  3. Landis E650 Hight Level Authentication
Landis E650 Hight level authentication
By gpatane , 8 April, 2024
I try to use hight authentication to connect to a Landis E650 and I found a gurux function EncryptLandisGyrHighLevelAuthentication() to encrypt the password to send to the meter. This function requires two parameters: the first the password to be encrypted and the second the "Seed", parameter received from the meter but I don't know how to get it!
2 years 7 months ago
Hi, The meter sends the seed…
The meter sends the seed in AARE message. Gurux DLMS library handles that automatically.
gpatane
Is it possible to have a…
Is it possible to have a code example to perform hight authentication with password encryption and seed?
Hi, You can do it something…
You can do it something like this:
GXDLMSSecureClient client = new GXDLMSSecureClient(false);
client.ManufacturerId = "LGZ":
//Generate AARQ request.
//Split requests to multiple packets if needed.
//If password is used all data might not fit to one packet.
var aarq = Client.AARQRequest();
//AARQ is not used for pre-established connections.
if (aarq.Length != 0)
foreach (byte[] it in aarq)
if (Trace > TraceLevel.Info)
Console.WriteLine("Send AARQ request", GXCommon.ToHex(it, true));
reply.Clear();
ReadDataBlock(it, reply);
Console.WriteLine("Parsing AARE reply" + reply.ToString());
//Parse reply.
Client.ParseAAREResponse(reply.Data);
reply.Clear();
//Get challenge Is HLS authentication is used.
if (Client.Authentication > Authentication.Low)
foreach (byte[] it in Client.GetApplicationAssociationRequest())
reply.Clear();
Client.ParseApplicationAssociationResponse(reply.Data);
Console.WriteLine("Parsing AARE reply succeeded.");
gpatane
I am getting authentication…
I am getting authentication error in parse reply:
Dim client As New GXDLMSSecureClient(False)
Client.ManufacturerId = "LGZ"
Client.UseLogicalNameReferencing = False
Client.InterfaceType = InterfaceType.HDLC
Client.ClientAddress = 48
Client.Authentication = Authentication.High
Client.Password = ASCIIEncoding.ASCII.GetBytes("3217423") ' <== ****** Default Password High Level ******
Manufacturer = man
UpdateManufactureSettings(man.Identification)
If TypeOf Media Is GXSerial Then
Console.WriteLine("Initializing serial connection.")
InitSerial()
ElseIf TypeOf Media Is GXNet Then
Console.WriteLine("Initializing Network connection.")
InitNet()
'Some Electricity meters need some time before first message can be send.
System.Threading.Thread.Sleep(500)
Else
Throw New Exception("Unknown media type.")
End If
Dim reply As New GXReplyData()
Dim data As Byte()
data = Client.SNRMRequest()
If data IsNot Nothing Then
If Trace Then
Console.WriteLine("Send SNRM request." + GXCommon.ToHex(data, True))
End If
ReadDLMSPacket(data, reply)
If Trace Then
Console.WriteLine("Parsing UA reply." + reply.ToString())
End If
'Has server accepted client.
Client.ParseUAResponse(reply.Data)
Console.WriteLine("Parsing UA reply succeeded.")
End If
reply.clear
' Generate AARQ request.
' Split requests to multiple packets if needed.
' If password is used all data might not fit to one packet.
Dim aarq = Client.AARQRequest()
' AARQ is not used for pre-established connections.
If aarq.Length <> 0 Then
For Each it As Byte() In aarq
Console.WriteLine("Invia richiesta AARQ: " & GXCommon.ToHex(it, True))
reply.Clear()
ReadDataBlock(it, reply2)
Next
Console.WriteLine("Analisi risposta AARE: " & reply.ToString())
' Parse reply.
Client.ParseAAREResponse(reply.Data) <<= Here I get the error Authentication failue
reply.Clear()
' Get challenge Is HLS authentication is used.
If Client.Authentication > Authentication.Low Then
MsgBox("3")
For Each it As Byte() In Client.GetApplicationAssociationRequest()
reply.Clear()
Next
End If
Console.WriteLine("Analisi risposta AARE completata.")
End If
Hi, Can you connect with…
Can you connect with GXDLMSDirector to this meter?
Are you using C# or Java?
What kind of authentication error do you receive?
Can you add the hex trace from this?
gpatane
I use VB.Net but I can also…
I use VB.Net but I can also use C#
I have tried with GXDLMSDirector and work fine with this command line:
-h 192.168.1.1 -p 4059 -r sn -c 48 -a High -P 3217423 -w 1 -f 128 -t Verbose
GXDLMSDirector works and I can reset the registry F.F successfull.
With my code I can connect using the gurux libraries with Low authentication and I can read the registers, GenericProfile and also updating successfull the date and time of the meter.
