  3. V.44 Compression Support
V.44 compression support
By dutchguy , 16 April, 2024
Do you have any timeline for when V.44 compression support is added to your library? The patent for V.44 is now expired, so that should not be an issue anymore.
2 years 6 months ago
Hi, V.44 is coming, but I'm…
V.44 is coming, but I'm not quite sure when it can be released. The compress rate seems to be quite good, but it's using a lot of memory and it's quite complex. I believe that it will be released sometime in the autumn.
dutchguy
Ok, thanks for the…
Ok, thanks for the information. If you have any beta version, I would be interested to test it :)
Hi, I'm sorry, but only our…
I'm sorry, but only our customers can access beta versions. It causes too much work if the version is released too early for general availability.
dutchguy
Ok, no problem, I will wait…
Ok, no problem, I will wait for the release.
dutchguy
1 year 7 months ago
Any updates on V.44?
1 year 7 months ago
Hi, It's under testing, but…
It's under testing, but not released as public yet.
