  3. Can´t Compile C++ GuruxDLMSClientExample Using Make
Can´t compile C++ GuruxDLMSClientExample using make
By alvaromemo , 17 February, 2024
Hi, i just download the latest git hub repository and try to compile the example provided but it failed.
When i run *make* it complains about the /bin and /obj folders. I manually create it. Then when i repeat the *make* it shows:
Compiled src/GuruxDLMSClientExample.cpp successfully!
usr/bin/ld: cannot find -lgurux_dlms_cpp: No such file or directory
collect2: error: ld returned 1 exit status
make: *** [makefile:27: bin/gurux.dlms.client.bin] Error 1
I am using g++
Using built-in specs.
COLLECT_GCC=/usr/bin/g++
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/13/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-redhat-linux
Configured with: ../configure --enable-bootstrap --enable-languages=c,c++,fortran,objc,obj-c++,ada,go,d,m2,lto --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-gcc-major-version-only --enable-libstdcxx-backtrace --with-libstdcxx-zoneinfo=/usr/share/zoneinfo --with-linker-hash-style=gnu --enable-plugin --enable-initfini-array --with-isl=/builddir/build/BUILD/gcc-13.2.1-20231205/obj-x86_64-redhat-linux/isl-install --enable-offload-targets=nvptx-none --without-cuda-driver --enable-offload-defaulted --enable-gnu-indirect-function --enable-cet --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux --with-build-config=bootstrap-lto --enable-link-serialization=1
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 13.2.1 20231205 (Red Hat 13.2.1-6) (GCC)
2 years 9 months ago
Hi, The M Make file don't…
The M
Make file don't make bin and obj folders. You need to make them.
mkdir bin
mkdir obj
  • Victorian | WA 083148835648
