  3. GXDLMSTranslator.DataToXml Vs Signed Integers
GXDLMSTranslator.DataToXml vs signed Integers
By DanB , 4 March, 2024
Is there any documentation available on what DatatoXML should produce in SimpleXML mode?
Hit an odd thing in v9.0.2205.2301 and confirmed it still occurs in v9.0.2402.2201
Converting any signed integer with a negative value seems to give a 64bit hex value in the XML.
passing data as 0x10FFFB (16bit Integer value = -5)
results in <Int16 Value="FFFFFFFFFFFFFFFB" />
Similar for 0x0FFB (8bit signed int = -5) => <Int8 Value="FFFFFFFFFFFFFFFB" />
And 0x05FFFFFFFB (32bit signed int =-5) => <Int32 Value="FFFFFFFFFFFFFFFB" />
Is this "expected behavior"?
Cheers Dan
2 years 8 months ago
Hi Dan, DatatoXML converts…
Hi Dan,
DatatoXML converts DLMS data to the XML and the output depends on the content. So output can be anything.
C# ToString shows a negative number as 64-bit value. This is fixed for the next release and extra bits are removed.
If you don't want to see output as a hex you can also set hex to false.
GXDLMSTranslator t = new GXDLMSTranslator();
t.Hex = false;
DanB
Hi Mikko, Hex is fine! But i…
Hex is fine!
But i was expecting the length of the output value to match the declared type / amount of data passed in.
<Int8 Value="FB">
<Int16 Value="FFFB">
<Int32 Value="FFFFFFFB">
It is strange to pass in a 1 byte value and get 8 bytes out.. no?
Dan
