30 53 ED 03 9E 87 99 E7 BA A6 2C 3B 5A 38 50 34 35 00 1B 10 38 E0 CC C8 2B 2A B5 A6 31 A3 30 11 4A 54 C7 1E AB 8E D7 FF 56 E2 CE DA 1B 7E
TX: 16:02:46 7E A0 08 44 D1 03 71 83 D4 7E
RX: 16:02:46 7E A0 5E 03 44 D1 76 1F 73 74 1E FA 5C 43 F4 2E A8 35 DD 13 F3 35 56 FE D2 83 C6 29 20 9D 9C 73 12 3A 19 A9 14 1B 06 B7 CE D5 3E E4 2F 27 60 1A 59 DA AE 9C 2B ED 2A 9A 5E 25 56 BC EF F2 07 8D 98 1D 6B 04 CB 21 6B A5 B1 73 19 3A E6 D3 17 EC 0B 57 B6 07 68 67 49 F3 83 73 AF AA 8E 76 4C 7E
TX: 16:02:46 7E A0 2D 44 D1 03 96 F7 01 E6 E6 00 C8 1E 30 00 00 09 63 7A 02 57 1E 00 F1 E8 0D 9E CA 48 0D 30 3D 70 64 8A 33 5F 8D 1D 22 45 1A 39 03 E4 7E
RX: 16:02:47 7E A0 29 03 44 D1 98 40 58 E6 E7 00 CC 1A 30 00 00 09 EB 56 C6 37 62 D7 89 10 C6 EF 08 11 F1 36 91 28 29 50 76 94 0B EC 09 45 7E
4. Reading Load profile with period 1 buffer by management client
TX: 16:02:47 7E A0 2D 44 D1 03 B8 8B C9 E6 E6 00 C8 1E 30 00 00 09 64 D4 30 D1 A3 4F 04 50 33 6E 25 77 C7 F2 C7 F9 B4 07 C2 8B C8 5C 0D E1 4E BA B5 02 7E
RX: 16:02:47 7E A8 87 03 44 D1 BA 74 F0 E6 E7 00 CC 82 0F F3 30 00 00 09 EC 73 07 43 1E 44 93 16 82 CA 87 78 60 B4 4F 1D 18 1E 7F DA 12 CA F1 B7 0F 87 89 A1 31 1A D1 EF E8 A8 60 70 6A 3B C9 AF CB B0 EF E1 0F 58 6A 50 13 7E BE DC 92 A6 53 8F 13 97 1A FD D4 07 67 49 6B 5F 2F 59 04 B2 46 6E C0 24 34 A0 BE A9 3B 30 85 7B 05 76 34 4B A4 40 A2 5B D8 31 90 1D 4C A8 E1 BC 79 C5 FE 1F 58 13 F0 B7 42 72 D5 52 AB D0 70 31 10 D6 7E
TX: 16:02:47 7E A0 08 44 D1 03 D1 89 71 7E
RX: 16:02:47 7E A8 87 03 44 D1 BC 42 95 13 8A 1C AB 84 EA 24 D1 42 95 3D 32 70 84 62 A2 03 80 04 E7 EA 6F AB EB C4 10 11 14 98 3F 17 27 96 3E CD 1E 9C 16 CF B6 6F AB D5 BD 7E AC 62 17 A8 77 65 0B CE 3C 47 F0 D4 D7 F4 08 23 8F 3A 80 9D DA AD 26 BE 0D 52 A2 51 68 57 E3 E0 97 25 23 8B 9C 81 D8 DE A8 3C EE 37 55 2E 56 2E 48 08 78 A4 29 06 3A 45 26 B1 56 2D 0C 64 EB 0C 34 0B F8 8A AF B6 86 4E A0 52 44 D5 9F D4 97 F6 BB 7B 7E
TX: 16:02:47 7E A0 08 44 D1 03 F1 8B 50 7E