I need to log in with High authentication to reset the F.F error register 0.0.97.97.0.255.
Best regards
Giacomo
Hi Giacomo, Try with…
Hi Giacomo,
Try with GXDLMSDirector and C#. Landis+Gyr is using High authentication that is not defined on DLMS standard and it's added later.
Let me know if you have any problems.
gpatane
I have tried with…
The problem is with my application!
gpatane
Returned authentication…
Returned authentication failure on row: Client.ParseAAREResponse(reply.Data)
' Client properties
Client = dlms
Media = media1
InitializeIEC = useIec
Client.ServerAddress = 1
Manufacturer = man
InitSerial()
InitNet()
Else
End If
Dim data As Byte()
If Trace Then
End If
If Trace Then
End If
End If
reply.Clear()
reply.Clear()
Next
' >>>>>> Hear i have error Authentication failure <<<<<<
reply.Clear()
' Ottieni la sfida se viene utilizzata l'autenticazione HLS.
reply.Clear()
Next
End If
End If
I get the following error:
Send AARQ request: 7E A8 47 03 25 10 6B 9C E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 56 3B 0C 0E 43 6C 52 63 53 52 5D 59 13 07 40 45 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 DC 62 7E
Send AARQ request: 7E A0 0E 03 25 12 8D 0A 1C 03 20 FF FF 4E 99 7E
AARE response: 61 29 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 00 09 60 FA 00
Disconnecting from the meter.
Gurux.DLMS.GXDLMSException: Connection is permanently rejected. Authentication failure.
in Gurux.DLMS.Internal.GXAPDU.ParsePDU2(GXDLMSSettings settings, GXICipher cipher, GXByteBuffer buff, GXDLMSTranslatorStructure xml)
in Gurux.DLMS.Internal.GXAPDU.ParsePDU(GXDLMSSettings settings, GXICipher cipher, GXByteBuffer buff, GXDLMSTranslatorStructure xml)
in Gurux.DLMS.GXDLMSClient.ParseAAREResponse(GXByteBuffer reply)
in Gurux.DLMS.Client.Example.VB.GXCommunicatation.InitializeConnection(GXManufacturer man) in C:\Users\user1\Desktop\dlms.net\GXCommunicatation.vb:riga 487
in Gurux.DLMS.Client.Example.VB.main.Main() in C:\Users\user1\Desktop\dlms.net\main.vb:riga 259
Hi, Can you add the…
Can you add the GXDLMSDirector hex trace here so I can check what might be the problem? Only connection messages (6 messages) are enough.
gpatane
20:36:12 Send SNRM request…
20:36:12 Send SNRM request.
TX: 7E A0 07 03 61 93 69 47 7E
20:36:12
RX: 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
20:36:12 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 07 27 51 57 3B 63 72 55 14 62 23 69 0F 1F 1E 0B BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 B2 BE 7E
20:36:13
RX: 7E A0 07 61 03 31 61 27 7E
20:36:13 Send AARQ request.
TX: 7E A0 0E 03 61 12 8B 2B 1C 03 20 FF FF 4E 99 7E
20:36:13
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 36 34 46 34 30 30 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 3B FC 7E
20:36:13 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 39 36 30 42 34 32 33 30 9F FB 7E
20:36:13
RX: 7E A0 0F 61 03 72 26 B2 E6 E7 00 0D 01 00 07 E4 7E
Hi, Your client address is…
Your client address is wrong. You are using the client address 0x12 and GXDLMSDirector is using the client address 0x30.
You must set the client address after you have call UpdateManufactureSettings.
UpdateManufactureSettings sets the default client address, but your model is using something else client address than the older Landis+Gyr meters.
gpatane
Hi, By moving the client…
By moving the client address setting after updatemanufactured I was able to connect with high authentication.
Unfortunately it doesn't always connect successfully, but causally, sometimes it connects successfully and sometimes it doesn't.
Connection error:
Gurux.DLMS.GXDLMSException: Access Error : Device reports scope of access violated.
16:54:19 Send SNRM request.
16:54:19
16:54:19 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 30 5D 0F 62 01 77 39 48 48 59 68 6B 6E 0F 54 27 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 64 BD 7E
16:54:20
16:54:20 Send AARQ request.
16:54:20
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 45 36 37 45 30 30 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 C4 A0 7E
16:54:20 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 48 38 38 4C 34 32 33 30 98 34 7E
16:54:20
RX: 7E A0 10 61 03 72 7E C3 E6 E7 00 0D 01 01 0D 1E 46 7E
16:54:20
RX: 7E A0 07 61 03 73 77 46 7E
Connected successfull
16:54:59 Send SNRM request.
