  3. HLS Mechanism_id(2)
HLS Mechanism_id(2)
By Shanmukhi , 7 March, 2024
After send f(ctos) we are getting Access Error : Device matched a unmatched type
we are using mechanism id (2) . we are giving password as "hello"
our AARE is passed and action request came from gurux director we can able to decrypt it
but further we are failing.
Shanmukhi
2 years 8 months ago
Response from meter:7E A0 7A…
Shanmukhi
BlockCipher key: 30 31 32 33…
Hi, In the log, you are not…
In the log, you are not sending f(ctos) or password yet. Those are sent in step 3. You are just sent AARQ and the meter returns AARE that you have added.
I believe that your password is wrong.
Shanmukhi
7E A0 41 00 02 04 01 61 32…
7E A0 41 00 02 04 01 61 32 16 F6 E6 E6 00 CB 30 30 00 00 00 01 F9 E1 7E D2 C1 0D 43 3C D4 96 9D B5 33 42 3F 59 F2 55 02 9D F5 E2 06 F2 BC 8C 1C 8F E7 2B 08 A7 F4 6B A7 ED 46 E3 41 E4 5C 44 F5 04 C7 7E
The above request, the meter can able to decrypt. We don't know which algorithm/mode is used in Mechanism_id(2) of GURUX.
Can you share details of the algorithm/mode used in Mechanism_id(2) of GURUX?
Hi, High authentication is a…
High authentication is a problem because DLMS specification does not specify details of the HLS mechanism. Indian standard uses Aes-128 for High authentication, so Gurux DLMS libraries are also using Aes-128 for High authentication.
Shanmukhi
Hi Thank you for the reply,…
What mode of AES-128 is used in Indian Standards and implemented in Gurux DLMS libraries?
Shanmukhi
Hi Shanmukhi, The mode is…
Hi Shanmukhi,
The mode is CBC NoPadding.
  • Victorian | WA 083148835648