RX: 16:02:48 7E A8 87 03 44 D1 BE 50 B6 F5 3D 0B 79 90 63 1F 6E 22 64 05 75 DF 1C D6 E8 E4 69 19 F0 E6 8A EE A9 47 D6 0D 3F 47 97 7A DB 95 C9 E2 94 29 E5 DE 8B AF CC BD 8B 39 14 FC B5 F3 1A 02 57 14 E6 BD FA 1A 95 F6 D5 99 67 5D 8E AC 66 62 87 B8 B8 3B F0 31 3F A9 5E A8 83 18 72 30 85 D1 4C 89 DC AC 48 8C D7 5F 5B 90 18 4C 3F 6A 89 63 CE AD 18 B0 DA 89 D0 B9 8B 46 F4 00 0D 2F 0E 81 E6 2E D5 B8 EB E0 11 08 A0 4F 4E 71 7E
TX: 16:02:48 7E A0 08 44 D1 03 11 85 B7 7E
RX: 16:02:48 7E A8 87 03 44 D1 B0 2E 5F DD 9C 44 95 E8 2E 24 4B 7E 5C AC B4 9E 37 0E B5 AA EE 61 DF A2 D7 71 CE 76 E8 9F 70 6F F0 D7 BE B7 68 07 DA 39 E3 C3 0E 9A 74 01 2C 70 44 88 F2 1A 04 BB F8 79 40 AF 22 F6 F3 67 82 15 D9 7E 1B 1F 0D F8 FF 5B 8F 42 F2 D1 14 0C 00 D5 7C F9 73 DE 7B 01 E6 1E F8 38 66 B5 7B EC 89 37 DC A3 B0 E8 1F 85 43 99 BC 31 A7 32 55 C9 59 5E 34 F3 48 E5 D0 BF 19 C5 2D A9 F6 B1 21 E1 64 5D 9A B5 7E
TX: 16:02:48 7E A0 08 44 D1 03 31 87 96 7E
RX: 16:02:48 7E A8 87 03 44 D1 B2 3C 7C E9 F9 C1 FD B5 C7 A5 E0 D3 93 AF 2B 1F 30 8F 58 A3 C5 6D 4D AE 1B AF 76 9D 44 3F 9F DB C6 2E E8 DB 41 41 7E 3C 8E 24 B1 0D 76 E7 7A 6D EA 0D FA 4F 64 86 80 E3 BC 61 91 C3 00 66 8B 8E 88 6F E8 DA 3E 46 FB 33 43 A4 FD 65 F9 35 B9 E9 56 65 FF 70 DD 19 7F 48 0A D8 CF 7A 5E B0 4C 16 B1 36 D4 F2 14 84 06 58 55 88 0E D0 AD 52 91 8D 20 BA F4 1E C1 2D 18 A3 C9 11 AA 9A E3 0A 26 BB 85 0E 7E
TX: 16:02:48 7E A0 08 44 D1 03 51 81 F5 7E
RX: 16:02:48 7E A8 87 03 44 D1 B4 0A 19 4A 28 B7 19 11 EE 15 48 7F BF 2E 87 69 C7 0F B0 3B 49 22 67 DB 6C 0F 3A DE 95 E6 0F 39 7A 32 B1 5D 92 27 F9 48 40 4C 2D 7D 0F 32 A2 91 C7 92 98 69 3E 73 B9 5E A8 FB 7A 64 FA 17 91 B8 3D 88 E7 F6 B8 25 0D 17 FA 45 12 4D B8 2C 60 20 7C 86 53 D5 2F D0 87 70 4C 55 35 B0 8A FB 2A 93 51 60 AF F5 59 E7 F5 59 A6 78 17 6A E4 6F 7E A9 CA 65 0A B1 A9 15 58 AB 68 3F 8B 09 86 A2 70 E4 51 5F 7E
TX: 16:02:48 7E A0 08 44 D1 03 71 83 D4 7E
RX: 16:02:48 7E A8 87 03 44 D1 B6 18 3A DA 36 6C 6A C7 3C F7 12 9A 79 E5 6E F7 8C 05 66 ED 89 59 50 38 A9 54 1D 03 B5 7D 4E B4 5C 1C 4E 2A CC 6B B1 20 97 05 92 61 EC 6A EE 19 3E 54 66 5F 58 7A B4 84 E8 DD 26 E4 23 C7 CA 07 6B 17 3D B5 E1 3F 8D 81 22 31 AA 65 D7 43 64 AD 4D 23 E8 60 5F 9E 1C 12 CF 1C 85 56 51 CC 0B ED FF 0A F3 BE 8D 5C FE 9F C1 D7 CF 3F 84 CB 23 62 A2 D9 9E D6 7B 91 E9 9F BB EB 69 03 FF AE 61 72 36 42 7E