16:54:59
16:54:59 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 34 46 2F 04 28 0B 0A 59 53 51 5B 03 6A 02 37 19 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 A2 04 7E
16:55:00
16:55:00 Send AARQ request.
16:55:00
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 41 42 36 37 30 34 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 47 DB 7E
16:55:00 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 44 44 37 45 34 36 33 30 A0 A0 7E
16:55:00
Hi, I believe that there is…
I believe that there is an issue with how the challenge is counted.
Landig+Gyr has not released the formula and this is my interpretation from the challenge generation. Can you add a few (two or three) successful connections here? I'll see if I can find anything.
gpatane
Hi, ========================…
CONNECT SUCCESSFULL
10:26:44 Send SNRM request.
10:26:44
10:26:44 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 08 2E 22 0A 27 5C 72 56 21 0E 14 43 2B 48 08 77 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 69 88 7E
10:26:44
10:26:44
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 35 34 30 39 30 30 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 C8 6C 7E
10:26:44 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 38 36 31 30 34 32 33 30 70 7D 7E
10:26:44
CONNECT SUCCESSFULL
10:27:06 Send SNRM request.
10:27:07
10:27:07 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 78 41 5F 44 66 0C 16 14 3A 76 1E 56 3B 77 02 42 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 34 7E
10:27:07
10:27:07
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 38 30 37 32 30 33 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 DE EA 7E
10:27:07 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 42 32 38 39 34 35 33 30 BE 44 7E
10:27:07
CONNECT SUCCESSFULL
10:27:22 Send SNRM request.
10:27:22
10:27:22 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 2C 2C 53 61 78 1B 64 74 65 23 08 00 5A 0F 79 19 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 78 05 7E
10:27:22
10:27:22
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 35 45 46 32 30 32 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 FD 3B 7E
10:27:22 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 38 30 30 39 34 34 33 30 2B A6 7E
10:27:22
CONNECT SUCCESSFULL
10:27:36 Send SNRM request.
10:27:36
10:27:36 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 60 3D 31 3A 37 70 6E 58 39 2C 28 6C 52 71 48 17 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 26 0E 7E
10:27:36
10:27:36
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 37 34 44 32 30 30 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 66 AB 7E
10:27:36 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 41 36 45 39 34 32 33 30 C3 DD 7E
10:27:37
CONNECT SUCCESSFULL
10:28:33 Send SNRM request.
10:28:34
10:28:34 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 79 75 5A 0B 0B 19 0D 56 65 26 62 69 58 17 46 68 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 F9 A7 7E
10:28:34
10:28:34
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 44 36 36 32 30 31 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 9A A0 7E
10:28:34 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 30 38 37 39 34 33 33 30 AF C5 7E
10:28:34
CONNECT SUCCESSFULL
10:29:17 Send SNRM request.
10:29:18
10:29:18 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 37 20 59 1C 53 6B 43 74 02 0F 32 17 18 00 72 3B BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 88 D2 7E
10:29:18
10:29:18
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 38 44 31 39 30 30 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 48 53 7E
10:29:18 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 42 46 32 30 34 32 33 30 EB CE 7E
10:29:18
ERROR: Device reports scope of access violated
10:25:25 Send SNRM request.
10:25:25
10:25:25 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 2D 6C 35 59 0E 18 21 24 4F 0E 47 38 79 66 14 6A BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 8F E4 7E
10:25:26
10:25:26 Send AARQ request.
10:25:26
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 32 46 31 35 30 30 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 E3 CA 7E
10:25:26 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 35 48 32 43 34 32 33 30 82 54 7E
10:25:27
10:25:27
10:27:50 Send SNRM request.
10:27:50
10:27:50 Send AARQ request.
TX: 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 05 47 55 74 43 2E 3C 41 45 03 3E 07 31 68 0B 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 98 32 7E
10:27:51
10:27:51 Send AARQ request.
10:27:51
RX: 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 39 43 33 44 30 33 30 30 BE 10 04 0E 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 EC B8 7E
10:27:51 Authenticating.
TX: 7E A0 1C 03 61 34 68 95 E6 E6 00 06 01 02 FA 58 01 09 08 43 45 34 4B 34 35 33 30 DA 21 7E
10:27:51
10:27:51
2 years ago
Hi, This is finally fixed…
This is finally fixed for Gurux.DLMS.Net version 9.0.2410.3101.
gpatane
2 years ago
Hi, Now the high…
Now the high authentication works well but only with meters connected via ethernet.
If the meter is connected via GSM it does not work.
Regards
Giacomo
2 years ago
Hi Giacomo, The password…
Hi Giacomo,
The password generation is the same for GPRS and TCP/IP.
Are you getting any reply from the meter? If not, check that you are using static IP addresses.
You can read more from dynamic and static IP addresses from here:
  • Victorian | WA 083148835648