TX: 16:02:48 7E A0 08 44 D1 03 91 8D 33 7E
RX: 16:02:49 7E A8 87 03 44 D1 B8 66 D3 D0 C6 1F D2 A9 6D 3F 43 9F 41 C8 5C 20 F4 B1 E7 58 68 AB 5B 9D D6 10 2C B9 56 CA CE 52 90 3C E2 E6 BF CC A5 01 29 39 7B 41 F3 97 72 91 14 E3 84 AC 8D A4 8E 6E AB 38 06 6F 9F 79 C6 FC D2 CD 87 5C 0B 34 CE 2D 2A 60 88 E9 89 06 12 DB AB B7 9A 65 E6 CD 2E 8C D0 B3 AF C4 50 0D 92 A2 DE 18 F3 B9 3B 59 8E 09 65 41 99 4D 27 5E 2E 39 27 D2 D0 32 49 82 8A E3 AD B0 73 AD 59 94 91 AA 52 C6 7E
TX: 16:02:49 7E A0 08 44 D1 03 B1 8F 12 7E
RX: 16:02:49 7E A8 87 03 44 D1 BA 74 F0 60 A2 3C 56 FF 6B 4C 8D 8F 1A E9 F3 6F 44 CC 23 C2 6A 7B 51 01 20 B0 77 FC 41 73 53 1D 8E 1D F2 CD A2 92 F3 D6 4B 39 89 CF B3 62 5A AD 91 42 00 03 60 5E A7 74 34 0E B0 68 25 02 FC 76 0E 77 8E 5B 04 82 34 92 9C 28 42 15 D1 9D 31 61 F1 16 FA 18 6F 44 31 C3 41 FE 10 30 98 73 DF DD DC 70 39 AA 9F 02 2F 3D 4A 70 07 EB F0 53 8C 0D 65 49 CE BC 4D 35 2C 68 09 D0 17 91 B7 1A 68 55 B5 BC 7E
TX: 16:02:49 7E A0 08 44 D1 03 D1 89 71 7E
RX: 16:02:49 7E A8 87 03 44 D1 BC 42 95 75 36 5F 94 FA 3A 75 53 8B C9 ED 66 F8 3D 5F 34 ED E6 BC 56 CF 29 5D 35 1B 61 6F C1 75 39 B7 5C CF AF 2F 7A 5F FA 09 05 C5 90 69 6A 04 46 2E 62 73 5A 85 1E 44 2E F5 83 AE ED 63 05 DB AB 7B CF 7E 5C 03 02 42 BB 61 85 03 49 29 B1 10 D1 6C 23 C3 FD 13 E7 B9 04 83 11 61 8F 55 0F A0 E1 B7 4A 9E F0 78 30 6C ED 6D CF 96 E1 E8 4C 33 12 AB B9 26 CB 3C 72 08 4C 21 5D 7B 8A 05 F5 F4 E1 47 7E
TX: 16:02:49 7E A0 08 44 D1 03 F1 8B 50 7E
RX: 16:02:49 7E A8 87 03 44 D1 BE 50 B6 D3 34 19 DB D6 1F 11 D7 3F 91 93 F6 05 B0 DE 49 21 22 9F 49 B7 51 C6 E1 2C 3C 88 93 E4 47 43 1F 7C 70 11 89 A2 41 D8 F1 BD AD 4C 18 07 AE 30 53 2F 3C 17 4A E2 B6 9C 5B 34 99 4D 45 04 AA E6 95 3A C5 ED 0F 02 2E 39 03 98 6C 25 FE 27 D7 63 36 B3 64 F4 A1 9F D4 6A B3 49 FA A1 3A 17 D8 ED C7 CB 68 AF 64 47 4B DF 77 98 F8 47 61 27 57 35 A7 C0 92 BE 43 2F CF E8 A0 EE 80 EE 97 DF B2 D0 7E
TX: 16:02:49 7E A0 08 44 D1 03 11 85 B7 7E
RX: 16:02:49 7E A8 87 03 44 D1 B0 2E 5F 46 20 32 E6 C3 54 A2 51 14 2F 73 4D A5 74 02 04 E8 00 44 7E E9 06 E0 61 37 6A 4D EF 80 4B D6 93 45 3B 2A E9 C6 07 7B 23 D7 A1 B4 6C 38 BB C4 0B B8 91 EF 46 82 7F FD 0D 53 2E C5 94 0D A0 18 A0 5B 35 BD C4 75 8C EC 95 05 66 47 27 D0 71 4C DC D3 73 CB 67 F4 40 56 C9 39 05 B3 D9 F2 40 6D AB D3 69 39 7A 2C 68 B7 5F F5 B0 75 62 41 99 BB BA B6 47 5D FC F3 90 FA D5 B0 E4 66 D2 E7 80 CB 7E
TX: 16:02:49 7E A0 08 44 D1 03 31 87 96 7E
RX: 16:02:50 7E A8 87 03 44 D1 B2 3C 7C 15 FD E9 AB 29 AE 51 CB 1F 85 A6 21 7A 98 3D 44 03 C3 F6 BC EB EB F8 CE 58 5B 90 57 E5 9D C1 9A 20 FB A6 9E AA 50 4A 80 A2 4F CE 49 79 0D D7 4E E2 32 61 5F 71 A2 3B 73 7E 7F DE 6D 88 FE F8 49 9E E0 98 9E AE 68 26 1C F6 FC 99 EE 88 0F CD 01 DA 0F 21 FA 03 C3 0E F2 22 A0 4A D4 71 10 C1 EC 52 FF BE 35 A3 C4 20 E3 58 DB 20 BD B4 84 78 39 3F FC C9 BC 1C 6A AD E0 69 8F A1 37 14 5C 6E 7E
TX: 16:02:50 7E A0 08 44 D1 03 51 81 F5 7E
RX: 16:02:50 7E A8 87 03 44 D1 B4 0A 19 5B ED A3 1C EC DC E3 CA CC 75 08 88 E6 A1 E0 91 CF 9D D7 56 EE F9 5E 0E C1 1C B1 03 1F 8A 7E A1 DE 8B 2F 94 74 66 8D CA EC D3 BF 45 DF 6E CA E9 71 CA AA 77 7D B7 0F 56 D0 D2 2E 97 54 26 42 93 AA DE 8E 85 D0 FD AF B7 44 E7 A1 AC E8 51 EC C0 5D 19 82 92 7B A7 74 B3 2A E9 B9 92 FB 27 F0 A7 AD A9 E9 5C 86 D2 A9 59 66 90 79 A2 43 21 B1 EF D0 96 FB F9 D0 0D BB BE 0A FC 7D EF 17 86 65 7E
TX: 16:02:50 7E A0 08 44 D1 03 71 83 D4 7E
RX: 16:02:50 7E A8 87 03 44 D1 B6 18 3A 68 F9 35 59 C6 ED 00 1F 17 FA BE 97 C4 E0 F2 3E EC F2 92 46 BC 9F 17 D5 85 6F 13 54 7A 34 51 CE 24 F1 E0 17 42 31 FA 7C BD CB 7A 3E 3A 13 41 DB 61 F7 3A C2 73 FC AA FB BF D2 F3 85 C2 90 21 C4 3A 37 42 D7 1C 9A 8A FF 45 C6 A1 9D 8E 8D 0D FD 16 A4 09 7D B2 6B 47 73 B7 CE 5C 31 B4 B7 CB 5D 16 8F 49 0E 68 9B 6B 6D A6 D2 EB F6 6B 46 3E 1E 94 C9 70 4A B8 2D F9 9E 80 C4 BD 44 9B 83 6F 7E
TX: 16:02:50 7E A0 08 44 D1 03 91 8D 33 7E
RX: 16:02:50 7E A8 87 03 44 D1 B8 66 D3 7B 27 85 29 15 F2 AF EE 9A 97 B3 40 3D 33 8F 8A 06 9B A8 6C 18 FB 5A 73 D1 AD 1C 34 16 7C 00 EF CE 85 2A 68 74 4D 9C B1 F7 09 D0 8A A7 C1 8E 0D 00 50 D5 64 07 33 8B A2 38 95 CC CC EA E1 59 AF C5 D6 10 C3 19 54 73 06 EB 35 E6 80 0E 81 A3 E5 D2 1F 80 E9 9B A5 58 8C B0 77 50 C8 5D F4 A3 69 2A 66 4E 47 60 6A 1D 6B 2A E5 08 6C 25 87 12 58 2E 34 6A D7 1D 2B 2F E3 20 B2 FC FF 0F 0B B3 7E
TX: 16:02:50 7E A0 08 44 D1 03 B1 8F 12 7E
RX: 16:02:50 7E A8 87 03 44 D1 BA 74 F0 BC F7 68 DC 6F 6A 45 E8 5A 9B C9 44 76 13 76 7D 55 AC EA 7E C9 66 A7 1A E7 CC 95 35 DF 96 06 EE 66 72 62 84 59 04 6C 0C F4 A4 82 37 33 05 FD 09 D9 DF 53 43 E9 5E E4 10 73 6B CF A6 30 DC B9 4D EB 88 72 11 B5 56 0C 9B 01 AF 0B BA EC 0B 30 4A 96 3E 04 AD D8 33 E5 3B A6 2C 68 6D E3 3F 11 FF ED E6 85 B6 B8 4B 34 D9 4E 8F 66 BE CB B0 48 24 ED 59 0D 50 0E 1F 44 8C F3 62 67 87 A0 02 CE 7E
TX: 16:02:50 7E A0 08 44 D1 03 D1 89 71 7E
RX: 16:02:51 7E A8 87 03 44 D1 BC 42 95 4C DE BE A7 B6 A7 4B 22 F3 9E C8 B6 3F 9B 85 A1 64 59 75 EE DD E7 10 11 02 76 79 B4 D0 59 82 4F 8B B4 46 18 C6 DF 27 39 BA CE 3C 2C 73 E1 78 F2 17 00 15 29 92 6F 57 28 A5 49 D0 E9 56 D9 07 52 5D 7B DD A7 D9 8B 54 BC 7A 78 A9 E8 9C 7D 9C 80 43 E9 77 8B F0 84 3F D4 6D 6E 3C 0C A0 AC 75 C3 69 ED 34 30 27 8A 45 F6 3E 2A 36 A6 37 47 7E 5A 5E 81 8B 65 EF 74 12 BB 07 C7 06 7E 3E 28 F3 7E
TX: 16:02:51 7E A0 08 44 D1 03 F1 8B 50 7E
RX: 16:02:51 7E A8 87 03 44 D1 BE 50 B6 13 AC DE FF C0 E0 96 DA 86 35 17 C5 47 BA 0B EE 4E 94 36 D2 19 E7 B7 C4 41 94 E1 D9 7A D6 99 C1 47 30 19 6C 07 13 D3 B9 10 96 76 99 A8 7B EE 99 A8 51 5A AF 4F 79 64 C4 76 AD A9 AF 47 58 74 BF D1 E2 DD 1C 70 F7 3D 58 1F AE 1B 4A D3 B1 B1 66 AA 82 7C BB EA 58 70 7C 93 A1 2D 63 39 5A B8 38 87 BA 59 A6 05 BE 96 68 B8 84 4E C9 96 56 66 70 C4 D6 43 E1 D4 87 D5 09 55 63 98 4A 83 BE 1B 7E
TX: 16:02:51 7E A0 08 44 D1 03 11 85 B7 7E
RX: 16:02:51 7E A8 87 03 44 D1 B0 2E 5F 1B E7 0F C0 BD D7 18 F0 50 F7 EF 48 F0 E0 25 22 F5 F4 8C D2 16 3C 11 9A D9 42 EF A3 C5 96 7A 06 9D 0D F0 A5 02 82 B9 DE C3 68 88 B5 8B DD AD A4 5B 9B F5 D7 06 B2 C1 0B 8A 98 14 53 2C 10 B3 08 2E 10 0E F1 01 B5 D6 F1 5B 0F F4 52 1B 29 49 F2 28 E5 8D 1A 88 B7 11 36 5F CD 2A E2 9D B4 02 1C D0 67 F3 49 ED 9E 94 FF CA 7D F1 47 49 00 72 74 E2 90 82 9C B4 CB B4 A9 B4 FD 25 1B 29 51 12 7E
TX: 16:02:51 7E A0 08 44 D1 03 31 87 96 7E
RX: 16:02:51 7E A8 87 03 44 D1 B2 3C 7C 9C 10 AB 0E A8 5A B4 58 E5 2D 03 82 9F 26 CC F7 41 CA 9A B4 97 0A 01 58 0A 95 D3 01 D5 C8 F0 CB 5D CB 5D B6 EE 12 24 BB B3 BE C4 4F A7 14 B3 7B DE DC C9 9F 97 E7 1E 9B 7C 5B 95 DE 07 B1 FD F1 8A D2 3B 1E 54 CE 0D DE C4 6C 86 83 9A 16 66 C4 95 FC 41 5D 2F 9E 50 5C 61 EC 7D 1D 0F C1 61 8C 9C 2F 8F D8 8C F8 B7 9F 1C 8A 43 67 0F 97 2B 5A 90 86 4C 07 1B BD EB 73 FA A9 F4 5B B8 2E 24 7E
TX: 16:02:51 7E A0 08 44 D1 03 51 81 F5 7E
RX: 16:02:51 7E A8 87 03 44 D1 B4 0A 19 BD 76 6E 5D D3 42 C6 E3 65 50 36 DE A9 A5 C4 30 C7 33 61 A2 62 D6 D5 4A C2 CE 72 5C E5 20 0B CF C9 B5 C5 9C FE 2C 34 70 CB 25 1F 48 37 08 6F A0 DB 72 31 A8 9E A6 14 45 0E 41 F0 87 7A CC DF 5F 31 7D 94 63 BD 3C 04 BC FE 1B 78 08 65 D0 10 10 0C 10 1B F4 7D D8 5D E4 F2 A2 91 71 7E E9 B4 5A AB 10 D7 B6 F4 E3 89 EB 89 AF 9B 4E 5C 00 A5 2D F8 22 46 B9 C7 67 BE 35 ED 0C 79 5C CA B2 15 7E
TX: 16:02:51 7E A0 08 44 D1 03 71 83 D4 7E
RX: 16:02:52 7E A8 87 03 44 D1 B6 18 3A 8A 38 03 1D 98 C6 56 52 1F B5 35 1B 06 29 66 A7 EF EC 74 6F 6A 27 B7 AB 3A D5 5F 0A 0D 6E E2 31 4B 1C 6F 03 16 AE 29 8D 92 52 19 7E A6 63 3D 0F FE B7 D6 C7 48 F0 63 72 2E 04 51 13 C0 8D BD 84 E6 84 15 E5 8D DD A4 CB 43 D5 7D 36 72 69 81 B2 9E 92 7D 12 69 B3 CC 18 06 34 88 A4 BB 68 E0 D7 CA A6 FE 71 9E D8 7F 00 BC 17 60 67 1B 00 0B 5D 3B 8A 1F 15 60 74 51 4F 0F BE F1 36 23 F4 68 7E
TX: 16:02:52 7E A0 08 44 D1 03 91 8D 33 7E
RX: 16:02:52 7E A8 87 03 44 D1 B8 66 D3 2F 38 0E F9 A1 E0 65 EA FD 66 F6 06 7F 7C 8D 4D E9 1F E4 82 2C 21 0A C6 BD 1A 41 84 81 F0 04 A0 A2 FF 9A 97 E4 29 FD 32 A0 49 AA 7D 0A 94 6C 0A 07 1D 6C FA AC 70 09 37 70 EB 36 37 EC EB F8 6E CB D4 30 39 2C 85 57 5C F9 96 DE 8C 60 7B D5 F9 DD A3 8A 87 3D 9D A8 BC 12 A4 B4 3A AA A6 BE 5B 05 7D 25 71 24 40 C5 6E 61 EA C7 3F E8 82 C1 59 F1 EB 5C D2 4F 8E 5B 0F 6B E4 C2 95 A3 2D 88 7E
TX: 16:02:52 7E A0 08 44 D1 03 B1 8F 12 7E
RX: 16:02:52 7E A8 87 03 44 D1 BA 74 F0 67 D6 18 35 10 46 69 72 86 52 8E 1A 38 F3 57 C0 3B 29 FF 94 24 43 3E 98 CB 23 A7 69 4C 7F 7E B7 6A 9D AC B9 93 CF 50 E3 0C B0 07 02 B0 EF 4D BF 6A FF EC 12 1D A8 B4 2C 9B ED CE 5F 6B 6A C8 3D C6 37 69 37 95 49 07 86 A8 0A 62 47 26 12 66 86 AA 9C E4 0F A9 81 C4 95 21 FE C9 A5 E8 22 84 79 BA 91 99 72 66 E7 EF 82 27 0D 90 4B BA B5 F5 DF 2C FE C8 BF 74 45 9E C4 2A 05 9A DB 9E 79 05 7E
TX: 16:02:52 7E A0 08 44 D1 03 D1 89 71 7E
RX: 16:02:52 7E A8 87 03 44 D1 BC 42 95 7C 36 CD B2 D2 36 62 40 1B DF 59 6A 1F 58 07 54 3A E9 97 53 5D 0A 94 FF 13 9E 4B 60 51 E4 E7 BB EE 3C CF 97 D1 DE 71 54 52 40 8D 44 C2 A3 76 91 96 DA B0 2C 9B D9 57 C3 74 C9 04 DD 54 6B 66 21 4C F6 D1 1A AA 0F F0 3E 16 0D 82 A1 00 FE D4 29 61 D4 A9 72 BD C8 5A 1E DC 5B 28 86 3C 46 2B A0 C6 B8 AC DD A2 BA 34 CF FC DE 1D EB FC 0F 11 70 53 7D B8 34 6D 25 6F D5 7E 3E 23 06 15 DC 71 7E
TX: 16:02:52 7E A0 08 44 D1 03 F1 8B 50 7E
RX: 16:02:52 7E A8 87 03 44 D1 BE 50 B6 AA AF 69 D2 8A 1C 16 C4 DB 54 8A 95 D0 83 21 61 BB 3D 38 95 1C 93 32 EC 70 D8 01 7B BE 9D 15 5E 9F B3 3B 15 73 04 25 DB 88 AB C8 E6 84 21 4C 10 10 F5 6C C5 0A F3 91 8D E0 30 B7 DB BC 1B 7C 35 83 BC F1 34 DF 5C AC 48 BE B5 92 BA BB A7 EC 11 56 CA 8A A1 A7 8A AD 8C 74 E8 CC 6A A7 25 21 79 F5 6C 4F 68 D6 E6 41 54 F5 CF E3 54 80 A0 92 40 31 20 89 F6 6F 80 D4 75 CD 20 DA C8 B6 31 FB 7E
TX: 16:02:52 7E A0 08 44 D1 03 11 85 B7 7E
RX: 16:02:53 7E A8 87 03 44 D1 B0 2E 5F 71 3C 08 49 B2 A4 A1 82 73 B4 B2 9A 44 50 1C F5 B7 80 52 D7 A5 02 CF FF 7C 15 F8 3D F8 E3 FF A7 93 26 E5 5A 42 E2 5D 32 00 5C 31 14 92 56 EC CF 23 93 58 1F 34 38 BE F3 4D 16 5A AB C1 21 40 80 FB 7E E8 DF 9B 2D 1D 0E 0F DE 22 BD EB 2B 02 98 39 0A 1B 40 4C CC 80 57 4D 3C DB 60 06 6A F8 DE 23 1A 7F 77 EE A9 87 13 81 4D 40 C8 D6 8A 7A 0C B6 88 19 81 F8 6A 78 7A 00 16 88 ED DB BE 06 7E
TX: 16:02:53 7E A0 08 44 D1 03 31 87 96 7E
RX: 16:02:53 7E A8 87 03 44 D1 B2 3C 7C C1 30 F9 0B D6 66 BE 1B D1 3C CA E6 BD 30 EA 1A 63 39 66 DA 9E BA 96 E5 E7 03 46 4E C1 27 A2 D2 A2 7D EF AB 4C 85 40 84 D3 72 05 29 E4 F7 A0 21 72 AC 85 46 A5 6B CC 9A C8 3D A3 81 A0 06 C9 1B D8 1F FF 1A 59 66 85 16 FD 50 34 A0 09 ED 38 23 FA F5 AE 63 AF DD D7 E1 09 A9 C2 5E 8D 31 9D 60 0E 90 59 8F AD 90 37 9D 74 EE 13 F7 B7 85 38 82 52 5F 4B AF A5 F6 EA D4 B7 A4 0F 18 32 F1 1E 7E
TX: 16:02:53 7E A0 08 44 D1 03 51 81 F5 7E
RX: 16:02:53 7E A8 87 03 44 D1 B4 0A 19 A0 A7 0F FD F4 C3 4C 9D 63 28 00 99 89 E0 AC C9 58 8B 9C B0 34 7F 39 82 A5 D1 02 69 A1 1E CE EF 22 55 95 E8 04 37 60 AA A7 83 6C 8F D3 F9 FC F8 1E 2F D4 66 21 99 5B 9D 22 EB B0 2E CB F5 36 AC E2 4E DA A0 EC FA 78 38 0A FE 82 E7 59 CC D0 4E B4 2F F6 7A AE 2F 2E 67 A0 06 0F D2 EC 79 99 2C FA 5B 7E D8 D6 59 2F A7 17 B5 4C EF ED B9 E0 EA F6 0A 3C AA 7D 6E 81 91 56 32 76 0D 6B 53 35 7E
TX: 16:02:53 7E A0 08 44 D1 03 71 83 D4 7E
RX: 16:02:53 7E A8 87 03 44 D1 B6 18 3A 16 86 BA 06 6C F9 29 09 F3 F2 ED E4 83 38 66 07 AE C2 85 DD CB 64 71 D9 5D 0F 7C 00 11 70 56 26 DB F2 74 AB 4F 11 61 2A 03 16 E8 F4 B9 24 83 DB 42 FD 7C 32 21 FA 5C F2 2E 77 68 40 48 81 AA C5 84 DC 00 2B A0 D9 58 5F 43 90 C5 A4 CF 5E 23 33 7C 49 B8 C3 12 FA D9 8D 6D 9B 7B 35 B4 80 A9 4A CB F8 0D CA FE D0 FF E3 BE 94 20 F9 BB CB FF 68 B4 A0 92 EE 87 60 5E 6B 0E FC 2F 20 3D 84 18 7E
TX: 16:02:53 7E A0 08 44 D1 03 91 8D 33 7E
RX: 16:02:53 7E A8 87 03 44 D1 B8 66 D3 11 E2 6B ED 44 90 BE 4C F4 7D 34 7F 95 A5 74 6B D2 59 B5 EC D7 58 42 84 01 EA D3 3B 56 D7 32 2F 41 55 E4 24 F5 03 82 9A CD 4D B8 8B 74 C4 CA 82 FC E2 C1 7C C3 72 18 61 D4 E4 22 C6 DF 1F E2 20 A7 D6 6D 9D 8F DB 94 8D D9 8C 02 35 B5 37 C0 A7 87 4E DB 75 9F 2C 95 57 04 E2 CA 7B D1 F1 8B D2 0C 60 6E 61 06 E9 18 5A CA 85 AA 06 D3 05 93 BE 03 C5 24 E1 08 AF 8F 81 B8 C7 77 94 CA AE 96 7E
TX: 16:02:53 7E A0 08 44 D1 03 B1 8F 12 7E
RX: 16:06:19 7E A0 64 03 44 D1 BA 06 E7 E9 5F 94 32 0C EE F2 E9 81 EE 86 C0 2B C2 71 7C F6 D6 82 E7 6B 9E 83 74 42 AB 5F A2 B7 68 C2 4B 5F 01 10 C1 3B 32 22 59 41 83 2A CF 5B 26 7C 3B 38 90 4F 56 38 10 19 4C F9 4E 69 50 8A 10 E9 C3 D5 73 46 09 5C C6 A1 B6 A0 B8 70 FA 8B DC D6 51 26 1F 8F 77 4E 3E 35 6E FB 94 F0 9A 7E
Hi, This is fixed for…
This is fixed for version 1.0.154.
Giulia2
Hi Mikko, thanks. With 1.0…
thanks. With 1.0.154 it works.
Giulia
